Displaying classes [message #61950] |
Mon, 03 December 2007 03:19  |
Originally posted by: news_post.jimmo.com
I installed pdt-all-in-one-1.0-R20070917 and loaded a PHP containing all of
my classes. In the left column of the IDE is there is a tab "PHP Project
Outline". It contains the entries Constants, Classes, Functions. Clicking
on them does nothing. I googled some references to the IDE and the way I
understand it is that these should show you the Constants, Classes, and
Functions in the current file. If not, what is the purpose of this? If so,
what do I need to do to active this functionality? Thanks for any help.
Jim Mohr
Re: Displaying classes [message #62162 is a reply to message #62114] |
Wed, 05 December 2007 18:45  |
Originally posted by: dcarver.starstandard.org
>> What do you mean by "loaded a PHP"? Did you create a PHP Project? Are
>> your files contained in this project?
> Oops. I loaded a PHP file containing all of my classes.
As was stated earlier. Make sure you have your classes in a PHP Project.
You can create a PHP Project by going to File->New->Project, select
the PHP Category, and select the PHP Project. Follow the wizard from
there.
Once the Project is created, make sure you copy all your PHP related
files including the appropriate directory structures into the new PHP
Project. You should also be using the PHP Explorer view and PHP
Perspective when working with the files. But the most important thing
is making sure you have the files in a PHP Project, otherwise some of
the functionality won't be available.
Dave
FUDForum. Page generated in 0.03431 seconds
