Home » Newcomers » Newcomers » Building Eclipse Problem
Building Eclipse Problem [message #61380] Fri, 06 May 2005 20:18 Go to next message
Originally posted by: viet.pham.sun.com
Hi All,
I am compiling eclipse for SPARC on Solaris 10 following exactly the
instruction at:
http://www.eclipse.org/downloads/index.php
and using the following command:
$ build -os solaris -ws motif -arch sparc
Here is the error I got:
build: ANT_OPTS=-Xmx1000M: is not an identifier
Google "build: ANT_OPTS=-Xmx1000M: is not an identifier" does not return
even one link. Any help is greatly appreciated.
If this is not the right mailing list, please forward to the right one
or tell me which mailing list I should register for this kind of question.
Thanks.
Re: Building Eclipse Problem [message #61522 is a reply to message #61380] Sat, 07 May 2005 15:46 Go to previous message
Originally posted by: myersj.gmail.com
You should probably ask this question in the eclipse.platform newsgroup.
- Jeff
Viet Pham wrote:
> Hi All,
> instruction at:
> Thanks.
Previous Topic:Automaticly implement an Interface or a Subclass
Next Topic:Eclipse (on Linux) is slow and freezes (doesn't repaint) 2 or 3 times a day
Current Time: Fri Nov 07 05:26:33 EST 2025
Powered by FUDForum. Page generated in 0.08283 seconds
