Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Teneo: HibernateResource is not smart enough
Teneo: HibernateResource is not smart enough [message #62119] |
Mon, 20 November 2006 06:35  |
I suppose question is for Martin Taal.
My problem is that HibernateResource is not enough for me.
I can specify hsql query for resource only before loading it.
I need to load some objects into my resource during startup and then load
some other objects incrementally using Criteria or HSQL - criteria is
preferred.
Could it be as some new method like List
HibernateResource.fetchAndLoad(Criteria c) that will fetch objects from
DB, add them to resource if they are not in resource already. I need
correct adding to resource - corresponding listeners
must receive notifications about adding objects to resource.
also i nave seen that StoreResource.attached(Eobject) which is called when
for example lazy collection is fetched doesn't add loaded objects to
resource - so resource.getContents() are not equal union of loadedObjects,
modifiedObjects, newObjects - it's very inconvenient for EMF client
application.
BTW I read comments in StoreResource.load():
// fill in the resource, do not use the normal add method because it
// is possible that a child of a container is loaded, in that case
// the normal add will remove the container of the object when the
// resource is set in the child object, this issue can happen with
/ direct reads using queries.
StoreUtil.setEResource((InternalEObject) obj, this, true);
elist.basicAdd(obj, null);
attached((EObject) obj);
BUT: In my application objects are not distributed across resources - all
objects are in one resource and supposed to be added incrementally.
Also there are no containment relationships in my model.
I can implement classes for my need on my own but I suppose that my
problem is quite general problem (now or in future) - so I need some
response from you.
Thanks in advance.
Re: Teneo: HibernateResource is not smart enough [message #62142 is a reply to message #62119] |
Mon, 20 November 2006 07:32   |
When does the attached method not add loaded objects (to loadedObjects)?
Yes, I can agree that incremental load is a nice feature, although you are the first to ask about it
(afair). I think the implementation is not that hard. The main thing is to call setIsLoading(true)
when incrementally loading extra objects (and setIsLoading(false) afterwards).
Contributions in this area are ofcourse welcome.
gr. Martin
Ilya Klyuchnikov wrote:
> Hi
> load some other objects incrementally using Criteria or HSQL - criteria
> is preferred.
> correct adding to resource - corresponding listeners must receive
> when for example lazy collection is fetched doesn't add loaded objects
> to resource - so resource.getContents() are not equal union of
> loadedObjects, modifiedObjects, newObjects - it's very inconvenient for
> EMF client application.
> all objects are in one resource and supposed to be added incrementally.
> response from you.
> Thanks in advance.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo: HibernateResource is not smart enough [message #62238 is a reply to message #62215] |
Mon, 20 November 2006 09:58   |
Okay I understand (is a bug/missing feature). There is also an option
XMLResource.OPTION_DISABLE_NOTIFY which should be taken into account when this is solved.
Can you enter a bugzilla for this?
Would you be able to send in a patch (would speed up the solution considerably)?
gr. Martin
> Martin Taal wrote:
>> Did you call setTrackingModification(true)?
>> gr. Martin
>>> I am sorry - attached method DOES add loaded objects (to loadedObjects).
>>> Also it adds them to Resource via
>>> BUT IT DOESN'T SEND NOTIFICATIONS TO ADAPTERS ATTACHED TO THE RESOURCE.
> I mean another thing:
> In StoreUtil:
> public static void setEResource(InternalEObject eobj, Resource.Internal
> resource, boolean force) {
> if (eobj.eResource() != null && eobj.eResource() != resource &&
> !force)
> return;
> InternalEObject currentEObject = eobj;
> while (currentEObject.eContainer() != null &&
> !currentEObject.eContainmentFeature().isResolveProxies()) {
> currentEObject = (InternalEObject) currentEObject.eContainer();
> AssertUtil.assertNotSameObject(currentEObject,
> currentEObject.eContainer());
> currentEObject.eSetResource(resource, null);
> currentEObject.eSetResource returns NotificationChain
> but notifications are not dispatched.
> For example:
> I have loaded some objects with lazy collections into HibernateResource.
> When I touch objects from lazy collection these objects are loaded into
> my resource but because notifications are not dispatched my
> adapters/listeners are not informed about loading of new objects from db.
The Netherlands
Re: Teneo: HibernateResource is not smart enough [message #62285 is a reply to message #62261] |
Mon, 20 November 2006 10:38   |
What you mean is that you want to disable notify during initial load and enable (or disable) it
during later loads?
So:
XMLResource.OPTION_DISABLE_NOTIFY=true means that during initial load no notifications are send
StoreResource.OPTION_DISABLE_LAZY_LOADING_NOTIFY=true means that during later lazy loads no
notifications are send.
To support this the Storeresource needs to know that additional load actions are being performed and
they are caused by lazy-load events.
Thinking further:
You mentioned earlier that you also wanted to support incremental loads (not only through lazy
loads). Would this option also control notifications during additional loads?
Maybe a distinction should be made between automatic loads (like a lazy load) and explicit
additional loads? (thinking out loud here)
But to introduce different options for all these cases is maybe too much.
So what I think:
XMLResource.OPTION_DISABLE_NOTIFY controls notifications for explicit load actions (initial, or
otherwise)
StoreResource.OPTION_DISABLE_ADDITIONAL_LOADING_NOTIFY controls notification only for lazy loading
of elists (automatic loading behind the scenes).
What do you think?
Some tips: the lazy load of elists is done in two classes (both in doLoad method):
org.eclipse.emf.teneo.hibernate.mapping.elist.HibernatePersi stableEList
org.eclipse.emf.teneo.hibernate.mapping.elist.HibernatePersi stableFeatureMap
Instead of setLoading(true), something like setLazyLoading (or something) should be done (to make
use of the lazy load option above).
gr. Martin
> I will create issue and patch ASAP.
> But I need your advice:
> XMLResource.OPTION_DISABLE_NOTIFY controls notifications during EMF
> standard loading only (common EMF resources are associated with files -
> so there is no incremental "lazy" loading from the same resource).
> I think that to solve my problem and to make Teneo flexible another
> option is needed - something like
> StoreResource.OPTION_DISABLE_LAZY_LOADING_NOTIFY.
> Do you agree?
> Thanks.
> this is solved.
> considerably)?
>> gr. Martin
>>>> gr. Martin
>>>>> loadedObjects).
>>>>> RESOURCE.
>>> In StoreUtil:
>>> Resource.Internal resource, boolean force) {
>>> && !force)
>>> return;
>>> For example:
>>> HibernateResource. When I touch objects from lazy collection these
>>> objects are loaded into my resource but because notifications are not
>>> dispatched my adapters/listeners are not informed about loading of
The Netherlands
Re: Teneo: HibernateResource is not smart enough [message #62499 is a reply to message #62333] |
Wed, 22 November 2006 05:08  |
I have create issue 165428 about notification and supplied patch.
I will create issue about additional loading by query today.
I hope that I can create patch for additional loading till Friday.
> I agree - two options XMLResource.OPTION_DISABLE_NOTIFY and
> StoreResource.OPTION_DISABLE_LAZY_LOADING_NOTIFY are enough.
> Simplicity and transparency is major.
> Thanks.
>> during later loads?
>> So:
>> later lazy loads no
actions
>> Thinking further:
(not
>> only through lazy
loads?
>> load) and explicit
>> So what I think:
>> otherwise)
notification
>> What do you think?
>> method):
>> gr. Martin
>>> Do you agree?
>>> Thanks.
>>> this is solved.
>>> considerably)?
>>>> gr. Martin
>>>>>> gr. Martin
>>>>>>> loadedObjects).
>>>>>>> RESOURCE.
>>>>> In StoreUtil:
>>>>> && !force)
>>>>> return;
>>>>> For example:
Re: Teneo: HibernateResource is not smart enough [message #595919 is a reply to message #62119] |
gr. Martin
> Hi
> is preferred.
> response from you.
> Thanks in advance.
The Netherlands
Re: Teneo: HibernateResource is not smart enough [message #595937 is a reply to message #62166] |
Mon, 20 November 2006 08:52  |
gr. Martin
The Netherlands
Re: Teneo: HibernateResource is not smart enough [message #595943 is a reply to message #62190] |
Mon, 20 November 2006 09:45  |
> gr. Martin
In StoreUtil:
if (eobj.eResource() != null && eobj.eResource() != resource && !force)
return;
For example:
When I touch objects from lazy collection these objects are loaded into my
Re: Teneo: HibernateResource is not smart enough [message #595951 is a reply to message #62215] |
gr. Martin
>> gr. Martin
> In StoreUtil:
> !force)
> return;
> For example:
The Netherlands
Re: Teneo: HibernateResource is not smart enough [message #595958 is a reply to message #62238] |
Mon, 20 November 2006 10:18  |
standard loading only (common EMF resources are associated with files - so
I think that to solve my problem and to make Teneo flexible another option
Do you agree?
Thanks.
this is solved.
considerably)?
> gr. Martin
>>> gr. Martin
>> In StoreUtil:
>> !force)
>> return;
>> For example:
Re: Teneo: HibernateResource is not smart enough [message #595961 is a reply to message #62261] |
during later loads?
So:
Thinking further:
So what I think:
otherwise)
What do you think?
gr. Martin
> Do you agree?
> Thanks.
> this is solved.
> considerably)?
>> gr. Martin
>>>> gr. Martin
>>>>> loadedObjects).
>>>>> RESOURCE.
>>> In StoreUtil:
>>> && !force)
>>> return;
>>> For example:
The Netherlands
Re: Teneo: HibernateResource is not smart enough [message #595979 is a reply to message #62285] |
Mon, 20 November 2006 11:41  |
Thanks.
> during later loads?
> So:
later lazy loads no
> Thinking further:
only through lazy
load) and explicit
> So what I think:
> otherwise)
> What do you think?
method):
> gr. Martin
>> Do you agree?
>> Thanks.
>> this is solved.
>> considerably)?
>>> gr. Martin
>>>>> gr. Martin
>>>>>> loadedObjects).
>>>>>> RESOURCE.
>>>> In StoreUtil:
>>>> && !force)
>>>> return;
>>>> For example:
Re: Teneo: HibernateResource is not smart enough [message #596048 is a reply to message #62333] |
> Thanks.
>> during later loads?
>> So:
>> later lazy loads no
actions
>> Thinking further:
(not
>> only through lazy
loads?
>> load) and explicit
>> So what I think:
>> otherwise)
notification
>> What do you think?
>> method):
>> gr. Martin
>>> Do you agree?
>>> Thanks.
>>> this is solved.
>>> considerably)?
>>>> gr. Martin
>>>>>> gr. Martin
>>>>>>> loadedObjects).
>>>>>>> RESOURCE.
>>>>> In StoreUtil:
>>>>> && !force)
>>>>> return;
>>>>> For example:
Current Time: Sat Jul 26 19:32:28 EDT 2025
Powered by FUDForum. Page generated in 0.07020 seconds
