| RCP roduct Launch fails when defining "-configuration" switch [message #61374] |
Wed, 13 May 2009 04:36  |
when we define the "-configuration" switch as a program argument inside a
product.launcher file, then the product fails to start (only) when
launched from inside the eclipse IDE.
Example:
-data
"@user.home/Client"
-user
"@user.home/Client"
-configuration
"@user.home/Client/configuration"
The product creates the configuration area, but seems that it cannot
locate it's runtime files:
java.lang.IllegalStateException: Unable to acquire application service.
Ensure that the org.eclipse.core.runtime bundle is resolved and started
(see config.ini).
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
If Product is being exported, then all runs fine - it does only not start
when launched from inside eclipse.
Tested with Eclipse 3.4.2 and Eclipse 3.5M6.
Any help appreciated....
| Re: RCP roduct Launch fails when defining "-configuration" switch [message #597413 is a reply to message #61374] |
Wed, 13 May 2009 14:12  |
Rhodan76 wrote:
> Hello,
> a product.launcher file, then the product fails to start (only) when
Ok.
> start when launched from inside eclipse.
That error implies that core.runtime isn't started.
Can you post your product definition here? That could help debug the issue.
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
| Re: RCP roduct Launch fails when defining "-configuration" switch [message #597516 is a reply to message #61560] |
Fri, 15 May 2009 02:53  |
Ok, no problem. Steps to reproduce:
1. create the example HelloWorld RCP plugin
2. create an product.launch configuration an configure it
3. add -configuration switch to the programm arguments of the
launch-configuration
launch-configuration used in my example:
<?pde version="3.4"?>
<product name="Hello World" id="org.eclipse.rcp.hello.world.product"
application="hello.world.application" version="1.0" useFeatures="false">
<configIni use="default">
</configIni>
<launcherArgs>
<programArgs>-configuration
"@user.home/Hello World/config"</programArgs>
<vmArgsMac>-XstartOnFirstThread
-Dorg.eclipse.swt.internal.carbon.smallFonts</vmArgsMac>
</launcherArgs>
<launcher>
<solaris/>
<win useIco="false">
<bmp/>
</win>
</launcher>
<vm>
</vm>
<plugins>
<plugin id="com.ibm.icu"/>
<plugin id="org.eclipse.core.commands"/>
<plugin id="org.eclipse.core.contenttype"/>
<plugin id="org.eclipse.core.databinding"/>
<plugin id="org.eclipse.core.expressions"/>
<plugin id="org.eclipse.core.jobs"/>
<plugin id="org.eclipse.core.runtime"/>
<plugin id="org.eclipse.core.runtime.compatibility.registry"
fragment="true"/>
<plugin id="org.eclipse.equinox.app"/>
<plugin id="org.eclipse.equinox.common"/>
<plugin id="org.eclipse.equinox.preferences"/>
<plugin id="org.eclipse.equinox.registry"/>
<plugin id="org.eclipse.help"/>
<plugin id="org.eclipse.jface"/>
<plugin id="org.eclipse.jface.databinding"/>
<plugin id="org.eclipse.osgi"/>
<plugin id="org.eclipse.rcp.hello.world"/>
<plugin id="org.eclipse.swt"/>
<plugin id="org.eclipse.swt.win32.win32.x86" fragment="true"/>
<plugin id="org.eclipse.ui"/>
<plugin id="org.eclipse.ui.workbench"/>
</plugins>
</product>
Resulting error message:
!SESSION Fri May 15 08:32:54 CEST 2009
!ENTRY org.eclipse.equinox.launcher 4 0 2009-05-15 08:32:54.087
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.ClassNotFoundException:
at java.net.URLClassLoader$1.run(URLClassLoader.java:200)
at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 546)
FUDForum. Page generated in 0.04318 seconds
