| VE and SWT [message #62037] |
Mon, 27 September 2004 20:40  |
Originally posted by: cchan.spikesource.com
Unable to create SWT Shell using Visual Editor.
I tried to create a SWT Shell from the palette and from the new Visual
Class dialog, niether of them allows me to create a shell so I can add
other contents like buttons, etc.
- Creating from palette allows be to select SWT Container Shell, drag a
rectangle into canvas, but nothing shows up.
- Creating from the initial dialog, SWT Application, generates some
code, but fails to load the control palette (its empty) and gives an
error that a Null pointer was discovered. Then it is stuck because
cannot layout any controls since there is nothing in the palette.
Does anyone know why? I'm using Eclipse 3.0.1 with VE 1.0.
Thanks in advanced.
- Chris
| Re: VE and SWT [message #62368 is a reply to message #62062] |
Tue, 28 September 2004 12:36  |
Originally posted by: mendelgili.netscape.net
Christopher Chan wrote:
> The error I get is
> "Error trying to set new file into editor"
> Reason:
> java.lang.NullPointerException
>> a rectangle into canvas, but nothing shows up.
>> Thanks in advanced.
>> - Chris
Please attach the .log file (in the .metadata directory of your workspace)
| Re: VE and SWT [message #599822 is a reply to message #62037] |
Mon, 27 September 2004 21:46  |
The error I get is
Reason:
> Thanks in advanced.
> - Chris
| Re: VE and SWT [message #599910 is a reply to message #62062] |
> The error I get is
> Reason:
>> Thanks in advanced.
>> - Chris
FUDForum. Page generated in 0.06338 seconds
