Home » Eclipse Projects » Subversive » Re: Mylar and team support (Subversion?)
Re: Mylar and team support (Subversion?) [message #5560] Sun, 10 September 2006 23:35 Go to next message
Ok, it seems to work better with Subclipse :)
Thanks again Eike.
For Mylar team (or maybe more for Subversive team) I red somewhere that the
problem was related to changeset not properly implemented in Subversive, is
it true ? Do you have any idea as to when Mylar will work with Subversive ?
Thanks a lot.
Joel.
"Joel Cheuoua" <jcheuoua@gmail.com> wrote in message
news:edts8c$40v$1@utils.eclipse.org...
> Hi Eike,
> Thanks for the tip, I will give it a try.
> Always a pleasure to hear from you :)
> Cheers.
> Joel.
> "Eike Stepper" <stepper@sympedia.de> wrote in message
> news:edtnai$v1t$1@utils.eclipse.org...
>> Hi Joel,
>> While adding configurable commit comment templates to Mylar I've seen
>> that there is a class
>> org.eclipse.mylar.internal.team.subclipse.SubclipseTeamRepos itoryProvider
>> as well. Since I don't like the Subclipse frontend very much, I did not
>> test the Mylar integration. But maybe you can simply try it?!
>> Cheers
>> /Eike
>> Joel Cheuoua schrieb:
>>> Hello folks,
>>> Great work with Mylar !
>>> I'm new to this very exciting plugin, hence I'am sorry if the question
>>> has already been mentioned here (a quick search wasn't successful)
>>> How is Mylar linked to the Eclipse Team Support framework ? Is it linked
>>> only to CVS ? is it possible/planned to extend it to other SCC like
>>> Subversion (using either subclipse or subversive) ?
>>> Thanks.
>>> Joel.
Re: Mylar and team support (Subversion?) [message #5565 is a reply to message #5560] Mon, 11 September 2006 14:11 Go to previous messageGo to next message
Hello Joel,
Thank you for nice questions. Unfortunately we have no information about
problems with change sets implementation. Could you please let us know
details (or source of this information)?
Regarding the time when you can see Subversive integration with Mylar - our
team does the best in order to make it as soon as possible. First of all we
included change sets support into the Subversive 1.1.x stream. Also we
created Architecture Overview document
http://www.polarion.org/projects/subversive/docs/Subversive_ Architecture_Overview.pdf,
which describes Subversive integration features. From our point of view it's
enough to start discussion with Mylar about integration.
We asked Mik Kersten to review the Subversive infrastructure from the Mylar
integration point of view. I suppose to get feedback soon. In this post I
want to summarize points about integration and want ask someone from Mylar
team to address them.
1. It will be great to have Subversive integrated with Mylar. Could you
please help us with this? What is required from our side?
2. Could you please review Subversive change sets support and integration
features? Are they full sufficient for integration with Mylar?
We are looking forward to get integration with Mylar soon. Thank you.
Igor Vinnykov
Subversive Team
Re: Mylar and team support (Subversion?) [message #5572 is a reply to message #5565] Mon, 11 September 2006 15:04 Go to previous messageGo to next message
Originally posted by: jcheuoua.ilog.com
Hi Igor,
"Igor Vinnykov" <igor.vinnykov@polarion.org> wrote in message
news:ee48se$u4g$1@utils.eclipse.org...
> Hello Joel,
Actually I think what I red was related to what you just mention hereafter
(supporting change sets into Subversive 1.1.x stream).
> our team does the best in order to make it as soon as possible. First of
> all we included change sets support into the Subversive 1.1.x stream. Also
> we created Architecture Overview document
> it's enough to start discussion with Mylar about integration.
> Mylar integration point of view. I suppose to get feedback soon. In this
> post I want to summarize points about integration and want ask someone
> from Mylar team to address them.
And I'm eagerly looking forward to get it :)
Joel.
> Best regards,
> Igor Vinnykov
> Subversive Team
Re: Mylar and team support (Subversion?) [message #5579 is a reply to message #5565] Wed, 13 September 2006 20:26 Go to previous messageGo to next message
Originally posted by: mik.kersten.eclipse.org
Hi Igor,
Given that you now have change sets, it should be very straightforward
to integrate with Mylar's automatic change set management and commit
messages. All that's required is to make your change set implementation
accessible to Mylar via the org.eclipse.mylar.team.providers extension
point. I've summarized the steps and requirements here:
http://wiki.eclipse.org/index.php/Mylar_Integrator_Reference #Integrating_Team_Providers
If you have any questions or requests when implementing this please
either create a new Bugzilla report and reply with the link in case
others are interested in the discussion.
http://www.eclipse.org/mylar/bugs.php
Mik
Igor Vinnykov wrote:
> Hello Joel,
Re: Mylar and team support (Subversion?) [message #5586 is a reply to message #5579] Fri, 15 September 2006 04:31 Go to previous messageGo to next message
Hello Mik,
Thank you for these references - it's exact information, which we need. Now
we have a set of urgent tasks related with the Subversive functionality and
as soon as they will be finished, we will spend efforts to make the
integration with Mylar. We will keep community informed about the progress.
Igor Vinnykov
Subversive Team
"Mik Kersten" <mik.kersten@eclipse.org> ???????/???????? ? ????????
?????????: news:4508A1AA.2040207@eclipse.org...
> Hi Igor,
> Given that you now have change sets, it should be very straightforward to
> If you have any questions or requests when implementing this please either
> create a new Bugzilla report and reply with the link in case others are
> Cheers,
> Mik
>> Hello Joel,
>> Also we created Architecture Overview document
Re: Mylar and team support (Subversion?) [message #5633 is a reply to message #5579] Wed, 04 October 2006 07:29 Go to previous message
Hello Mik and other,
I want to announce Mylar integration, which was included to the latest
Subversive 1.1.0 M5 build. It will be great if someone from Mylar team can
evaluate integration and let us know the result. Also we welcome community
to test the integration and share opinion with us.
How to install the Mylar integration:
Point Update Manager to
http://www.polarion.org/projects/subversive/download/1.1/upd ate-site/ and
select Mylar Integration during installation.
Igor Vinnykov
Subversive Team
> Hi Igor,
> Cheers,
> Mik
Previous Topic:svn metadata
Next Topic:Cooperation Subclipse, Subversive
Current Time: Sun Nov 09 18:56:31 EST 2025
Powered by FUDForum. Page generated in 0.04418 seconds
