Home » Eclipse Projects » GEF » draw2d.text strange behaviour
draw2d.text strange behaviour [message #61456] Mon, 03 February 2003 10:52 Go to next message
My app creates BlockFlows at runtime, I noticed that first two ones were
placed correctly, after that appeared some gap between blocks, the more
blocks the huge gap. I looked at TextExample in draw2d.examples and saw
similar picture - there are gaps between last blocks. I suspect that this
happens because ParagraphTextLayout calls context.getCurrentLine and
indirectly creates new line. This happens in BlockFlowLayout.layoutChildren
and this new line height is added to block size each layout call.
WBR Kir
Re: draw2d.text strange behaviour [message #61526 is a reply to message #61456] Mon, 03 February 2003 13:23 Go to previous message
Thanks, I found the problem in BlockBox. It used to override unionInfo, and
only update its width and height. Now it is updating its x and y locations
too, which was done for centered/right-aligned text.
"Kirill Paliy" <kpaliy@aaanet.ru> wrote in message
news:b1m238$g4$1@rogue.oti.com...
> WBR Kir
Previous Topic:View & Toolbar
Next Topic:Rotate a Label
Current Time: Fri Nov 07 01:39:14 EST 2025
Powered by FUDForum. Page generated in 0.06504 seconds
