| Nesting classes in corresponding package [message #62006] |
Thu, 20 September 2007 03:51  |
I have two metamodels (uml and ecore).Can you please tell me
1) how do i assign classes in their respective package?I am trying to do
the transformation from uml to ecore using ATL.
If you want me to send the metamodels can you please tell me how do i
attach the same in this portal since i can't see any such feature?
Please reply at the earliest.
Swetha.
| Re: [ATL] Nesting classes in corresponding package [message #62100 is a reply to message #62030] |
Fri, 21 September 2007 15:18  |
Hi Swetha,
You may also want to have a look at the UML to MOF 1.4 transformation
available in the ATL transformation zoo:
http://www.eclipse.org/m2m/atl/atlTransformations/#UML2MOF
Regarding file attachments: I believe the portal is merely offered as a
convenience, which is limited in functionality. If you really want to
use all the powerful newsgroup functionalities, then you probably need
to get a news client (e.g., Thunderbird).
Frédéric Jouault
Freddy Allilaire wrote:
> Hi Swetha,
> The assignment of a class into its respective package will be done by
> the ATL Resolve Algorithm.
> I advise you to take a look to the following article/example (especially
> section 6):
> http://www.eclipse.org/m2m/atl/basicExamples_Patterns/Tree2L ist/
> Best regards,
> Freddy.
> Swetha a écrit :
>> do the transformation from uml to ecore using ATL.
>> Regards,
>> Swetha.
FUDForum. Page generated in 0.03898 seconds
