XSDDiagnostic [message #62237] |
Fri, 01 July 2005 21:39  |
Originally posted by: anand.mindreef.com
I'm trying to process the Diagnostics obtained by running validate().
My question is: what's the relationship between what's returned by
diagnostic.getNode() and diagnostic.getComponents() (of which the first
element is getPrimaryComponent())?
Thanks!
Anand Thakker
Mindreef, Inc
http://www.mindreef.com
Web Services Diagnostics
Re: XSDDiagnostic [message #62292 is a reply to message #62237] |
Tue, 05 July 2005 08:20  |
Anand,
Something like a complex type can be composed of a number of nested
elements and there could be problems like bad attributes on any of those
elements. The getNode method should return exactly the right node,
e.g., the restriction, or the complexContent. The getComponents returns
all the components involved in the error. For example, if you have a
length facet, there shouldn't be a minLength or maxLength facet, so if
both are present along with the length, they will both be included in
the components.
> first element is getPrimaryComponent())?
> Thanks!
> Anand Thakker
> Mindreef, Inc
Re: XSDDiagnostic [message #595955 is a reply to message #62237] |
Anand,
the components.
> Thanks!
> Anand Thakker
> Mindreef, Inc
FUDForum. Page generated in 0.03285 seconds
