Home » Eclipse Projects » Nebula » Proposal to submit XViewer to eclipse.technology.nebula
Proposal to submit XViewer to eclipse.technology.nebula [message #62087] Thu, 22 January 2009 13:59 Go to next message
For a number of years, the OSEE project (http://www.eclipse.org/osee)
has developed and deployed the XViewer widget as part of it's
engineering environment solution. Since this widget has applicability
beyond OSEE, we wanted to propose submitting it as part of the Nebula
project.
This would allow the Eclipse/SWT community to take advantage of it's
capabilities and also allow collaboration independent of OSEE.
XViewer information:
http://www.eclipse.org/osee/documentation/core/xviewer/xview er.php
Code can be accessed at:
https://dev.eclipse.org/svnroot/technology/org.eclipse.osee/ trunk/org.eclipse.nebula.widgets.xviewer/
XViewer will be debuted at EclipseCon 2009:
https://www.eclipsecon.org/submissions/2009/view_talk.php?id =672
The code was recently split out from the other OSEE source. The plugin
name is named for where it was destined, not where is is committed yet.
Let me know if this is ok for the proposal phase.
Re: Proposal to submit XViewer to eclipse.technology.nebula [message #62111 is a reply to message #62087] Thu, 22 January 2009 14:00 Go to previous messageGo to next message
Cross post to eclipse.technology.osee newsgroup
> project.
Re: Proposal to submit XViewer to eclipse.technology.nebula [message #62230 is a reply to message #62111] Fri, 23 January 2009 03:33 Go to previous messageGo to next message
Hi Don,
Great. We appreciate any contribution. Could you please post a proposal
to the nebula-dev mailing list. This the first step to announce
contributions. The newsgroup is more for user questions.
Tom
>> project.
>> plugin name is named for where it was destined, not where is is
>> committed yet. Let me know if this is ok for the proposal phase.
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Proposal to submit XViewer to eclipse.technology.nebula [message #509921 is a reply to message #62230] Mon, 25 January 2010 09:06 Go to previous messageGo to next message
the year is over - what's up with XViewer?
Thomas
Am 23.01.2009 09:33, schrieb Tom Schindl:
> Hi Don,
> Thanks
> Tom
>>> project.
Re: Proposal to submit XViewer to eclipse.technology.nebula [message #519778 is a reply to message #509921] Tue, 09 March 2010 17:19 Go to previous messageGo to next message
Thomas Paradies wrote:
> Thomas
>> Hi Don,
>> Thanks
>> Tom
>>>> project.
OSEE (www.eclipse.org/osee), XViewer's mother ship, has been working
hard toward 1.0.0, so XViewer committal to Nebula was put on hold. That
hold is over and XViewer is finally a member of Nebula.
http://www.eclipse.org/nebula/widgets/xviewer/xviewer.php
We're currently working through building issues, however source can be
obtained the nebula way through read-only anonymous CVS.
Re: Proposal to submit XViewer to eclipse.technology.nebula [message #520290 is a reply to message #519778] Thu, 11 March 2010 15:04 Go to previous messageGo to next message
Don,
sounds promising, thank you for answer. I'll have a look at it.
Thomas
>> Thomas
>>> Hi Don,
>>> Thanks
>>> Tom
>>>>> project.
Re: Proposal to submit XViewer to eclipse.technology.nebula [message #520297 is a reply to message #520290] Thu, 11 March 2010 15:24 Go to previous messageGo to next message
In the meantime Nicolas added the build and you can get nightly builds
from http://www.eclipse.org/nebula/downloads.php
Tom
Am 11.03.10 21:04, schrieb Thomas Paradies:
> Don,
> Thomas
>>> Hi,
>>> Thomas
>>>> Hi Don,
>>>> Thanks
>>>> Tom
>>>>>> project.
Re: Proposal to submit XViewer to eclipse.technology.nebula [message #522026 is a reply to message #520297] Fri, 19 March 2010 13:10 Go to previous messageGo to next message
Any chance of getting source through the update site?
Craig
Re: Proposal to submit XViewer to eclipse.technology.nebula [message #522027 is a reply to message #520297] Fri, 19 March 2010 13:11 Go to previous message
Would you consider the build you're publishing to be alpha or full releases? Has it been tested?
Craig
Re: Proposal to submit XViewer to eclipse.technology.nebula [message #593348 is a reply to message #62087] Thu, 22 January 2009 14:00 Go to previous message
> project.
Re: Proposal to submit XViewer to eclipse.technology.nebula [message #593395 is a reply to message #62111] Fri, 23 January 2009 03:33 Go to previous message
Hi Don,
Tom
>> project.
Re: Proposal to submit XViewer to eclipse.technology.nebula [message #598897 is a reply to message #62230] Mon, 25 January 2010 14:00 Go to previous message
Thomas
> Hi Don,
> Thanks
> Tom
>>> project.
Re: Proposal to submit XViewer to eclipse.technology.nebula [message #599215 is a reply to message #598897] Tue, 09 March 2010 17:19 Go to previous message
> Thomas
>> Hi Don,
>> Thanks
>> Tom
>>>> project.
Re: Proposal to submit XViewer to eclipse.technology.nebula [message #599218 is a reply to message #519778] Thu, 11 March 2010 15:04 Go to previous message
Don,
Thomas
>> Thomas
>>> Hi Don,
>>> Thanks
>>> Tom
>>>>> project.
Re: Proposal to submit XViewer to eclipse.technology.nebula [message #599226 is a reply to message #520290] Thu, 11 March 2010 15:24 Go to previous message
Tom
> Don,
> Thomas
>>> Hi,
>>> Thomas
>>>> Hi Don,
>>>> Thanks
>>>> Tom
>>>>>> project.
Re: Proposal to submit XViewer to eclipse.technology.nebula [message #599259 is a reply to message #520297] Fri, 19 March 2010 13:10 Go to previous message
Craig
Re: Proposal to submit XViewer to eclipse.technology.nebula [message #599266 is a reply to message #520297] Fri, 19 March 2010 13:11 Go to previous message
Craig
Previous Topic:About XView language pack
Next Topic:Set Cell Focus
Current Time: Tue Jul 22 17:51:56 EDT 2025
Powered by FUDForum. Page generated in 0.06216 seconds
