Crash on Redhat 9.0 [message #61952] |
Wed, 04 June 2003 04:30  |
Originally posted by: mrf.inxnet.de
Eclipse always crashes after sometime with the following error.
Redhat 9.0, 512MB Ram, 1.8Ghz PIV
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : 11 occurred at PC=0x4D697020
Function=(null)+0x4D697020
Library=/usr/lib/libgdk-x11-2.0.so.0
NOTE: We are unable to locate the function name symbol for the error
just occurred. Please refer to release documentation for possible
reason and solutions.
Current Java thread:
at org.eclipse.swt.internal.gtk.OS.gtk_main_iteration(Native
Method)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1428)
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1402)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1385)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:845)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Dynamic libraries:
08048000-0804e000 r-xp 00000000 03:03 717699
/usr/java/j2sdk1.4.1_02/bin/java
0804e000-0804f000 rw-p 00005000 03:03 717699
40000000-40015000 r-xp 00000000 03:03 1726542 /lib/ld-2.3.2.so
40015000-40016000 rw-p 00014000 03:03 1726542 /lib/ld-2.3.2.so
40017000-40020000 r-xp 00000000 03:03 407943
/usr/java/j2sdk1.4.1_02/jre/lib/i386/native_threads/libhpi.s o
40020000-40021000 rw-p 00008000 03:03 407943
40022000-40025000 r--s 00000000 03:03 1564501
/usr/java/j2sdk1.4.1_02/jre/lib/ext/dnsns.jar
40025000-4002a000 r--s 00000000 03:03 668829
/home/mrf/eclipse/startup.jar
4002a000-40035000 r-xp 00000000 03:03 1954590 /lib/tls/libpthread-0.34.so
40035000-40036000 rw-p 0000a000 03:03 1954590 /lib/tls/libpthread-0.34.so
40038000-4003b000 r-xp 00000000 03:03 1726559 /lib/libdl-2.3.2.so
4003b000-4003c000 rw-p 00002000 03:03 1726559 /lib/libdl-2.3.2.so
4003d000-40355000 r-xp 00000000 03:03 1222465
/usr/java/j2sdk1.4.1_02/jre/lib/i386/client/libjvm.so
40355000-40539000 rw-p 00317000 03:03 1222465
4054a000-4055c000 r-xp 00000000 03:03 1726563 /lib/libnsl-2.3.2.so
4055c000-4055d000 rw-p 00011000 03:03 1726563 /lib/libnsl-2.3.2.so
4055f000-40580000 r-xp 00000000 03:03 1954588 /lib/tls/libm-2.3.2.so
40580000-40581000 rw-p 00020000 03:03 1954588 /lib/tls/libm-2.3.2.so
40581000-40591000 r-xp 00000000 03:03 522031
/usr/java/j2sdk1.4.1_02/jre/lib/i386/libverify.so
40591000-40593000 rw-p 0000f000 03:03 522031
40593000-405b4000 r-xp 00000000 03:03 522019
/usr/java/j2sdk1.4.1_02/jre/lib/i386/libjava.so
405b4000-405b6000 rw-p 00020000 03:03 522019
405b6000-405cb000 r-xp 00000000 03:03 522032
/usr/java/j2sdk1.4.1_02/jre/lib/i386/libzip.so
405cb000-405cd000 rw-p 00014000 03:03 522032
405cd000-41c9c000 r--s 00000000 03:03 701432
/usr/java/j2sdk1.4.1_02/jre/lib/rt.jar
41cdf000-41cf6000 r--s 00000000 03:03 701433
/usr/java/j2sdk1.4.1_02/jre/lib/sunrsasign.jar
41cf6000-41d67000 r--s 00000000 03:03 701426
/usr/java/j2sdk1.4.1_02/jre/lib/jsse.jar
41d67000-41d7a000 r--s 00000000 03:03 701425
/usr/java/j2sdk1.4.1_02/jre/lib/jce.jar
41fa4000-41fb2000 r--s 00000000 03:03 1564502
/usr/java/j2sdk1.4.1_02/jre/lib/ext/ldapsec.jar
41fb2000-41fb3000 r--s 00000000 03:03 179792
/home/mrf/eclipse/plugins/org.eclipse.ui_2.1.0/ui.jar
41fb3000-41fb4000 r-xp 00000000 03:03 1222415
/home/mrf/eclipse/plugins/org.eclipse.core.resources.linux_2 .1.0/os/linux/x86/libcore_2_1_0a.so
41fb4000-41fb5000 rw-p 00001000 03:03 1222415
41fb5000-41fb6000 r-xp 00000000 03:03 814487
/usr/X11R6/lib/X11/locale/lib/common/xlcUTF8Load.so.2
41fb6000-41fb7000 rw-p 00000000 03:03 814487
41fb7000-41fc2000 r-xp 00000000 03:03 1726569 /lib/libnss_files-2.3.2.so
41fc2000-41fc3000 rw-p 0000a000 03:03 1726569 /lib/libnss_files-2.3.2.so
41fc3000-41fe0000 r--s 00000000 03:03 1564504
/usr/java/j2sdk1.4.1_02/jre/lib/ext/sunjce_provider.jar
41fe0000-41ff8000 r--s 00000000 03:03 1678656
/home/mrf/eclipse/plugins/org.eclipse.core.boot_2.1.0/boot.j ar
41ff8000-41fff000 r--s 00000000 03:03 407890
/home/mrf/eclipse/plugins/org.eclipse.swt.gtk_2.1.0/ws/gtk/s wt-pi.jar
42000000-4212f000 r-xp 00000000 03:03 1954579 /lib/tls/libc-2.3.2.so
4212f000-42132000 rw-p 0012f000 03:03 1954579 /lib/tls/libc-2.3.2.so
42134000-423f0000 r--s 00000000 03:03 701411
/usr/java/j2sdk1.4.1_02/jre/lib/charsets.jar
4c471000-4c671000 r--p 00000000 03:03 472779
/usr/lib/locale/locale-archive
4c875000-4c914000 r--s 00000000 03:03 1564503
/usr/java/j2sdk1.4.1_02/jre/lib/ext/localedata.jar
4c995000-4c9ca000 r--s 00000000 03:03 1499488
/home/mrf/eclipse/plugins/org.eclipse.core.runtime_2.1.0/run time.jar
4c9ca000-4ca19000 r--s 00000000 03:03 1434130
/home/mrf/eclipse/plugins/org.eclipse.ui.views_2.1.0/views.j ar
4ca19000-4cc30000 r--s 00000000 03:03 1059714
/home/mrf/eclipse/plugins/org.eclipse.ui.workbench_2.1.0/wor kbench.jar
4cc30000-4cc9c000 r--s 00000000 03:03 1890253
/home/mrf/eclipse/plugins/org.eclipse.jface_2.1.0/jface.jar
4cc9c000-4cd4d000 r--s 00000000 03:03 407891
/home/mrf/eclipse/plugins/org.eclipse.swt.gtk_2.1.0/ws/gtk/s wt.jar
4cd4d000-4cdda000 r--s 00000000 03:03 2150604
/home/mrf/eclipse/plugins/org.eclipse.core.resources_2.1.0/r esources.jar
4cdda000-4cdf0000 r--s 00000000 03:03 1173729
/home/mrf/eclipse/plugins/org.apache.xerces_4.0.7/xmlParserA PIs.jar
4cdf0000-4cf0f000 r--s 00000000 03:03 1173731
/home/mrf/eclipse/plugins/org.apache.xerces_4.0.7/xercesImpl .jar
4cf0f000-4cf76000 r--s 00000000 03:03 1873914
/home/mrf/eclipse/plugins/org.eclipse.team.cvs.core_2.1.0/cv s.jar
4cf76000-4cffd000 r--s 00000000 03:03 489913
/home/mrf/eclipse/plugins/dbedit.ui_0.9.9/dbedit.jar
4cffd000-4d007000 r--s 00000000 03:03 945841
/home/mrf/eclipse/plugins/dbedit.ui_0.9.9/lib/parser.jar
4d007000-4d03a000 r--s 00000000 03:03 1629558
/home/mrf/eclipse/plugins/org.eclipse.search_2.1.0/search.ja r
4d03a000-4d048000 r--s 00000000 03:03 1873951
/home/mrf/eclipse/plugins/org.eclipse.pde_2.1.0/pde.jar
4d048000-4d2a1000 r--s 00000000 03:03 1450239
/home/mrf/eclipse/plugins/org.eclipse.jdt.core_2.1.0/jdtcore .jar
4d2a1000-4d2e1000 r--s 00000000 03:03 1629582
/home/mrf/eclipse/plugins/org.eclipse.jdt.junit_2.1.0/junits upport.jar
4d2e1000-4d2f7000 r--s 00000000 03:03 2069447
/home/mrf/eclipse/plugins/org.eclipse.help.ui_2.1.0/helpwork bench.jar
4d2f7000-4d358000 r--s 00000000 03:03 994546
/home/mrf/eclipse/plugins/org.eclipse.compare_2.1.0/compare. jar
4d358000-4d382000 r-xp 00000000 03:03 2150618
/home/mrf/eclipse/plugins/org.eclipse.swt.gtk_2.1.0/os/linux /x86/libswt-pi-gtk-2133.so
4d382000-4d384000 rw-p 00029000 03:03 2150618
4d384000-4d38a000 r--s 00000000 03:03 1905909
/usr/lib/gconv/gconv-modules.cache
4d38a000-4d396000 r-xp 00000000 03:03 1564106
/usr/lib/gtk-2.0/2.2.0/engines/libbluecurve.so
4d396000-4d397000 rw-p 0000b000 03:03 1564106
4d397000-4d39b000 r-xp 00000000 03:03 358398
/usr/lib/libgthread-2.0.so.0.200.1
4d39b000-4d39c000 rw-p 00003000 03:03 358398
4d39c000-4d405000 r-xp 00000000 03:03 358392
/usr/lib/libglib-2.0.so.0.200.1
4d405000-4d406000 rw-p 00069000 03:03 358392
4d406000-4d64f000 r-xp 00000000 03:03 358601
/usr/lib/libgtk-x11-2.0.so.0.200.1
4d64f000-4d658000 rw-p 00248000 03:03 358601
4d65a000-4d6c3000 r-xp 00000000 03:03 358595
/usr/lib/libgdk-x11-2.0.so.0.200.1
4d6c3000-4d6c8000 rw-p 00069000 03:03 358595
4d6c8000-4d6df000 r-xp 00000000 03:03 358563
/usr/lib/libatk-1.0.so.0.200.0
4d6df000-4d6e1000 rw-p 00016000 03:03 358563
4d6e1000-4d6f3000 r-xp 00000000 03:03 358597
/usr/lib/libgdk_pixbuf-2.0.so.0.200.1
4d6f3000-4d6f4000 rw-p 00011000 03:03 358597
4d6f4000-4d700000 r-xp 00000000 03:03 358591
/usr/lib/libpangox-1.0.so.0.200.1
4d700000-4d701000 rw-p 0000b000 03:03 358591
4d701000-4d728000 r-xp 00000000 03:03 358587
/usr/lib/libpango-1.0.so.0.200.1
4d728000-4d734000 rw-p 00026000 03:03 358587
4d734000-4d767000 r-xp 00000000 03:03 358396
/usr/lib/libgobject-2.0.so.0.200.1
4d767000-4d769000 rw-p 00032000 03:03 358396
4d769000-4d76c000 r-xp 00000000 03:03 358394
/usr/lib/libgmodule-2.0.so.0.200.1
4d76c000-4d76d000 rw-p 00002000 03:03 358394
4d76d000-4d78d000 r-xp 00000000 03:03 358593
/usr/lib/libpangoxft-1.0.so.0.200.1
4d78d000-4d78e000 rw-p 0001f000 03:03 358593
4d78e000-4d791000 r-xp 00000000 03:03 1108053
/usr/X11R6/lib/libXrandr.so.2.0
4d791000-4d792000 rw-p 00002000 03:03 1108053
4d792000-4d799000 r-xp 00000000 03:03 1108043 /usr/X11R6/lib/libXi.so.6.0
4d799000-4d79a000 rw-p 00006000 03:03 1108043 /usr/X11R6/lib/libXi.so.6.0
4d79a000-4d7a7000 r-xp 00000000 03:03 1108035
/usr/X11R6/lib/libXext.so.6.4
4d7a7000-4d7a8000 rw-p 0000c000 03:03 1108035
4d7a8000-4d7b9000 r-xp 00000000 03:03 1108041
/usr/X11R6/lib/libXft.so.2.1
4d7b9000-4d7ba000 rw-p 00010000 03:03 1108041
4d7ba000-4d7c1000 r-xp 00000000 03:03 1108055
/usr/X11R6/lib/libXrender.so.1.2
4d7c1000-4d7c2000 rw-p 00006000 03:03 1108055
4d7c2000-4d7e3000 r-xp 00000000 03:03 358510
/usr/lib/libfontconfig.so.1.0
4d7e3000-4d7e6000 rw-p 00021000 03:03 358510
4d7e7000-4d8c3000 r-xp 00000000 03:03 1108025
/usr/X11R6/lib/libX11.so.6.2
4d8c3000-4d8c6000 rw-p 000db000 03:03 1108025
4d8c6000-4d912000 r-xp 00000000 03:03 358506
/usr/lib/libfreetype.so.6.3.2
4d912000-4d916000 rw-p 0004c000 03:03 358506
4d917000-4d935000 r-xp 00000000 03:03 358382 /usr/lib/libexpat.so.0.4.0
4d935000-4d937000 rw-p 0001e000 03:03 358382 /usr/lib/libexpat.so.0.4.0
4d937000-4d951000 r--p 00000000 03:03 733079
/usr/share/locale/de/LC_MESSAGES/gtk20.mo
4d951000-4d976000 r-xp 00000000 03:03 2150619
/home/mrf/eclipse/plugins/org.eclipse.swt.gtk_2.1.0/os/linux /x86/libswt-gtk-2133.so
4d976000-4d978000 rw-p 00025000 03:03 2150619
4d978000-4d98e000 r--p 00000000 03:03 732972
/usr/share/locale/de/LC_MESSAGES/libc.mo
4d98e000-4d98f000 r-xp 00000000 03:03 1905852 /usr/lib/gconv/ISO8859-1.so
4d98f000-4d990000 rw-p 00001000 03:03 1905852 /usr/lib/gconv/ISO8859-1.so
4d990000-4d9a2000 r--s 00000000 03:03 1304013
/home/mrf/eclipse/plugins/org.eclipse.text_2.1.0/text.jar
4d9a3000-4d9ab000 r-xp 00000000 03:03 1108033
/usr/X11R6/lib/libXcursor.so.1.0
4d9ab000-4d9ac000 rw-p 00007000 03:03 1108033
4d9ac000-4d9fe000 r--s 00000000 03:03 1938954
/home/mrf/eclipse/plugins/org.eclipse.update.core_2.1.0/upda tecore.jar
4d9fe000-4da2b000 r--s 00000000 03:03 1841543
/home/mrf/eclipse/plugins/org.eclipse.help_2.1.0/help.jar
4da2b000-4da81000 r--s 00000000 03:03 1189725
/home/mrf/eclipse/plugins/org.eclipse.jface.text_2.1.0/jface text.jar
4da81000-4dafb000 r--s 00000000 03:03 619873
/home/mrf/eclipse/plugins/org.eclipse.debug.ui_2.1.0/dtui.ja r
4dafb000-4dec8000 r--s 00000000 03:03 994588
/home/mrf/eclipse/plugins/org.eclipse.jdt.ui_2.1.0/jdt.jar
4dec8000-4df96000 r--s 00000000 03:03 1613513
/home/mrf/eclipse/plugins/org.eclipse.team.cvs.ui_2.1.0/team cvsui.jar
4df96000-4e127000 r--s 00000000 03:03 1939019
/home/mrf/eclipse/plugins/org.eclipse.pde.ui_2.1.0/pdeui.jar
4e127000-4e1c3000 r--s 00000000 03:03 81922
/home/mrf/eclipse/plugins/org.eclipse.update.ui_2.1.0/update ui.jar
4e1c3000-4e282000 r--s 00000000 03:03 1059738
/home/mrf/eclipse/plugins/org.eclipse.jdt.debug.ui_2.1.0/jdi ui.jar
4e282000-4e34e000 r--s 00000000 03:03 1255007
/home/mrf/eclipse/plugins/org.eclipse.ui.externaltools_2.1.0 /externaltools.jar
4e34e000-4e355000 r--s 00000000 03:03 1841526
/home/mrf/eclipse/plugins/org.eclipse.ant.core_2.1.0/antsupp ort.jar
4e355000-4e36c000 r--s 00000000 03:03 407853
/home/mrf/eclipse/plugins/org.eclipse.team.core_2.1.0/team.j ar
4e36c000-4e386000 r--s 00000000 03:03 407859
/home/mrf/eclipse/plugins/org.eclipse.ui.editors_2.1.0/edito rs.jar
4e386000-4e388000 r-xp 00000000 03:03 1189129
/usr/lib/pango/1.2.0/modules/pango-basic-xft.so
4e388000-4e389000 rw-p 00001000 03:03 1189129
4e389000-4e39b000 r--p 00000000 03:03 228325
/usr/X11R6/lib/X11/fonts/Type1/l048013t.pfa
4e41c000-4e454000 r--s 00000000 03:03 2085858
/home/mrf/eclipse/plugins/org.eclipse.ui.workbench.textedito r_2.1.0/texteditor.jar
4e454000-4e472000 r--s 00000000 03:03 619841
/home/mrf/eclipse/plugins/org.eclipse.debug.core_2.1.0/dtcor e.jar
4e472000-4e47e000 r--s 00000000 03:03 1092300
/home/mrf/eclipse/plugins/org.eclipse.jdt.debug_2.1.0/jdi.ja r
4e47e000-4e51e000 r--s 00000000 03:03 1092301
/home/mrf/eclipse/plugins/org.eclipse.jdt.debug_2.1.0/jdimod el.jar
4e51e000-4e542000 r--s 00000000 03:03 766516
/home/mrf/eclipse/plugins/org.eclipse.jdt.launching_2.1.0/la unching.jar
4e542000-4e552000 r--s 00000000 03:03 945570
/home/mrf/eclipse/plugins/org.eclipse.pde.runtime_2.1.0/pder t.jar
4e552000-4e599000 r--s 00000000 03:03 1222406
/home/mrf/eclipse/plugins/org.eclipse.team.ui_2.1.0/teamui.j ar
4e599000-4e5ab000 r--p 00000000 03:03 228327
/usr/X11R6/lib/X11/fonts/Type1/l048016t.pfa
4e72e000-4e72f000 r-xp 00000000 03:03 2150617
/home/mrf/eclipse/plugins/org.eclipse.swt.gtk_2.1.0/os/linux /x86/libswt-gnome-gtk-2133.so
4e72f000-4e730000 rw-p 00001000 03:03 2150617
4e730000-4e73c000 r--s 00000000 03:03 1776386
/home/mrf/eclipse/plugins/org.eclipse.team.cvs.ssh_2.1.0/tea mcvsssh.jar
4e743000-4e77a000 r-xp 00000000 03:03 358605
/usr/lib/libgnomevfs-2.so.0.0.0
4e77a000-4e77c000 rw-p 00036000 03:03 358605
4e77c000-4e78d000 r-xp 00000000 03:03 358583
/usr/lib/libbonobo-activation.so.4.0.0
4e78d000-4e78f000 rw-p 00011000 03:03 358583
4e78f000-4e7c8000 r-xp 00000000 03:03 358579
/usr/lib/libORBit-2.so.0.0.0
4e7c8000-4e7d1000 rw-p 00038000 03:03 358579
4e7d1000-4e8b0000 r-xp 00000000 03:03 358519 /usr/lib/libxml2.so.2.5.4
4e8b0000-4e8bb000 rw-p 000de000 03:03 358519 /usr/lib/libxml2.so.2.5.4
4e8bc000-4e8c8000 r-xp 00000000 03:03 358426 /usr/lib/libz.so.1.1.4
4e8c8000-4e8ca000 rw-p 0000b000 03:03 358426 /usr/lib/libz.so.1.1.4
4e8ca000-4e8d1000 r-xp 00000000 03:03 358577 /usr/lib/liblinc.so.1.0.0
4e8d1000-4e8d2000 rw-p 00006000 03:03 358577 /usr/lib/liblinc.so.1.0.0
4e8d2000-4e905000 r-xp 00000000 03:03 358603
/usr/lib/libgconf-2.so.4.1.0
4e905000-4e908000 rw-p 00033000 03:03 358603
4e908000-4e93a000 r-xp 00000000 03:03 1726946 /lib/libssl.so.0.9.7a
4e93a000-4e93d000 rw-p 00032000 03:03 1726946 /lib/libssl.so.0.9.7a
4e93d000-4ea19000 r-xp 00000000 03:03 1726587 /lib/libcrypto.so.0.9.7a
4ea19000-4ea2b000 rw-p 000db000 03:03 1726587 /lib/libcrypto.so.0.9.7a
4ea2e000-4ea34000 r-xp 00000000 03:03 1954592 /lib/tls/librt-2.3.2.so
4ea34000-4ea36000 rw-p 00005000 03:03 1954592 /lib/tls/librt-2.3.2.so
4ea40000-4ea47000 r-xp 00000000 03:03 358409 /usr/lib/libpopt.so.0.0.0
4ea47000-4ea48000 rw-p 00006000 03:03 358409 /usr/lib/libpopt.so.0.0.0
4ea48000-4ea57000 r-xp 00000000 03:03 1726579 /lib/libresolv-2.3.2.so
4ea57000-4ea58000 rw-p 0000f000 03:03 1726579 /lib/libresolv-2.3.2.so
4ea5a000-4ea6c000 r-xp 00000000 03:03 1645144
/usr/kerberos/lib/libgssapi_krb5.so.2.2
4ea6c000-4ea6d000 rw-p 00011000 03:03 1645144
4ea6d000-4eac9000 r-xp 00000000 03:03 1645158
/usr/kerberos/lib/libkrb5.so.3.1
4eac9000-4eacb000 rw-p 0005c000 03:03 1645158
4eacb000-4eada000 r-xp 00000000 03:03 1645148
/usr/kerberos/lib/libk5crypto.so.3.0
4eada000-4eadb000 rw-p 0000f000 03:03 1645148
4eadb000-4eadc000 r-xp 00000000 03:03 1645138
/usr/kerberos/lib/libcom_err.so.3.0
4eadc000-4eadd000 rw-p 00001000 03:03 1645138
4ed62000-4ed72000 r-xp 00000000 03:03 522028
/usr/java/j2sdk1.4.1_02/jre/lib/i386/libnet.so
4ed72000-4ed74000 rw-p 0000f000 03:03 522028
Local Time = Wed Jun 4 09:36:35 2003
Elapsed Time = 2385
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot(TM) Client VM (1.4.1_02-b06 mixed mode)
# An error report file has been saved as hs_err_pid22812.log.
# Please refer to the file for further information.
Re: Crash on Redhat 9.0 [message #62656 is a reply to message #62121] |
Wed, 04 June 2003 13:11   |
It seems like you are lacking some libs. Not sure why SUSE would be,
but I would recommend doing a find/locate to see if you can determine
where "libc.so.4" is.
Then do either a "setenv LD_LIBRARY_PATH $LD_LIBRARY_PATH:/newdir" to
point to the lib ( either at the command line or add it to your shell
script", or add it to your /etc/ld.so.conf ( as root ).
The other problem with RH9 is that they added "Native Posix Threading
Libraies", so you might try recompliling but passing a "--with-ntpl" to
the configure script.
As for cygwin, I would be real surprised if they supported Eclipse. But
twm is not to blame. I have used it succesfully, although I usually
only use Enlightenment.
You might try just using your SuSe box directly instead of over ssh.
Jan-Peter Voigt wrote:
> Hello Michael,
> I got a quite similar message on SuSe 8.1 (see below) - I also use the
> GTK Version of eclipse.
> To start eclipse on the Linux-machine, first I connected via ssh from my
> Powerbook
> running Apple's X11.app. This X-Server always runs in rootless mode.
> -> eclipse crashes with the message below.
> After that, I started X11 in the cygwin environment of my office NT-
> machine via 'startx', wich runs this ugly twm WindowManager in an own
> window.
> -> eclipse is starting this way.
> But when I start the cygwin X11 with the 'startxwin.bat' - it starts a
> rootless Windows-WindowManager - eclipse also fails.
> I am quite new to this eclipse stuff and don't know too much about the
> swt architecture, but maybe there is a problem with gtk on Linux and
> rootless Window Managers.
> Regards, Jan-Peter.
Re: Crash on Redhat 9.0 [message #68878 is a reply to message #61952] |
Tue, 10 June 2003 04:06  |
> Method)
> at
> at
> at
> at
> at
> Dynamic libraries:
> 40025000-4002a000 r--s 00000000 03:03 668829 /home/mrf/eclipse/startup.jar
> 4c471000-4c671000 r--p 00000000 03:03 472779 /usr/lib/locale/locale-archive
> 4d6c8000-4d6df000 r-xp 00000000 03:03 358563 /usr/lib/libatk-1.0.so.0.200.0
> 4d6df000-4d6e1000 rw-p 00016000 03:03 358563 /usr/lib/libatk-1.0.so.0.200.0
> 4d79a000-4d7a7000 r-xp 00000000 03:03 1108035 /usr/X11R6/lib/libXext.so.6.4
> 4d7a7000-4d7a8000 rw-p 0000c000 03:03 1108035 /usr/X11R6/lib/libXext.so.6.4
> 4d7a8000-4d7b9000 r-xp 00000000 03:03 1108041 /usr/X11R6/lib/libXft.so.2.1
> 4d7b9000-4d7ba000 rw-p 00010000 03:03 1108041 /usr/X11R6/lib/libXft.so.2.1
> 4d7c2000-4d7e3000 r-xp 00000000 03:03 358510 /usr/lib/libfontconfig.so.1.0
> 4d7e3000-4d7e6000 rw-p 00021000 03:03 358510 /usr/lib/libfontconfig.so.1.0
> 4d7e7000-4d8c3000 r-xp 00000000 03:03 1108025 /usr/X11R6/lib/libX11.so.6.2
> 4d8c3000-4d8c6000 rw-p 000db000 03:03 1108025 /usr/X11R6/lib/libX11.so.6.2
> 4d8c6000-4d912000 r-xp 00000000 03:03 358506 /usr/lib/libfreetype.so.6.3.2
> 4d912000-4d916000 rw-p 0004c000 03:03 358506 /usr/lib/libfreetype.so.6.3.2
> 4e78f000-4e7c8000 r-xp 00000000 03:03 358579 /usr/lib/libORBit-2.so.0.0.0
> 4e7c8000-4e7d1000 rw-p 00038000 03:03 358579 /usr/lib/libORBit-2.so.0.0.0
> 4e8d2000-4e905000 r-xp 00000000 03:03 358603 /usr/lib/libgconf-2.so.4.1.0
> 4e905000-4e908000 rw-p 00033000 03:03 358603 /usr/lib/libgconf-2.so.4.1.0
> Elapsed Time = 2385
I remember something similar...
....I'm not sure, but maybe I fixed the problem exporting
LD_ASSUME_KERNEL=2.2.5 before invoking eclipse.
Let me know if this solves your problem.
C.
FUDForum. Page generated in 0.04984 seconds
