Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » teneo - transient references are mapped to hibernate
teneo - transient references are mapped to hibernate [message #61976] Fri, 17 November 2006 20:09 Go to next message
Hi Martin,
I have a bidirectional association which is on both side transient, not volatile
and not changeable. In an XMI resource, the association is ignored, but they are
both mapped to hibernate by teneo, which creates an FK on the many side.
Is this a bug or a feature?
Reason why I'm asking: I'm using MySQL and would like to have the many side live
in a MyISAM table, which is faster and non-transactional, but can not hold an
FK. All other tables live in the InnoDB engine for transactional safety.
Andre
Re: teneo - transient references are mapped to hibernate [message #62001 is a reply to message #61976] Sat, 18 November 2006 00:04 Go to previous message
Hi Andre,
For bi-directional cases the transient attribute is ignored if the other side is a containment
relation (see processEFeature method in DefaultAnnotator). Does this apply to your situation?
In this case the system should check that the eopposite is also transient and if so tag it as transient.
Can you enter a bugzilla for this (if this applies to you)?
Btw, if the efeature is volatile then it is ignored also (without checking the other side).
gr. Martin
Andre Pareis wrote:
> Hi Martin,
> volatile and not changeable. In an XMI resource, the association is
> ignored, but they are both mapped to hibernate by teneo, which creates
> side live in a MyISAM table, which is faster and non-transactional, but
> can not hold an FK. All other tables live in the InnoDB engine for
> Regards
> Andre
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: teneo - transient references are mapped to hibernate [message #595877 is a reply to message #61976] Sat, 18 November 2006 00:04 Go to previous message
Hi Andre,
gr. Martin
Andre Pareis wrote:
> Hi Martin,
> Regards
> Andre
The Netherlands
Previous Topic:teneo - transient references are mapped to hibernate
Next Topic:Teneo: HibernateResource is not smart enough
Current Time: Thu Jul 17 03:22:36 EDT 2025
Powered by FUDForum. Page generated in 0.06097 seconds
