Home » Archived » XML Schema Definition (XSD) » XSD schema tree
XSD schema tree [message #61612] Tue, 14 June 2005 10:42 Go to next message
Originally posted by: Parameshwara.tatini.gxs.com
I am trying to build tree from Schema. And I am able to build the tree
from schema.
But I am facing the problems if my schema has import/include schemas.
It is like A.xsd imported B.xsd and B.xsd imports C.xsd.
Say I have Element 'xa' defined in A.xsd and type="xbtype" which is
defined in B.xsd and in b.xsd the defination for 'xbtype' is defined as
type="xctype" and in C.xsd i have defined type for 'xctype'. but in parser
i am not able to get all the elements which are defined in C.XSD
Please help me to resolve this issue
Robert
Re: XSD schema tree [message #61660 is a reply to message #61612] Tue, 14 June 2005 12:24 Go to previous messageGo to next message
Robert,
It will help me to know what you've tried. The XSD model really
supports both a syntactic view of the schema as well as the abstract
component model defined in the XML Schema specification. For example,
XSDSchema.getContents() will get you what's physically in the schema
whereas something like XSDSchema.getElementDeclarations will get you all
the elements logically part of the schema (via includes and imports).
It's also possible that you are having problems with imports and
includes not resolving because you've not loaded the schema with an
absolute URI; see the note about "How to get elements from the include
schemas" which is two notes up from this one in the newsgroup.
Robert wrote:
> tree from schema.
> as type="xctype" and in C.xsd i have defined type for 'xctype'. but in
> parser i am not able to get all the elements which are defined in C.XSD
> Robert
Re: XSD schema tree [message #61804 is a reply to message #61660] Tue, 21 June 2005 01:29 Go to previous messageGo to next message
Hi Ed Merks,
Thanks for your response.
I have gone through that link But not able to solve my problem.
Brief Des about my problem is
I have A.XSD which Includes B.XSD and B.xsd includes C.XSD.
I am able to resolve entity type referenced in B.XSD But not from C.XSD
My Requirement is to build schema tree. I am sending you sample schemas
and code which I have used (modified for demo purpose).
with the current code I am getting this as output
/envelope
/envelope/messageHeader
/envelope/messageHeader/to
Here the problem is Typedefination for element 'to' is defined in C.xsd
which is not resolved.
I should get some thing like this
/envelope
/envelope/messageHeader/to/gln
Here is the code I have used
* Created on Mar 9, 2005
* TODO To change the template for this generated file go to
* Window - Preferences - Java - Code Style - Code Templates
package com.gxs.ai.ngwb.xsdparser;
import java.io.File;
import java.io.FileNotFoundException;
import java.io.IOException;
import java.util.ArrayList;
import java.util.Iterator;
import javax.swing.tree.TreeNode;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.xsd.XSDAttributeDeclaration;
import org.eclipse.xsd.XSDAttributeGroupContent;
import org.eclipse.xsd.XSDAttributeGroupDefinition;
import org.eclipse.xsd.XSDAttributeUse;
import org.eclipse.xsd.XSDAttributeUseCategory;
import org.eclipse.xsd.XSDComplexTypeDefinition;
import org.eclipse.xsd.XSDDiagnostic;
import org.eclipse.xsd.XSDElementDeclaration;
import org.eclipse.xsd.XSDModelGroup;
import org.eclipse.xsd.XSDModelGroupDefinition;
import org.eclipse.xsd.XSDParticle;
import org.eclipse.xsd.XSDParticleContent;
import org.eclipse.xsd.XSDPlugin;
import org.eclipse.xsd.XSDSchema;
import org.eclipse.xsd.XSDSchemaContent;
import org.eclipse.xsd.XSDSimpleTypeDefinition;
import org.eclipse.xsd.XSDTypeDefinition;
import org.eclipse.xsd.impl.XSDComplexTypeDefinitionImpl;
import org.eclipse.xsd.impl.XSDElementDeclarationImpl;
import org.eclipse.xsd.util.XSDResourceFactoryImpl;
import org.eclipse.xsd.util.XSDResourceImpl;
* @author tatinip
* TODO To change the template for this generated type comment go to
public class XSDParserNEW
private String m_XSDFileName;
private ArrayList m_error_List ;
private ArrayList m_warning_List ;
private int m_minOccurrence = 1;
private int m_maxOccurrence = 1;
private String m_rootElementName;
private boolean m_isRoot = false;
private boolean flag = false;
private boolean m_ignoreCpexTypeDefnName = false;
private String m_modelName;
private String m_modelDirection;
protected TreeNode m_VirtualRoot;
private String m_ModelType="";
public XSDParserNEW(){
public boolean parseXSD(String xsdFileName ,
String rootElementName)
throws FileNotFoundException , IOException , Exception
m_rootElementName = rootElementName;
m_XSDFileName = xsdFileName;
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "xsd",
new XSDResourceFactoryImpl());
try
boolean status = validateAndProcess(xsdFileName);
return status;
}catch(IOException ioe)
throw ioe;
}catch(Exception e)
throw e;
private boolean validateAndProcess(String xsdFile) throws Exception
* This let's us test whether the string exists as a file.
* It not, we try as a URI.
m_error_List = new ArrayList();
m_warning_List = new ArrayList();
URI uri;
if (xsdFile==null ){
//DMParseError parserError = new DMParseError(4,"","Schema file not
specified",0,0);
//m_error_List.add(parserError);
m_warning_List.add("Schema file not specified in Model file " +
m_modelName);
//this.rootNode = null;
return true;
File file = new File(xsdFile);
if (!file.exists()){
//DMParseError parserError = new DMParseError(4,"","File Not
Found",0,0);
m_warning_List.add("Schema file not Found " + xsdFile);
return true;
if (file.isFile())
uri = URI.createFileURI(file.getCanonicalFile().toString());
else
uri = URI.createURI(xsdFile);
// Create a resource set, create a schema resource, and load the main
schema file into it.
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getLoadOptions().put(XSDResourceImpl.XSD_TRACK_L OCATION,
Boolean.TRUE);
XSDResourceImpl xsdMainResource =
(XSDResourceImpl)resourceSet.createResource(uri);
xsdMainResource.setURI(uri);
xsdMainResource.load(resourceSet.getLoadOptions());
// Get the first resource, i.e., the main resource and those that
have been included or imported.
Object resource = resourceSet.getResources().get(0);
if (resource instanceof XSDResourceImpl)
XSDResourceImpl xsdResource = (XSDResourceImpl)resource;
XSDSchema xsdSchema = xsdResource.getSchema();
xsdSchema.validate();
* Schema file is valid if Diagnostics is empty
if (!xsdSchema.getDiagnostics().isEmpty())
for (Iterator i = xsdSchema.getDiagnostics().iterator();
i.hasNext(); )
XSDDiagnostic xsdDiagnostic = (XSDDiagnostic)i.next();
String localizedSeverity =
XSDPlugin.INSTANCE.getString("_UI_XSDDiagnosticSeverity_" +
xsdDiagnostic.getSeverity());
//Handle Error
// DMParseError parserError = new
DMParseError(4,"" ,xsdDiagnostic.getMessage(),xsdDiagnostic.getLine(),xsdDiagn ostic.getColumn());
xsdResource.unload();
return false;
// If the user not selected root element set first element as
root element
if (m_rootElementName == null ||
m_rootElementName.equalsIgnoreCase("")){
Iterator i = xsdSchema.getContents().iterator();
while(i.hasNext()){
XSDSchemaContent e = (XSDSchemaContent)i.next(); // probable root
element
if (e instanceof XSDElementDeclaration){
m_rootElementName = e.getElement().getAttribute("name");
break;
processRoot(xsdSchema);
return true;
return false;
private void processRoot(XSDSchema schema)
//process each element directly under the 'schema' element
for(Iterator i = schema.getElementDeclarations().iterator();
i.hasNext(); )
XSDElementDeclaration e = (XSDElementDeclaration)i.next(); // probable
root element
m_isRoot = true;
if (m_rootElementName != null &&
!m_rootElementName.equalsIgnoreCase("")){
if (m_rootElementName.equalsIgnoreCase(e.getName())){
dumpContentItem(e, 0,"");
}else{
flag = false;
* Method dumpContentItem.
* @param item
* @param level
* This is a recursive method called for handling (currently)
XSDElementDeclaration,
* XSDComplexTypeDefinition, XSDSimpleTypeDefinition,
XSDAttributeDeclaration,
* XSDModelGroupDefinition, XSDAttributeGroupDefinition
private void dumpContentItem(XSDSchemaContent item, int level, String
xPath)
try{
if(item instanceof XSDElementDeclaration)
XSDElementDeclarationImpl elem = (XSDElementDeclarationImpl)item;
int min = m_minOccurrence;
int max = m_maxOccurrence;
if(elem.getName() != null)
xPath = xPath+"/"+elem.getName();
printTree(xPath);
m_isRoot = false; // Need to do this after writing the root header,
//because the processing of child elements starts here
// Get the type definition of the Element
XSDTypeDefinition elemTypeDef= elem.getTypeDefinition();
if(elemTypeDef==null &&
elem.getResolvedElementDeclaration().getValue() == null)
// For a reference
dumpContentItem(elem.getResolvedElementDeclaration(), level, xPath);
}else if((elemTypeDef instanceof XSDSimpleTypeDefinition) &&
((XSDSimpleTypeDefinition)elem.getTypeDefinition()).getConte nts().isEmpty())
// Element doesn't have any children i.e simpleContent but might have
restrictions etc
else // The 'type' attribute is another element in the same XSD file
/* name of the Complex type must be ignored when an element refers to
* it with the 'type' attribute
if(elemTypeDef instanceof XSDComplexTypeDefinition)
if(((XSDComplexTypeDefinition)elemTypeDef).getName()!=null )
m_ignoreCpexTypeDefnName = true;
dumpContentItem(elemTypeDef, level, xPath);
else if (item instanceof XSDComplexTypeDefinition)
XSDComplexTypeDefinitionImpl cplex = (XSDComplexTypeDefinitionImpl)item;
if(!m_ignoreCpexTypeDefnName && cplex.getName()!=null)
xPath = xPath+"/"+cplex.getName();
// Process the attributes
for(Iterator i = cplex.getAttributeContents().iterator(); i.hasNext(); )
XSDAttributeGroupContent att_grp = (XSDAttributeGroupContent) i.next();
// For attribute group
if(att_grp instanceof XSDAttributeGroupDefinition)
dumpContentItem(((XSDAttributeGroupDefinition)att_grp), level,
xPath);
/*for(Iterator j =
((XSDAttributeGroupDefinition)att_grp).getAttributeUses().it erator();
j.hasNext(); )
j.next(); // need to take care
//dumpContentItem(((XSDAttributeUse)j.next()).getAttributeDe claration(),level);
}else if(att_grp instanceof XSDAttributeUse)
setAttributeOccurrences(((XSDAttributeUse)att_grp).getUse()) ;
dumpContentItem(((XSDAttributeUse)att_grp).getAttributeDecla ration(),level,
xPath);
else
System.out.println("2. UNHANDLED");
// Process the element content if it is not equal to null
if(cplex.getContent() != null)
if(cplex.getContent() instanceof XSDParticle)
dumpParticle((XSDParticle)cplex.getContent(), level, xPath);
else if(cplex.getContent() instanceof XSDSimpleTypeDefinition)
dumpContentItem((XSDSimpleTypeDefinition)cplex.getContent(), level,
xPath);
else
System.out.println("1. UNHANDLED"+ cplex.getContent().toString());
else if (item instanceof XSDSimpleTypeDefinition)
XSDSimpleTypeDefinition simple = (XSDSimpleTypeDefinition)item;
xPath = xPath+"/"+simple.getName();
if(simple.getContents() != null )
if(!simple.getContents().isEmpty())
for(Iterator i = simple.getContents().iterator(); i.hasNext(); )
XSDSimpleTypeDefinition child_simple =
(XSDSimpleTypeDefinition)i.next();
dumpContentItem(child_simple, level+1, xPath);
else
System.out.println("4. UNHANDLED");
else
System.out.println("3. UNHANDLED");
else if (item instanceof XSDAttributeDeclaration)
XSDAttributeDeclaration attrib = (XSDAttributeDeclaration)item;
xPath = xPath+"/"+attrib.getName();
} else if(item instanceof XSDModelGroupDefinition)
// For sequence, all, choice
XSDModelGroupDefinition mgdef = (XSDModelGroupDefinition)item;
if(mgdef.getModelGroup() != null)
for(Iterator i = mgdef.getModelGroup().getContents().iterator();
i.hasNext(); )
XSDParticle pcle = (XSDParticle)i.next();
dumpParticle(pcle, level+1, xPath);
} else
// for "<xs:group ref=
dumpContentItem((mgdef.getResolvedModelGroupDefinition()), level,
xPath);
} else if(item instanceof XSDAttributeGroupDefinition)
XSDAttributeGroupDefinition att_grp = (XSDAttributeGroupDefinition)item;
if(!att_grp.getAttributeUses().isEmpty())
for(Iterator i = att_grp.getAttributeUses().iterator(); i.hasNext(); )
XSDAttributeUse att_use = (XSDAttributeUse)i.next();
setAttributeOccurrences(att_use.getUse());
dumpContentItem((att_use).getAttributeDeclaration(),level, xPath);
}else // For an attributeGroup reference
//dumpContentItem(att_grp.getResolvedAttributeGroupDefinitio n(),
level, xPath);
else
// example : XSDAnnotation, XSDNotationDeclaration, XSDImport,
XSDInclude,
if(item != null)
System.out.println("Unhandled Schema Content : "+ item.toString());
}catch(Exception e)
e.printStackTrace();
// Set the class level helper variables to default values
m_isRoot = false;
private void setAttributeOccurrences(XSDAttributeUseCategory e)
if(e == XSDAttributeUseCategory.OPTIONAL_LITERAL)
m_minOccurrence = 0;
} else
if(e == XSDAttributeUseCategory.REQUIRED_LITERAL)
} else
if(e == XSDAttributeUseCategory.PROHIBITED_LITERAL)
m_maxOccurrence = 0;
else // default
* Method dumpParticle.
* @param p
* @param level
private void dumpParticle(XSDParticle p, int level,String xPath)
m_minOccurrence = p.getMinOccurs();
if (p.getMaxOccurs() == XSDParticle.UNBOUNDED ) {
m_maxOccurrence = Integer.MAX_VALUE;
}else {
m_maxOccurrence = p.getMaxOccurs();
XSDParticleContent partContent= p.getContent();
if(partContent instanceof XSDElementDeclaration)
dumpContentItem((XSDElementDeclaration)partContent, level, xPath);
else if(partContent instanceof XSDModelGroupDefinition)
dumpContentItem((XSDModelGroupDefinition)partContent, level, xPath);
else if(partContent instanceof XSDModelGroup)
XSDModelGroup temp = (XSDModelGroup)partContent;
for(Iterator i = temp.getContents().iterator(); i.hasNext(); )
dumpParticle((XSDParticle)i.next(), level+1, xPath);
else
System.out.println("unhandled particle "+ p.toString());
//XSDTerm
//XSDWildcard
private void printTree(String xPath){
System.out.println(xPath);
public static void main(String arg[]){
try {
new XSDParserNEW().parseXSD("A.xsd","envelope");
} catch (FileNotFoundException e) {
// TODO Auto-generated catch block
} catch (IOException e) {
} catch (Exception e) {
These are sample files.
A.XSD
<!-- edited with XMLSpy v2005 rel. 3 U (http://www.altova.com) by Param
(GXS) -->
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns="http://www.ean-ucc.org/schemas/1.3.1/eanucc"
targetNamespace="http://www.ean-ucc.org/schemas/1.3.1/eanucc"
elementFormDefault="unqualified" attributeFormDefault="unqualified">
<xsd:include schemaLocation="B.xsd"/>
<xsd:element name="envelope" type="EnvelopeType"/>
<xsd:complexType name="EnvelopeType">
<xsd:sequence>
<xsd:element name="messageHeader" type="MessageHeaderType"/>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
B.XSD
<!-- edited with XMLSPY v5 rel. 3 U (http://www.xmlspy.com) by Ewa Iwicka
(EAN International) -->
<xsd:include schemaLocation="C.xsd"/>
<!--Entity Identification -->
<xsd:complexType name="MessageHeaderType">
<xsd:sequence>
<xsd:element name="to" type="PartyIdentificationType" minOccurs="0"/>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
C.XSD
<xsd:simpleType name="GlobalLocationNumberType">
<xsd:restriction base="xsd:string">
<xsd:pattern value="\d{13}"/>
</xsd:restriction>
</xsd:simpleType>
<xsd:complexType name="PartyIdentificationType">
<xsd:sequence>
<xsd:choice>
<xsd:element name="gln" type="GlobalLocationNumberType"/>
</xsd:choice>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
Thanks for Help.
Robert
Re: XSD schema tree [message #61854 is a reply to message #61804] Tue, 21 June 2005 08:08 Go to previous messageGo to next message
--------------050100040901090906070309
Robert,
When I ran this sample it produced:
/envelope
I wonder if 99227 <https://bugs.eclipse.org/bugs/show_bug.cgi?id=99227>
solved the problem? Which version are you trying?
Robert wrote:
> Hi Ed Merks,
> schemas and code which I have used (modified for demo purpose).
> /envelope
> C.xsd which is not resolved.
> /envelope
> * @author tatinip
> public class XSDParserNEW {
> String rootElementName) throws
> try
> return status;
> throw ioe;
> }catch(Exception e)
> { throw e;
> URI uri;
> file not specified",0,0);
> file " + m_modelName);
> return true;
> Not Found",0,0);
> return true;
> if (file.isFile())
> else
> the main schema file into it.
> Boolean.TRUE);
> that have been included or imported.
> i.hasNext(); )
> //Handle Error
> return false;
> // If the user not
> selected root element set first element as root element
> while(i.hasNext()){
> // probable root element
> m_rootElementName =
> break;
> return true;
> return false;
> i.hasNext(); )
> (XSDElementDeclaration)i.next(); // probable root element
> m_isRoot = true;
> }else{
> flag = false;
> * @param item
> * @param level
> String xPath)
> try{
> printTree(xPath);
> root header,
> // For a reference
> level, xPath);
> simpleContent but might have restrictions etc
> same XSD file
> element refers to
> i.hasNext(); )
> dumpContentItem(((XSDAttributeGroupDefinition)att_grp), level, xPath);
> /*for(Iterator j =
> j.hasNext(); )
> xPath);
> else
> level, xPath);
> xPath);
> else
> i.hasNext(); )
> else
> else
> for(Iterator i =
> mgdef.getModelGroup().getContents().iterator(); i.hasNext(); )
> } else
> dumpContentItem((mgdef.getResolvedModelGroupDefinition()), level, xPath);
> for(Iterator i =
> level, xPath);
> else
> XSDImport, XSDInclude,
> if(item != null)
> item.toString());
> }catch(Exception e)
> m_isRoot = false;
> } else
> } else
> else // default
> * @param p
> * @param level
> }else {
> xPath);
> level, xPath);
> i.hasNext(); )
> else
> //XSDTerm
> //XSDWildcard
> try {
> A.XSD
> Param (GXS) -->
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> B.XSD
> Iwicka (EAN International) -->
> <xsd:sequence>
> minOccurs="0"/>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> C.XSD
> </xsd:restriction>
> </xsd:simpleType>
> <xsd:sequence>
> <xsd:choice>
> </xsd:choice>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> Thanks for Help.
> Robert
<html>
<head>
http-equiv="Content-Type">
</head>
Robert,<br>
<br>
When I ran this sample it produced:<br>
<blockquote>/envelope<br>
/envelope/messageHeader<br>
/envelope/messageHeader/to<br>
/envelope/messageHeader/to/gln<br>
</blockquote>
I wonder if
Re: XSD schema tree [message #61879 is a reply to message #61854] Tue, 21 June 2005 08:19 Go to previous messageGo to next message
Hi Ed Merks,
Thanks for very quick response.
I am using XSD 2.0.0 plugin and eclipse 3.0.0
Can you suggest me which version of XSD plugin I have to use?.
We are using eclipse 3.0.0 and that I can't change as we are developing
all products in 3.0.0.
Thanks again for quick response
Robert.
Re: XSD schema tree [message #61932 is a reply to message #61879] Tue, 21 June 2005 09:12 Go to previous messageGo to next message
--------------010906030604020109030401
Robert,
I'm not able to reproduce this on an old 3.0.1 (with EMF/XSD/SDO 2.0.1)
base I have kicking around either:
Maybe the problem was fixed in the 2.0.x stream. The 2.0.2 version of
EMF/XSD/SDO is a released supported version that should still work with
Eclipse 3.0.0.
Robert wrote:
> Hi Ed Merks,
> developing all products in 3.0.0.
> Robert.
Content-Type: multipart/related;
boundary="------------020404090102070604030907"
--------------020404090102070604030907
<html>
<head>
</head>
Robert,<br>
<br>
base I have kicking around either:<br>
<blockquote><img src="cid:part1.09070607.03000306@ca.ibm.com" alt=""><br>
</blockquote>
Re: XSD schema tree [message #61954 is a reply to message #61932] Tue, 21 June 2005 09:34 Go to previous messageGo to next message
Hi Ed Merks,
Yes you are correct. This is fixed in 2.0.3 or may be before.
Your valueble suggistions really helped us.
Thanks again
Robert.
Re: XSD schema tree [message #62116 is a reply to message #61954] Wed, 29 June 2005 09:43 Go to previous messageGo to next message
HI Ed Merks,
I am here again with new question.
My requirement is I have to copy main Schema file and imported/included
schema files from remote site.
I have another utility which will copy file from remote site to my local
disk if I send file name.
So first time I will send main schema file to my utility. So that I can
have main file in local disk.
Now my requirement comes here. I have to parse main schema file and get
Import/Include files list.
So when I load schema and validate I am getting getAllDiagnostics errors.
Because I do not have imported files (they are not resolved)
To get imported files I am using the below code. Please advise me weather
I am following right way or not ?
I am posting my code here. The below method prints import/include file
names.
Robert
public String[] getImpIncList(String schemaFileName)throws IOException{
String impincList[];
File file = new File(schemaFileName);
URI uri;
if (file.isFile())
else
uri = URI.createURI(schemaFileName);
Boolean.TRUE);
(XSDResourceImpl)resourceSet.createResource(URI.createURI("*.xsd "));
// Get the first resource, i.e., the main resource and those that have
if (!xsdSchema.getAllDiagnostics().isEmpty())
for (Iterator i = xsdSchema.getAllDiagnostics().iterator();
i.hasNext(); )
EList elist = xsdDiagnostic.getComponents();
if (elist != null){
for (Iterator ie = elist.iterator(); ie.hasNext(); )
Object obj = ie.next();
if (obj instanceof XSDImport){
XSDImport imp = (XSDImport)obj;
System.out.println(imp.getSchemaLocation());
}else if (obj instanceof XSDInclude){
XSDInclude inc = (XSDInclude)obj;
System.out.println(inc.getSchemaLocation());
return null;
return null;
Re: XSD schema tree [message #62140 is a reply to message #62116] Wed, 29 June 2005 17:36 Go to previous messageGo to next message
Robert,
Your code looks okay, but the problem is that the schema locations could
be relative URIs (needing to be resolved against the base URI of the
schema in which they occur) or could even be missing (for imports), in
which case the namespace itself is used as a location.
If you loaded the main remote file into a resource set, all the imports
and includes will resolve (to the correct relative locations). This
will fill the resource set up with all the schema resources you need.
You could look at the URI of each resource to know what file to copy
over and you have the complete list. This seems better.
Robert wrote:
> HI Ed Merks,
> imported/included schema files from remote site.
> local disk if I send file name.
> can have main file in local disk.
> get Import/Include files list.
> errors. Because I do not have imported files (they are not resolved)
> weather I am following right way or not ?
> names.
> Thanks
> Robert
> IOException{
> URI uri;
> if (file.isFile())
> else
> load the main schema file into it.
> Boolean.TRUE);
> those that have been included or imported.
> for (Iterator i =
> xsdSchema.getAllDiagnostics().iterator(); i.hasNext(); )
> if (elist != null){
> ie.hasNext(); )
> return null;
> return null;
Re: XSD schema tree [message #65650 is a reply to message #61612] Sun, 08 January 2006 05:16 Go to previous messageGo to next message
Originally posted by: erezh.magicsoftware.com
hi,
i'm new to the XSD schema infoset API.
can u help me just extract the tree information from a given schema file?
a simple example would be appreciated (via email as well).
10x
erez
Re: XSD schema tree [message #65670 is a reply to message #65650] Sun, 08 January 2006 05:18 Go to previous messageGo to next message
my email is erezh@magicsoftware.com
Re: XSD schema tree [message #65712 is a reply to message #65650] Mon, 09 January 2006 10:34 Go to previous message
Hi Erez,
I'd invite you look at the samples in the org.eclipse.xsd.example
plug-in. XSDMainExample is a good place to start. If you get stuck,
please feel free to come back here and ask specific questions.
Dave
Re: XSD schema tree [message #595689 is a reply to message #61612] Tue, 14 June 2005 12:24 Go to previous message
Robert,
Robert wrote:
> tree from schema.
> Robert
Re: XSD schema tree [message #595752 is a reply to message #61660] Tue, 21 June 2005 01:29 Go to previous message
Hi Ed Merks,
/envelope
/envelope
* @author tatinip
try
return status;
throw ioe;
}catch(Exception e)
throw e;
URI uri;
specified",0,0);
m_modelName);
return true;
Found",0,0);
return true;
if (file.isFile())
else
Boolean.TRUE);
i.hasNext(); )
//Handle Error
return false;
root element
while(i.hasNext()){
element
break;
return true;
return false;
i.hasNext(); )
root element
m_isRoot = true;
}else{
flag = false;
* @param item
* @param level
xPath)
try{
printTree(xPath);
// For a reference
restrictions etc
xPath);
/*for(Iterator j =
j.hasNext(); )
xPath);
else
xPath);
else
else
else
i.hasNext(); )
} else
xPath);
level, xPath);
else
XSDInclude,
if(item != null)
}catch(Exception e)
m_isRoot = false;
} else
} else
else // default
* @param p
* @param level
}else {
else
//XSDTerm
//XSDWildcard
try {
A.XSD
(GXS) -->
<xsd:sequence>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
B.XSD
<xsd:sequence>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
C.XSD
</xsd:restriction>
</xsd:simpleType>
<xsd:sequence>
<xsd:choice>
</xsd:choice>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
Thanks for Help.
Robert
Re: XSD schema tree [message #595775 is a reply to message #61804] Tue, 21 June 2005 08:08 Go to previous message
Robert,
/envelope
Robert wrote:
> Hi Ed Merks,
> /envelope
> /envelope
> * @author tatinip
> try
> return status;
> throw ioe;
> }catch(Exception e)
> { throw e;
> URI uri;
> return true;
> Not Found",0,0);
> return true;
> if (file.isFile())
> else
> Boolean.TRUE);
> i.hasNext(); )
> //Handle Error
> return false;
> // If the user not
> while(i.hasNext()){
> m_rootElementName =
> break;
> return true;
> return false;
> i.hasNext(); )
> m_isRoot = true;
> }else{
> flag = false;
> * @param item
> * @param level
> String xPath)
> try{
> printTree(xPath);
> root header,
> // For a reference
> level, xPath);
> same XSD file
> element refers to
> i.hasNext(); )
> /*for(Iterator j =
> j.hasNext(); )
> xPath);
> else
> level, xPath);
> xPath);
> else
> i.hasNext(); )
> else
> else
> for(Iterator i =
> } else
> for(Iterator i =
> level, xPath);
> else
> if(item != null)
> item.toString());
> }catch(Exception e)
> m_isRoot = false;
> } else
> } else
> else // default
> * @param p
> * @param level
> }else {
> xPath);
> level, xPath);
> i.hasNext(); )
> else
> //XSDTerm
> //XSDWildcard
> try {
> A.XSD
> Param (GXS) -->
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> B.XSD
> <xsd:sequence>
> minOccurs="0"/>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> C.XSD
> </xsd:restriction>
> </xsd:simpleType>
> <xsd:sequence>
> <xsd:choice>
> </xsd:choice>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> Thanks for Help.
> Robert
<html>
<head>
</head>
Robert,<br>
<br>
</blockquote>
I wonder if
Re: XSD schema tree [message #595783 is a reply to message #61854] Tue, 21 June 2005 08:19 Go to previous message
Hi Ed Merks,
Robert.
Re: XSD schema tree [message #595806 is a reply to message #61879] Tue, 21 June 2005 09:12 Go to previous message
Robert,
Eclipse 3.0.0.
Robert wrote:
> Hi Ed Merks,
> Robert.
<html>
<head>
</head>
Robert,<br>
<br>
</blockquote>
Re: XSD schema tree [message #595818 is a reply to message #61932] Tue, 21 June 2005 09:34 Go to previous message
Hi Ed Merks,
Thanks again
Robert.
Re: XSD schema tree [message #595888 is a reply to message #61954] Wed, 29 June 2005 09:43 Go to previous message
HI Ed Merks,
names.
Robert
URI uri;
if (file.isFile())
else
Boolean.TRUE);
i.hasNext(); )
if (elist != null){
return null;
return null;
Re: XSD schema tree [message #595894 is a reply to message #62116] Wed, 29 June 2005 17:36 Go to previous message
Robert,
Robert wrote:
> HI Ed Merks,
> names.
> Thanks
> Robert
> IOException{
> URI uri;
> if (file.isFile())
> else
> Boolean.TRUE);
> for (Iterator i =
> if (elist != null){
> ie.hasNext(); )
> return null;
> return null;
Re: XSD schema tree [message #597425 is a reply to message #61612] Sun, 08 January 2006 05:16 Go to previous message
hi,
10x
erez
Re: XSD schema tree [message #597433 is a reply to message #65650] Sun, 08 January 2006 05:18 Go to previous message
Re: XSD schema tree [message #597444 is a reply to message #65650] Mon, 09 January 2006 10:34 Go to previous message
Hi Erez,
Dave
Previous Topic:XSD:How to extract xsd:simpleContent ?
Next Topic:XSD:How to extract xsd:simpleContent ?
Current Time: Thu Nov 06 17:20:10 EST 2025
Powered by FUDForum. Page generated in 0.50891 seconds
