Home » Newcomers » Newcomers » .metadata damaged
.metadata damaged [message #61402] Fri, 06 May 2005 22:04 Go to next message
Originally posted by: kangkang.interchange.ubc.ca
Hi, I guess I damaged the .metadata directory in the workspace. Although my
projects are physically there in the workspace directory, they don't show up
in the java perspective/package explorer etc. anymore. How could I recover
these projects?
thanks,
-Kay
Re: .metadata damaged [message #61498 is a reply to message #61402] Sat, 07 May 2005 09:39 Go to previous messageGo to next message
Originally posted by: vikram_n_a.yahoo.co.in
No problems.
delete the complete .metadata from the file system and start eclipse
point to the same workspace folder.
goto file--> import-> external project into workspace and select the
projects one at a time and press finish
do this for all the projects one by one.
Re: .metadata damaged [message #62180 is a reply to message #61402] Mon, 09 May 2005 14:32 Go to previous messageGo to next message
> these projects?
If you just start the process of re-creating the Project(s) using the
same name, Eclipse will recognize that there are already .project and
..classpath files there and use them.
HTH,
Eric
Re: .metadata damaged [message #67855 is a reply to message #62180] Mon, 23 May 2005 16:53 Go to previous messageGo to next message
thanks you guys very much...But my cvs info seems lost, and I had some
un-checked in changes before my system crash so I don't want to just check
out the projects from the cvs but somehow relink the local projects with
the cvs repository.
thanks,
-Kay
Re: .metadata damaged [message #67877 is a reply to message #67855] Mon, 23 May 2005 17:14 Go to previous message
sharing the project again seems solving the problem.
thanks,
-Kay
Previous Topic:Can I have the same file in two tiles?
Next Topic:Can't run SWT
Current Time: Sat Nov 08 05:44:04 EST 2025
Powered by FUDForum. Page generated in 0.13376 seconds
