Home » Eclipse Projects » Nebula » Nebula Version Downloads
| Nebula Version Downloads [message #61680] |
Fri, 16 January 2009 12:34  |
I am hoping someing can help me find out information about downloading the
latest version of nebula-cdatetime.
The download page
http://www.eclipse.org/nebula/widgets/cdatetime/cdatetime.ph p only allows
download of nebula_cdatetime_0.9.0.jar. I think are are newer versions
available, but I cannot find them.
Is the downloads page out of date?
What is the latest version of nebula-cdatetime and where can I download it?
Please help if you can.
| Re: Nebula Version Downloads [message #61968 is a reply to message #61824] |
Tue, 20 January 2009 19:59   |
Hi Jeremy,
I imported the projects via your team project set but I get the following compilation errors in 'org.eclipse.nebula.cwt'. Any ideas?
Craig
Description Resource Path Location Type
The method cairo_pattern_add_color_stop_rgba(int, double, double, double, double, double) in the type SwtAdapter is not applicable for the arguments (long, Float, double, double, double, Float) SwtAdapter.java org.eclipse.nebula.cwt/src/org/eclipse/nebula/cwt/svg line 507 Java Problem
The method cairo_pattern_destroy(int) in the type SwtAdapter is not applicable for the arguments (long) SwtAdapter.java org.eclipse.nebula.cwt/src/org/eclipse/nebula/cwt/svg line 475 Java Problem
The method cairo_pattern_set_matrix(int, double[]) in the type SwtAdapter is not applicable for the arguments (long, double[]) SwtAdapter.java org.eclipse.nebula.cwt/src/org/eclipse/nebula/cwt/svg line 501 Java Problem
The method gdip_LinearGradientBrush_ScaleTransform(int, float, float, int) in the type SwtAdapter is not applicable for the arguments (long, float, float, int) SwtAdapter.java org.eclipse.nebula.cwt/src/org/eclipse/nebula/cwt/svg line 613 Java Problem
The method gdip_LinearGradientBrush_SetInterpolationColors(int, int[], float[], int) in the type SwtAdapter is not applicable for the arguments (long, int[], float[], int) SwtAdapter.java org.eclipse.nebula.cwt/src/org/eclipse/nebula/cwt/svg line 592 Java Problem
The method gdip_LinearGradientBrush_TranslateTransform(int, float, float, int) in the type SwtAdapter is not applicable for the arguments (long, float, float, int) SwtAdapter.java org.eclipse.nebula.cwt/src/org/eclipse/nebula/cwt/svg line 612 Java Problem
The method gdip_PathGradientBrush_SetInterpolationColors(int, int[], float[], int) in the type SwtAdapter is not applicable for the arguments (long, int[], float[], int) SwtAdapter.java org.eclipse.nebula.cwt/src/org/eclipse/nebula/cwt/svg line 566 Java Problem
The method gdip_SolidBrush_delete(int) in the type SwtAdapter is not applicable for the arguments (long) SwtAdapter.java org.eclipse.nebula.cwt/src/org/eclipse/nebula/cwt/svg line 530 Java Problem
The method gtk_setSpreadMethod(int, int) in the type SwtAdapter is not applicable for the arguments (long, int) SwtAdapter.java org.eclipse.nebula.cwt/src/org/eclipse/nebula/cwt/svg line 509 Java Problem
The method win32_setSpreadMethod(int, int) in the type SwtAdapter is not applicable for the arguments (long, int) SwtAdapter.java org.eclipse.nebula.cwt/src/org/eclipse/nebula/cwt/svg line 593 Java Problem
On Sat, 17 Jan 2009 17:56:26 -0700, Jeremy Dowdall wrote:
> Attached is a team project set that will do the import for you. It uses
> eclipse's anonymous pserver access, so the username is "anonymous" and
> the password should be left blank.
> I just tested it on a fresh eclipse install, but let me know if it gives
> you any troubles.
> cheers,
> Jeremy
> Craig Foote wrote:
>> Can you provide the CVS URL please?
>> Craig Foote
>> On Fri, 16 Jan 2009 21:30:39 +0100, Tom Schindl wrote:
>>> Hi Mark,
>>> We currently have no builds you need to fetch the sources from CVS.
>>> Tom
>>>> downloading the latest version of nebula-cdatetime.
>>>> The download page
>>>> allows download of nebula_cdatetime_0.9.0.jar. I think are are newer
>>>> versions available, but I cannot find them.
>>>> download it?
> <?xml version="1.0" encoding="UTF-8"?> <psf version="2.0">
> <provider id="org.eclipse.team.cvs.core.cvsnature"> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .swt.nebula/org.eclipse.nebula.cwt,org.eclipse.nebula.cwt "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .swt.nebula/org.eclipse.nebula.cwt.snippets,org.eclipse.nebu la.cwt.snippets "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .swt.nebula/org.eclipse.nebula.cwt.tests,org.eclipse.nebula. cwt.tests "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .swt.nebula/org.eclipse.nebula.widgets.cdatetime,org.eclipse .nebula.widgets.cdatetime "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .swt.nebula/org.eclipse.nebula.widgets.cdatetime.snippets,or g.eclipse.nebula.widgets.cdatetime.snippets "/>
> <project
> reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/technology,org.eclipse .swt.nebula/org.eclipse.nebula.widgets.cdatetime.tests,org.e clipse.nebula.widgets.cdatetime.tests "/>
> </provider>
> </psf>
| Re: Nebula Version Downloads [message #62017 is a reply to message #61968] |
Wed, 21 January 2009 20:04   |
Hi Craig,
Any chance you're running a 64bit OS?
Getting a 64bit vm up and running is on my list, but I haven't gotten
there yet.
Add yourself to this bug to track the issue:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=261941
thanks,
Jeremy
Craig Foote wrote:
> Hi Jeremy,
> Craig
>> you any troubles.
>> cheers,
>> Jeremy
>>> Craig Foote
>>>> Hi Mark,
>>>> Tom
>>>>> The download page
>>>>> download it?
>> <project
>> <project
>> <project
>> <project
>> <project
>> </provider>
>> </psf>
| Re: Nebula Version Downloads [message #62040 is a reply to message #62017] |
Wed, 21 January 2009 20:24   |
Why yes I am, impressive. I have updated the ticket and CC'd myself. Thanks Jeremy, we'll try again with a 32-bit machine.
Craig
On Wed, 21 Jan 2009 18:04:00 -0700, Jeremy Dowdall wrote:
> Hi Craig,
> Any chance you're running a 64bit OS? Getting a 64bit vm up and running
> is on my list, but I haven't gotten there yet.
> thanks,
> Jeremy
> Craig Foote wrote:
>> Hi Jeremy,
>> Craig
>> Description Resource Path Location Type The method
>> Problem The method cairo_pattern_destroy(int) in the type SwtAdapter is
>> Problem The method cairo_pattern_set_matrix(int, double[]) in the type
>> line 501 Java Problem The method
>> Problem The method gdip_LinearGradientBrush_SetInterpolationColors(int,
>> Problem The method gdip_LinearGradientBrush_TranslateTransform(int,
>> Problem The method gdip_PathGradientBrush_SetInterpolationColors(int,
>> Problem The method gdip_SolidBrush_delete(int) in the type SwtAdapter
>> Problem The method gtk_setSpreadMethod(int, int) in the type SwtAdapter
>> Problem The method win32_setSpreadMethod(int, int) in the type
>>> uses eclipse's anonymous pserver access, so the username is
>>> "anonymous" and the password should be left blank.
>>> gives you any troubles.
>>> cheers,
>>> Jeremy
>>>> Craig Foote
>>>>> Hi Mark,
>>>>> Tom
>>>>>> The download page
>>>>>> newer versions available, but I cannot find them.
>>>>>> download it?
>>> <?xml version="1.0" encoding="UTF-8"?> <psf version="2.0"> <provider
>>> <project
>>> <project
>>> <project
>>> <project
>>> <project
>>> </provider>
>>> </psf>
| Re: Nebula Version Downloads [message #62207 is a reply to message #62017] |
Fri, 23 January 2009 00:12  |
You da man Jeremy! I just updated and my errors are gone. I've exported the jars and I'm ready to go. Thanks very much for your help and cat-like response.
Craig
> Hi Craig,
> thanks,
> Jeremy
> Craig Foote wrote:
>> Hi Jeremy,
>> Craig
>>> cheers,
>>> Jeremy
>>>> Craig Foote
>>>>> Hi Mark,
>>>>> Tom
>>>>>> The download page
>>>>>> download it?
>>> <project
>>> <project
>>> <project
>>> <project
>>> <project
>>> </provider>
>>> </psf>
| Re: Nebula Version Downloads [message #593159 is a reply to message #61680] |
Fri, 16 January 2009 15:30  |
Hi Mark,
Tom
> The download page
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
| Re: Nebula Version Downloads [message #593207 is a reply to message #61703] |
Sat, 17 January 2009 18:39  |
Craig Foote
> Hi Mark,
> Tom
>> The download page
>> it?
| Re: Nebula Version Downloads [message #593219 is a reply to message #61801] |
Sat, 17 January 2009 19:56  |
--------------070905030204080709060009
Content-Type: text/plain; charset=UTF-8; format=flowed
It uses eclipse's anonymous pserver access, so the username is
you any troubles.
cheers,
Jeremy
> Craig Foote
>> Hi Mark,
>> Tom
>>> The download page
>>> it?
Content-Type: text/xml;
name="cdatetime.psf"
Content-Disposition: inline;
filename="cdatetime.psf"
PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiPz4KPHBzZiB2 ZXJzaW9uPSIy
LjAiPgo8cHJvdmlkZXIgaWQ9Im9yZy5lY2xpcHNlLnRlYW0uY3ZzLmNvcmUu Y3ZzbmF0dXJl
Ij4KPHByb2plY3QgcmVmZXJlbmNlPSIxLjAsOnBzZXJ2ZXI6ZGV2LmVjbGlw c2Uub3JnOi9j
dnNyb290L3RlY2hub2xvZ3ksb3JnLmVjbGlwc2Uuc3d0Lm5lYnVsYS9vcmcu ZWNsaXBzZS5u
ZWJ1bGEuY3d0LG9yZy5lY2xpcHNlLm5lYnVsYS5jd3QiLz4KPHByb2plY3Qg cmVmZXJlbmNl
PSIxLjAsOnBzZXJ2ZXI6ZGV2LmVjbGlwc2Uub3JnOi9jdnNyb290L3RlY2hu b2xvZ3ksb3Jn
LmVjbGlwc2Uuc3d0Lm5lYnVsYS9vcmcuZWNsaXBzZS5uZWJ1bGEuY3d0LnNu aXBwZXRzLG9y
Zy5lY2xpcHNlLm5lYnVsYS5jd3Quc25pcHBldHMiLz4KPHByb2plY3QgcmVm ZXJlbmNlPSIx
LjAsOnBzZXJ2ZXI6ZGV2LmVjbGlwc2Uub3JnOi9jdnNyb290L3RlY2hub2xv Z3ksb3JnLmVj
bGlwc2Uuc3d0Lm5lYnVsYS9vcmcuZWNsaXBzZS5uZWJ1bGEuY3d0LnRlc3Rz LG9yZy5lY2xp
cHNlLm5lYnVsYS5jd3QudGVzdHMiLz4KPHByb2plY3QgcmVmZXJlbmNlPSIx LjAsOnBzZXJ2
ZXI6ZGV2LmVjbGlwc2Uub3JnOi9jdnNyb290L3RlY2hub2xvZ3ksb3JnLmVj bGlwc2Uuc3d0
Lm5lYnVsYS9vcmcuZWNsaXBzZS5uZWJ1bGEud2lkZ2V0cy5jZGF0ZXRpbWUs b3JnLmVjbGlw
c2UubmVidWxhLndpZGdldHMuY2RhdGV0aW1lIi8+Cjxwcm9qZWN0IHJlZmVy ZW5jZT0iMS4w
LDpwc2VydmVyOmRldi5lY2xpcHNlLm9yZzovY3Zzcm9vdC90ZWNobm9sb2d5 LG9yZy5lY2xp
cHNlLnN3dC5uZWJ1bGEvb3JnLmVjbGlwc2UubmVidWxhLndpZGdldHMuY2Rh dGV0aW1lLnNu
aXBwZXRzLG9yZy5lY2xpcHNlLm5lYnVsYS53aWRnZXRzLmNkYXRldGltZS5z bmlwcGV0cyIv
Pgo8cHJvamVjdCByZWZlcmVuY2U9IjEuMCw6cHNlcnZlcjpkZXYuZWNsaXBz ZS5vcmc6L2N2
c3Jvb3QvdGVjaG5vbG9neSxvcmcuZWNsaXBzZS5zd3QubmVidWxhL29yZy5l Y2xpcHNlLm5l
YnVsYS53aWRnZXRzLmNkYXRldGltZS50ZXN0cyxvcmcuZWNsaXBzZS5uZWJ1 bGEud2lkZ2V0
cy5jZGF0ZXRpbWUudGVzdHMiLz4KPC9wcm92aWRlcj4KPC9wc2Y+
--------------070905030204080709060009--
| Re: Nebula Version Downloads [message #593257 is a reply to message #61824] |
Tue, 20 January 2009 09:39  |
I am getting a "connection refused" error.
I suspect this is a firewall issue at my end.
Is there an alternative way to access the repository, such as straight
HTTP.
Thank you
| Re: Nebula Version Downloads [message #593276 is a reply to message #61824] |
Hi Jeremy,
Craig
> you any troubles.
> cheers,
> Jeremy
>> Craig Foote
>>> Hi Mark,
>>> Tom
>>>> The download page
>>>> download it?
> <project
> <project
> <project
> <project
> <project
> </provider>
> </psf>
| Re: Nebula Version Downloads [message #593286 is a reply to message #61919] |
Wed, 21 January 2009 19:51  |
I haven't had to connect from behind a firewall, but Eclipse offers
these tips that may help:
http://wiki.eclipse.org/index.php/CVS_Howto#CVS_and_firewall s
Note that the psf file contains all the CVS paths.
We're also working on updating a lot of things in the Nebula project so
hopefully it won't be too much longer before an updated download is
available - for now it would probably be a good idea to subscribe to the
dev mailing list if you haven't already.
> HTTP.
> Thank you
| Re: Nebula Version Downloads [message #593295 is a reply to message #61968] |
Hi Craig,
there yet.
thanks,
Jeremy
Craig Foote wrote:
> Hi Jeremy,
> Craig
>> you any troubles.
>> cheers,
>> Jeremy
>>> Craig Foote
>>>> Hi Mark,
>>>> Tom
>>>>> The download page
>>>>> download it?
>> <project
>> <project
>> <project
>> <project
>> <project
>> </provider>
>> </psf>
| Re: Nebula Version Downloads [message #593306 is a reply to message #62017] |
Craig
> Hi Craig,
> thanks,
> Jeremy
> Craig Foote wrote:
>> Hi Jeremy,
>> Craig
>>> cheers,
>>> Jeremy
>>>> Craig Foote
>>>>> Hi Mark,
>>>>> Tom
>>>>>> The download page
>>>>>> download it?
>>> <project
>>> <project
>>> <project
>>> <project
>>> <project
>>> </provider>
>>> </psf>
| Re: Nebula Version Downloads [message #593361 is a reply to message #61703] |
Thu, 22 January 2009 15:02  |
The Nebula web page seems out of date. The Download page for CDateTime
should be updated to show how to get the code. I expect that you will be
doing this as the project progresses.
| Re: Nebula Version Downloads [message #593390 is a reply to message #62017] |
Craig
> Hi Craig,
> thanks,
> Jeremy
> Craig Foote wrote:
>> Hi Jeremy,
>> Craig
>>> cheers,
>>> Jeremy
>>>> Craig Foote
>>>>> Hi Mark,
>>>>> Tom
>>>>>> The download page
>>>>>> download it?
>>> <project
>>> <project
>>> <project
>>> <project
>>> <project
>>> </provider>
>>> </psf>
Current Time: Sat Nov 08 20:25:01 EST 2025
Powered by FUDForum. Page generated in 0.29190 seconds
