Home » Language IDEs » PHP Development Tools (PDT) » PDT debugger doesn't stop at break points
PDT debugger doesn't stop at break points [message #62209] Thu, 06 December 2007 06:02 Go to next message
Originally posted by: joakim.astrocalc.com
Using xdebug 2.0.2 and remote debugging I have noticed after latest PDT
update the other day debugger doesn't stop at breakpoints anymore, same if
using "run to selected line" it just carry on until I have to do some
action in the browser.
Break at first line works though or debugger would have been totally
useless.
Re: PDT debugger doesn't stop at break points [message #62235 is a reply to message #62209] Thu, 06 December 2007 14:28 Go to previous messageGo to next message
Which version of PDT are you using ?
Can you describe your setup, and also your launch setup that you are using to invoke the URL ?
Dave Kelsey
> if using "run to selected line" it just carry on until I have to do some
> useless.
Re: PDT debugger doesn't stop at break points [message #62616 is a reply to message #62235] Mon, 10 December 2007 11:17 Go to previous message
Dave,
thanks for responding. I been away for some days and now I see there is a
new update for PDT so I will try it out to see if my problems remain and
in such case be back.
Previous Topic:Publish files to (local) server
Next Topic:Uploading PHP file to a web server
Current Time: Sat Nov 08 12:10:44 EST 2025
Powered by FUDForum. Page generated in 0.03266 seconds
