Home » Archived » Test and Performance Tools Platform (TPTP) » Widget Resolver problem
Widget Resolver problem [message #61899] Wed, 29 March 2006 07:06 Go to next message
Originally posted by: mvjaibharatreddy.yahoo.com
Hi all,
I have problem to understand widget revolver:
How AGR generates the unique identifier?. ( Example : Button#2).
what i am feeling:
It is getData property of the button.
Please correct me.
Thanks in advance.
Jai
Re: Widget Resolver problem [message #62319 is a reply to message #61899] Wed, 29 March 2006 12:25 Go to previous messageGo to next message
The recorder will first request the registered widget resolvers to resolve
the widget in question. If that fails, then the recorder will attempt to
use a primitive resolving mechanism to resolve the widget.
The adaptive widget resolver for example uses a xml file to resolve widgets.
Consider its entry for buttons:
<class name = "org.eclipse.swt.widgets.Button" matchThreshold = "1.0">
<method name = "getData" weight = "1.0"/>
</class>
In the case of buttons, if the value returned by getData happens to be null,
then the recorder will attempt to resolve the button using its index
relative to the composite that contains it. If a composite contains two
buttons, then the first button is resolved as Button#1 and the second button
is resolved as Button#2.
It's strongly recommended for users to define a well-established widget
resolver or contribute entries under the widgetReg.xml file before creating
test cases.
See the user guide for more details.
"Jai9999" <mvjaibharatreddy@yahoo.com> wrote in message
news:e0dt95$cd8$1@utils.eclipse.org...
> Hi all,
> what i am feeling:
> Please correct me.
> Thanks in advance.
> Jai
Re: Widget Resolver problem [message #62606 is a reply to message #62319] Thu, 30 March 2006 06:01 Go to previous message
Hi ali,
Thank you for the suggestion. It clears my understanding.
One more question on macro syntax :
I see different macro syntax for different setData() key property.
1.
In pulg-in code:
button.setData("tptp.persistance.id", "select_button");
Adaptive widget resolver:
<method name = "getData" weight = "1.0">
<argument value = "key"/>
</method>
</class>
Result macro :
<command type="select" contextId="editor/com.xxx"
widgetId=" org.eclipse.swt.widgets.Button#{{select_button}}-{{1.0}}{{se lect_button}}-{{1.0}} "/>
2.
In pulg-in code:
button.setData("key", "select_button");
<method name = "key" weight = "1.0">
</method>
</class>
Result macro:
widgetId="org.eclipse.swt.widgets.Button#{{select_button}}-{{1.0}} "/>
Can any one explain me why the Result macro is different ( widget
identification )?.
Thanks for any insight.
Jai
Button
"Ali Mehregani" <amehrega@ca.ibm.com> wrote in message
news:e0eftt$qbd$1@utils.eclipse.org...
> widgets.
> </class>
> null,
> button
> creating
> test cases.
>> Hi all,
>> what i am feeling:
>> Please correct me.
>> Thanks in advance.
>> Jai
Previous Topic:Where is the memory usage?
Next Topic:Different variations of a rule without killing perf?
Current Time: Sat Nov 08 16:01:55 EST 2025
Powered by FUDForum. Page generated in 0.02905 seconds
