Home » Eclipse Projects » Remote Application Platform (RAP) » listener
listener [message #62095] Thu, 22 November 2007 07:34 Go to next message
Originally posted by: wen.ai.gillardon.de
hello all,
I have defined by myself a composite class with several attributs (for
example called one of them "value"). Can anyone tell me, how can I
write a listener for this attribut in rap, when this value has changed?
Thanks a lot.
Greetings
Wen
Re: listener [message #62358 is a reply to message #62095] Fri, 23 November 2007 02:35 Go to previous messageGo to next message
You could load your define your composite as a java bean an add a
property support like this :
private PropertyChangeSupport propertyChangeSupport = new
PropertyChangeSupport(this);
public void addPropertyChangeListener(PropertyChangeListener listener) {
propertyChangeSupport.addPropertyChangeListener(listener);
public void addPropertyChangeListener(String propertyName,
propertyChangeSupport.addPropertyChangeListener(propertyName , listener);
public void removePropertyChangeListener(PropertyChangeListener listener) {
propertyChangeSupport.removePropertyChangeListener(listener) ;
public void removePropertyChangeListener(String propertyName,
propertyChangeSupport.removePropertyChangeListener(propertyN ame,
listener);
protected void firePropertyChange(String propertyName, Object oldValue,
Object newValue) {
propertyChangeSupport.firePropertyChange(propertyName, oldValue,
newValue);
protected void firePropertyChange(String propertyName, int oldValue,
int newValue) {
newValue);
protected void firePropertyChange(String propertyName, boolean
oldValue, boolean newValue) {
newValue);
Then u may use databinding
http://wiki.eclipse.org/index.php/JFace_Data_Binding to bind your
attribute to rwt controls.
Hope this helps you.
Val
Wen Ai wrote:
> hello all,
> Thanks a lot.
> Greetings
> Wen
Re: listener [message #62382 is a reply to message #62358] Fri, 23 November 2007 04:24 Go to previous message
Hi Val,
thank you very much for your infos and I will try that way :-)
cheers
Wen
Val schrieb:
> Hi
> listener);
> Object newValue) {
> newValue);
> int newValue) {
> newValue);
> newValue);
> Cheers,
> Val
> Wen Ai wrote:
>> hello all,
>> Thanks a lot.
>> Greetings
>> Wen
Previous Topic:Cell Editors
Next Topic:some question about resource registry
Current Time: Thu Jul 17 22:32:35 EDT 2025
Powered by FUDForum. Page generated in 0.46289 seconds
