draw2d.text strange behaviour [message #61456] |
Mon, 03 February 2003 10:52  |
My app creates BlockFlows at runtime, I noticed that first two ones were
placed correctly, after that appeared some gap between blocks, the more
blocks the huge gap. I looked at TextExample in draw2d.examples and saw
similar picture - there are gaps between last blocks. I suspect that this
happens because ParagraphTextLayout calls context.getCurrentLine and
indirectly creates new line. This happens in BlockFlowLayout.layoutChildren
and this new line height is added to block size each layout call.
WBR Kir
Re: draw2d.text strange behaviour [message #61526 is a reply to message #61456] |
Mon, 03 February 2003 13:23  |
Thanks, I found the problem in BlockBox. It used to override unionInfo, and
only update its width and height. Now it is updating its x and y locations
too, which was done for centered/right-aligned text.
"Kirill Paliy" <kpaliy@aaanet.ru> wrote in message
news:b1m238$g4$1@rogue.oti.com...
> WBR Kir
FUDForum. Page generated in 0.08400 seconds
