Home » Eclipse Projects » Technology Project and PMC » Upgrade from eclipse 2.0 to eclipse 2.1
Upgrade from eclipse 2.0 to eclipse 2.1 [message #62046] Wed, 03 March 2004 01:43 Go to next message
Originally posted by: lizhih.cn.ibm.com
I have developed a plugin using the EMF 1.01 on WSADIE5.0 , when I try to
run it on WSADIE5.1 , it doesn't work .
I've check the plugins in WSADIE5.1 , under the plugin folder
:org.eclipse.ui.2.1.1,no workbench.jar exists , but we used a lot of this
jar file on WSADIE5.0 , how to solve this problem?
Have anybody met this problem before ? Thank you in advance!
Re: Upgrade from eclipse 2.0 to eclipse 2.1 [message #62143 is a reply to message #62046] Wed, 10 March 2004 07:02 Go to previous message
Originally posted by: daniel.megert.gmx.net
hellen wrote:
>Hi,
org.eclipse.ui has been splitted into several plug-ins. As long as your
project(s) reference org.eclipse.ui you will not have any problems.
However, if you directly reference JARs then this hits you. You find
workbench.jar in org.eclipse.ui.workbench.
Dani
Re: Upgrade from eclipse 2.0 to eclipse 2.1 [message #596865 is a reply to message #62046] Wed, 10 March 2004 07:02 Go to previous message
hellen wrote:
>Hi,
Dani
Previous Topic:Editor filenames pattern
Next Topic:link file in M7
Current Time: Sat Jul 26 00:52:17 EDT 2025
Powered by FUDForum. Page generated in 0.05858 seconds
