Saving values modified from property sheet [message #62221] |
Tue, 19 May 2009 04:31  |
Originally posted by: rodrigo.garcia.kotasoft.com
I want to know how to setDirty my editor when a property of my model is
changed from the propertySheetPage.
I have this in my editor:
protected PropertySheetPage getPropertySheetPage()
if (null == propertySheetPage)
propertySheetPage = new PropertySheetPage();
propertySheetPage.setPropertySourceProvider(new
EObjectPropertySourceProvider());
return propertySheetPage;
public Object getAdapter(Class adapter) {
if (adapter == IPropertySheetPage.class)
return getPropertySheetPage();
// the super implementation handles the rest
return super.getAdapter(adapter);
The propertySheet shows the differents properties of my model and let me
edit, but I need to save the new values.
Any idea?
Thanks in advance.
Re: Saving values modified from property sheet [message #63158 is a reply to message #62341] |
Mon, 25 May 2009 13:02  |
Ok, I'll do that,
but it would be possible add the editor like a listener to the
propertysource?
Ben Vitale escribió:
> If your model provides notification when it changes, listen for those
> notifications in your editor and call firePropertyChange(PROP_DIRTY).
> Also make sure you implement isDirty().
> Hope that helps,
> Ben
> Rodrigo García wrote:
>> is changed from the propertySheetPage.
>> me edit, but I need to save the new values.
>> Any idea?
>> Thanks in advance.
Re: Saving values modified from property sheet [message #597674 is a reply to message #62221] |
Wed, 20 May 2009 16:34  |
Hope that helps,
Ben
> Any idea?
> Thanks in advance.
Re: Saving values modified from property sheet [message #597837 is a reply to message #62341] |
Ok, I'll do that,
propertysource?
> Hope that helps,
> Ben
>> Any idea?
>> Thanks in advance.
FUDForum. Page generated in 0.05629 seconds
