| Reading Xtext model file in Java Apps [message #62206] |
Wed, 22 July 2009 04:08  |
Originally posted by: ilyas.keser.gmail.com
Hi @all,
how can I access a Xtext model file in a java application? I am trying
to read it with:
@SuppressWarnings("unused")
ConfDSLPackage confDSLPackage = onfDSLPackage.eINSTANCE;
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put( ".conf",
new ConfDSLFactoryImpl());
URI uri =
URI.createURI(" platform:/resource/myproject/src/de/test/mydsl/Configuration .conf ");
Resource resource = resourceSet.createResource(uri);
try {
resource.load(null);
Configuration conf = (Configuration)resource.getContents().get(0);
} catch (Exception e) {
System.out.println("Failed to read " + uri);
resource.load(null) throws an exception. Any ideas?
Ilyas
| Re: Reading Xtext model file in Java Apps [message #62379 is a reply to message #62306] |
Wed, 22 July 2009 05:29   |
Hi Ilyas,
the ConfDSLFactoryImpl is not a ResourceFactory but an EFactory. It is
not intendent to put an EFactory into the FactoryToExtensionMap.
Please try Knut's suggestion. It should work fine.
Hope that helps,
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 22.07.2009 10:50 Uhr, schrieb Ilyas Keser:
> Hi Sebastian,
> the thrown exception is a NPE and resourceSet.createResource(uri)
> returns null.
> ConfDSLFactoryImpl is generated by Xtext and is in the package
> .../src-gen/de/test/mydsl/confDSL.impl.
> I am using a Xtext grammar to define a configuration file. After
> generating the Xtext artefacts, I created a model file with generated
> DSL editor. Just, I am trying to read/access this model file in a Java
> Application.
> ILyas
> Sebastian Zarnekow schrieb:
>> Hi Ilyas,
>> maybe you want to be more specific about the exception that you catch.
>> Otherwise it is hardly possible to answer your question.
>> Where does the class ConfDSLFactoryImpl come from? Do you mix up an
>> Editor that was generated by EMF and an Xtext-based DSL file?
>> Regards,
>> Sebastian
| Re: Reading Xtext model file in Java Apps [message #62427 is a reply to message #62403] |
Wed, 22 July 2009 07:34  |
Hi Ilyas,
please feel free to update the wiki.
Sebastian
Am 22.07.2009 12:03 Uhr, schrieb Ilyas Keser:
> Sebastian & Knut, thanks for your replies. It works for me.
> The method createInjectorAndDoEMFRegistration() isn't static anymore. Is
> it OK, if I modify the first line of the snippet (in wiki) as follows:
> Injector injector = new
> ConfDSLStandaloneSetup().createInjectorAndDoEMFRegistration( );
> ILyas
>> Hi Ilyas,
>> Hope that helps,
>> Sebastian
FUDForum. Page generated in 0.05537 seconds
