Home » Language IDEs » AspectJ » AJDT on Mustang (java 1.6) problem
AJDT on Mustang (java 1.6) problem [message #62210] Fri, 24 February 2006 10:25 Go to next message
Hi.
Do AJDT work on Mustang(java 1.6)?
When I start Eclipse with AJDT using java 1.5_06 I see AJDT related stuff
(e.g. menus, toolbars, etc) in eclipse window.
When I start Eclipse with AJDT using java 1.6 I do not see any AJDT
related stuff, but AJDT presents in Help -> Software updates -> Manage
Configuration. No errors appear in .log file too.
WBR,
Stanislav Bernatsky.
Re: AJDT on Mustang (java 1.6) problem [message #62233 is a reply to message #62210] Fri, 24 February 2006 11:48 Go to previous messageGo to next message
Works fine for me and has done so for quite some time. I'm curently using
b72.
-h
Re: AJDT on Mustang (java 1.6) problem [message #62280 is a reply to message #62233] Mon, 27 February 2006 04:43 Go to previous messageGo to next message
Hmm. Doesn't work for me neither with bublic beta nor b70 of mustang.
I'm using 1.4.0 version of AJDT (build 20060209002800, AspectJ version:
1.5.1.20060131132251) with eclipse 3.2M4.
What is yours configuration so I could check it for me?
WBR,
Re: AJDT on Mustang (java 1.6) problem [message #62352 is a reply to message #62280] Thu, 02 March 2006 10:17 Go to previous messageGo to next message
Replying to myself:
I've figured why AJDT didn't work.
It was broblem with org.eclipse.pde.build plugin that AJDT depends on.
For it 'Bundle-RequiredExecutionEnvironment: J2SE-1.4' was set in
MANIFEST-MF. Deleting this line helped.
WBR,
PS. [off] Is there any way to specify that plugin requires _at least_ the
specified version?
Re: AJDT on Mustang (java 1.6) problem [message #62401 is a reply to message #62352] Thu, 02 March 2006 10:52 Go to previous message
Aha, good detective work.
> specified version?
I'm not sure, but if not, there should be! This seems a bit of a strange
specification for that plug-in to be making anyway. Can you raise a bug
for this against PDE?
Matt.
Re: AJDT on Mustang (java 1.6) problem [message #592341 is a reply to message #62210] Fri, 24 February 2006 11:48 Go to previous message
b72.
-h
Re: AJDT on Mustang (java 1.6) problem [message #592359 is a reply to message #62233] Mon, 27 February 2006 04:43 Go to previous message
WBR,
Re: AJDT on Mustang (java 1.6) problem [message #592384 is a reply to message #62280] Thu, 02 March 2006 10:17 Go to previous message
Replying to myself:
WBR,
specified version?
Re: AJDT on Mustang (java 1.6) problem [message #592399 is a reply to message #62352] Thu, 02 March 2006 10:52 Go to previous message
> specified version?
Matt.
Previous Topic:AJDT New Feature of the Week: Additional Crosscutting Comparison functionality
Next Topic:Multi-dirrectory output
Current Time: Tue Nov 04 00:21:00 EST 2025
Powered by FUDForum. Page generated in 0.05462 seconds
