Home » Eclipse Projects » Mylyn » Can't close a bugzilla issue through Eclipse
Can't close a bugzilla issue through Eclipse [message #62056] Fri, 21 November 2008 19:10 Go to next message
Originally posted by: fake.phony_email_address.com
I'm using the Mylyn Bugzilla connector. When I pull up an issue on the
Tasks tab, I can enter comments, but I can't change the status of the
issue (to close it, resolve it, etc). When I change the status and click
Submit, the page submits and refreshes, but the status is unchanged.
This is very odd, because I can change the status using bugzilla's web
interface without a problem.
I'm using the same login for both interfaces, and my login has full
admin privileges. What could be wrong?
Re: Can't close a bugzilla issue through Eclipse [message #62128 is a reply to message #62056] Mon, 24 November 2008 19:40 Go to previous message
Originally posted by: rob.elves.eclipse.org
If using a Bugzilla server 3.2 release candidate, you could be seeing:
252297: Bugzilla 3.2 Changing the Status of a bug does not really change it.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=252297
....which is fixed in the latest weekly builds:
http://www.eclipse.org/mylyn/downloads/
If not, please submit a new bug report and we'll investigate further.
-Rob
Re: Can't close a bugzilla issue through Eclipse [message #594960 is a reply to message #62056] Mon, 24 November 2008 19:40 Go to previous message
-Rob
Previous Topic:Adding content assist to text fields
Next Topic:Move tasks to Trac connector
Current Time: Thu Jul 17 04:36:37 EDT 2025
Powered by FUDForum. Page generated in 0.06937 seconds
