Home » Eclipse Projects » Eclipse Platform » ANT with JDK1.3 and additional tasks
ANT with JDK1.3 and additional tasks [message #61999] Wed, 04 June 2003 06:05 Go to next message
Hello all,
i'm starting eclipse with jdk1.3.1_07 and want to build my project with an
ant build. I'm using some additional tasks like AntDoc for which i add the
AntDoc.jar to the "additional classpath entries" of the ant preferences. I'm
setting the virtual machine as a start parameter of eclipse, so the
tools.jar is there in the runtime classpath.
If i start the build file (via right click "run ant) the following output is
created:
[taskdef] BUILD FAILED:
file:W:/WWSNG_MobilePOS/P3_Impl/Java/build/build_internal.xm l:336: taskdef
class org.ed.pack.ant.AntDoc cannot be found
The class is in the jar file i added ... the strange thing: if i'm starting
eclipse with jdk1.4 everthing works fine, but i need to compile the project
with jdk1.3 :(
any suggestions, solutions, hints ?
thanx in advance,
jochen
Re: ANT with JDK1.3 and additional tasks [message #62217 is a reply to message #61999] Wed, 04 June 2003 09:07 Go to previous messageGo to next message
Originally posted by: hcs33.egon.gyaloglo.hu
Did you also add the additional tasks to the Tasks page in Ant-->Runtime
preferences? If not, that might be the problem.
HTH,
Csaba
"Jochen Vogele" <vogele@media-saturn.com> wrote in message
news:bbkg40$iv0$1@rogue.oti.com...
> Hello all,
I'm
is
> created:
starting
project
> with jdk1.3 :(
> thanx in advance,
> jochen
Re: ANT with JDK1.3 and additional tasks [message #62288 is a reply to message #62217] Wed, 04 June 2003 09:57 Go to previous message
Hi Csaba,
that helped ....
thanx,
jochen
"Horv
Previous Topic:Skinnable Eclipse?
Next Topic:javadoc tags
Current Time: Thu Nov 20 12:19:29 EST 2025
Powered by FUDForum. Page generated in 0.03202 seconds
