Home » Archived » M2M (model-to-model transformation) » [M2M] On the usage of prefixes in the M2M newsgroup
[M2M] On the usage of prefixes in the M2M newsgroup [message #61648] Mon, 10 September 2007 11:43
Hi All,
The M2M project consists of several components.
Therefore, the subject of every post should mention the targeted
component to make it clear without having to read through the entire post.
In order to keep things simple, the rule of prefixing every subject with
an identifier of the targeted component (or [M2M] for the overall
project, like here) has been instated.
See http://wiki.eclipse.org/M2M for more details.
This message is a reminder that every post must abide by that rule.
In particular, we should not see any post without prefix, or with a
non-standard prefix.
For instance, there are two QVT components:
- QVT Operational Mappings, for which the prefix is [QVTOM],
- QVT Relations, for which the prefix is [QVTR]
But because there is no [QVT] prefix defined, using it is confusing.
Frédéric Jouault
Previous Topic:[ATL] ATL Port to Eclipse Linux
Next Topic:[ATL]String expression to ATL model
Current Time: Fri Nov 07 11:10:43 EST 2025
Powered by FUDForum. Page generated in 0.03853 seconds
