Home » Eclipse Projects » Plugin Development Environment (PDE) » Saving values modified from property sheet
Saving values modified from property sheet [message #62221] Tue, 19 May 2009 04:31 Go to next message
Originally posted by: rodrigo.garcia.kotasoft.com
I want to know how to setDirty my editor when a property of my model is
changed from the propertySheetPage.
I have this in my editor:
protected PropertySheetPage getPropertySheetPage()
if (null == propertySheetPage)
propertySheetPage = new PropertySheetPage();
propertySheetPage.setPropertySourceProvider(new
EObjectPropertySourceProvider());
return propertySheetPage;
public Object getAdapter(Class adapter) {
if (adapter == IPropertySheetPage.class)
return getPropertySheetPage();
// the super implementation handles the rest
return super.getAdapter(adapter);
The propertySheet shows the differents properties of my model and let me
edit, but I need to save the new values.
Any idea?
Thanks in advance.
Re: Saving values modified from property sheet [message #62341 is a reply to message #62221] Wed, 20 May 2009 16:34 Go to previous messageGo to next message
If your model provides notification when it changes, listen for those
notifications in your editor and call firePropertyChange(PROP_DIRTY).
Also make sure you implement isDirty().
Hope that helps,
Ben
Rodrigo García wrote:
> Any idea?
> Thanks in advance.
Re: Saving values modified from property sheet [message #63158 is a reply to message #62341] Mon, 25 May 2009 13:02 Go to previous message
Ok, I'll do that,
but it would be possible add the editor like a listener to the
propertysource?
> Hope that helps,
> Ben
>> is changed from the propertySheetPage.
>> me edit, but I need to save the new values.
>> Any idea?
>> Thanks in advance.
Re: Saving values modified from property sheet [message #597674 is a reply to message #62221] Wed, 20 May 2009 16:34 Go to previous message
Hope that helps,
Ben
> Any idea?
> Thanks in advance.
Re: Saving values modified from property sheet [message #597837 is a reply to message #62341] Mon, 25 May 2009 13:02 Go to previous message
Ok, I'll do that,
propertysource?
> Hope that helps,
> Ben
>> Any idea?
>> Thanks in advance.
Previous Topic:View menuContribution always disabled
Next Topic:Language Pack Eclipse 3.4.2
Current Time: Thu Nov 20 23:38:09 EST 2025
Powered by FUDForum. Page generated in 0.24594 seconds
