Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Calling Java methods
[Acceleo] Calling Java methods [message #61819] |
Tue, 26 May 2009 16:50  |
Originally posted by: no.email.com
Salut to the team Acceleo,
I'd like to call java code in Acceleo, is it possible?
I have an old generator made in Java and I'm trying to update it by
converting some parts to MTL but I'd like to keep other parts in Java,
like complex queries to retrieve / filter / sort some model elements,
and call them from MTL templates.
Jeremy
Re: [Acceleo] Calling Java methods [message #62052 is a reply to message #61866] |
Thu, 28 May 2009 13:52   |
It is coming soon...
The engine is ready but not the compiler...
We've finally planned to do that after the galileo release
But stephane is right ;-)
Perhaps OCL can fit your need, you can make queries...
At the moment, there is a way to pass Java arguments to the code generator :
(I'm not sure to help you with this solution)
You can modify the generated Java class (code generation entry point
@main) and give the instance of your Java Class as an argument of the
code generation
Jonathan
Stéphane Bouchet a écrit :
> hi Jeremy,
> Java services in Acceleo is not possible yet.
> We ( EEF team ) use Acceleo for a while and didn't have any specials
> needs for a java service for now.
> OCL can't fit your needs ?
> Cheers,
> Stéphane
>> Thanks,
>> Jeremy
Re: [Acceleo] Calling Java methods [message #62075 is a reply to message #62052] |
Thu, 28 May 2009 16:43   |
Thanks for your answers.
I know I could do what I want in OCL but, hmm, I'm lazy :).
By the way, is the code of your future unfinished version available on a
public repository? I'd be glad to look at the code to see the new
features if that was possible or even contribute some parts.
> generator :
> code generation
> Cheers,
> Jonathan
>> hi Jeremy,
>> Cheers,
>> Stéphane
>>> Java, like complex queries to retrieve / filter / sort some model
>>> elements, and call them from MTL templates.
>>> Thanks,
>>> Jeremy
Re: [Acceleo] Calling Java methods [message #62147 is a reply to message #62075] |
Fri, 29 May 2009 12:15   |
Thank you,
I'll be happy to have such a contribution ;-)
The Eclipse Acceleo code is available at :
CVS host : dev.eclipse.org
Repository : /cvsroot/modeling/org.eclipse.m2t/org.eclipse.acceleo
You can checkout all the org.eclipse.acceleo* plugins and features...
(Eclipse Galileo)
You have to define a way in the parser to store the dynamic Java
services as new OCL services
The class OCLParser is a good entry point because I think that you'll
have to register Java Classes like the templates and the queries
Other important classes for this task are AcceleoWorkspaceUtil (common),
and AcceleoEnvironment (parser)...
Let me know when you have problem, and good luck ;-)
Jonathan
>> generator :
>> code generation
>> Cheers,
>> Jonathan
>>> hi Jeremy,
>>> Cheers,
>>> Stéphane
>>>> Thanks,
>>>> Jeremy
Re: [Acceleo] Calling Java methods [message #62171 is a reply to message #62147] |
Fri, 29 May 2009 20:09   |
Originally posted by: nomail.email.com
I must admit I don't have the time to really understand the code of
Acceleo and to be able to add the Java service call.
I'll try to contribute another time.
Sorry for the bother,
Jeremy
> Thank you,
> (Eclipse Galileo)
> Cheers,
> Jonathan
>> a public repository? I'd be glad to look at the code to see the new
>>> generator :
>>> code generation
>>> Cheers,
>>> Jonathan
>>>> hi Jeremy,
>>>> Cheers,
>>>> Stéphane
>>>>> Thanks,
>>>>> Jeremy
Re: [Acceleo] Calling Java methods [message #62705 is a reply to message #62171] |
Mon, 22 June 2009 10:25   |
--------------070406050409020802070304
Hi Jeremy,
Sorry for the delay, I didn't pay enough attention to this thread ... We
don't have a "nice" way to call java methods from acceleo templates yet;
and we the MTL specification doesn't allow for anything of the sort either.
We do provide a workaround though, in the form of a non-standard
operation allowing you to call java code from any template. Its syntax is :
[invoke(<qualified class name>, <full method name>, Sequence{<arguments>})/]
For example, let's say you have a service class
"domain.host.StringService" providing a method "toLower(String)". This
method could then be called with :
[invoke("domain.host.StringService", "toLower(java.lang.String)",
Sequence{'TEST'}/]
As you can see for yourself, this isn't really the readable way of doing
things ... and you can expect this to change on later versions of
Acceleo. It is merely provided as a workaround for now in wait for
proper tooling.
Laurent Goubet
Obeo
Jeremy Lavean a
Re: [Acceleo] Calling Java methods [message #523192 is a reply to message #63101] |
Thu, 25 March 2010 04:38   |
laurent Goubet schrieb:
> Hi Max,
> This feature comes from the "old" Acceleo where invoking Java services
> was frequent. In this "old" version, Java services had to be defined
> with a first parameter being the "receiver" of the service. This
> behavior has been kept in this implementation.
> It is true though that having a parameter is not always mandatory ...
> we'll have to think about this when we give this feature its needed
> overhaul :). For now and as you've discovered, passing the methods a
> dummy argument is a workaround.
> Do not hesitate to raise bugzillas about the things you'd like to see
> evolve or you think ar not intuitive/usable enough. This feature is a
> good example of a thing we provide "non-standard" yet would like to see
> added to the OMG specification sooner or later. Ideas to improve such
> features will always be warmly welcomed.
> Laurent Goubet
> Obeo
> Max Bureck a écrit :
>> this is better than having no black-box support at all. Unfortunately
>> I cannot invoke methods that have no parameters. Example:
>> [invoke('de.fuberlin.m2t.test.Helper', 'test()', Sequence{})/]
>> creates the output
>> org.eclipse.emf.ecore.impl.DynamicEObjectImpl@19aa8db (eClass:
>> org.eclipse.emf.ecore.impl.EClassImpl@c3f2e6 (name: Invalid_Class)
>> (instanceClassName: null) (abstract: false, interface: false))
>> When adding a dummy string-attribute to the java method and pass a
>> dummy string on invokation, everything works fine. Did I do something
>> wrong, or is it a bug?
i have another question. When i am invoking a java method and i am
returning a String or something, its always comes out with brackets like
"[myString]". Is there a way do work around that ? Sry, its my first
week with Acceleo ;).
Re: [Acceleo] Calling Java methods [message #523195 is a reply to message #523192] |
Thu, 25 March 2010 09:32   |
>> Hi Max,
>> see added to the OMG specification sooner or later. Ideas to improve
>> such features will always be warmly welcomed.
>> Laurent Goubet
>> Obeo
>>> Hi,
>>> creates the output
Ok, never mind.
Re: [Acceleo] Calling Java methods [message #523382 is a reply to message #523195] |
Fri, 26 March 2010 00:22  |
--------------060604020905000303040108
Hi Kevin,
I guess from this second mail that you've figured out the why. Please
create new threads for new questions instead of reusing old ones :).
Laurent Goubet
Obeo
>>> Hi Max,
>>> services was frequent. In this "old" version, Java services had to be
>>> defined with a first parameter being the "receiver" of the service.
>>> This behavior has been kept in this implementation.
>>> Laurent Goubet
>>> Obeo
>>> Max Bureck a
Current Time: Wed Jul 16 01:16:17 EDT 2025
Powered by FUDForum. Page generated in 0.06852 seconds
