Home » Eclipse Projects » GEF » View & Toolbar
View & Toolbar [message #61338] Mon, 03 February 2003 04:55 Go to next message
Originally posted by: jan.odvarko.schemantix.com
Hi All,
I have created a custom view (derived fromViewPart class),
which uses action toolbar (I am using IToolBarManager). Further
I have added some actions into to toolbar (simply by add
method) and it works well.
The question is, how can I visually check the button within
that toolbar in order to indicate, that the action is active? Just
to note that the action stands as a switch (on, off).
I have called the setChecked(true) method on the action object,
however the button is still not checked. Should I refresh or
somehow update the toolbar buttons?
thanks
cheers
Honza
Re: View & Toolbar [message #61362 is a reply to message #61338] Mon, 03 February 2003 05:16 Go to previous messageGo to next message
I would just make 2 Icons (for on and off) and call setImageDescriptor() /
setHoverImageDescriptor everytime the button changes state. That is no
problem if the state change is triggered from the run-method of your action.
If not, you need some way to obtain a reference to your action to be able to
tell your button to change state.
"Jan Odv
Re: View & Toolbar [message #61410 is a reply to message #61338] Mon, 03 February 2003 08:35 Go to previous message
setChecked should be sufficient. Make call this method before adding the
action to the toolbarmanager.
Notice that by setting the checked state you are changing the result of
getStyle(), which is used when creating the ToolItem.
"Jan Odv
Previous Topic:Layout in Circuit Figure
Next Topic:draw2d.text strange behaviour
Current Time: Mon Jul 21 21:46:44 EDT 2025
Powered by FUDForum. Page generated in 0.05600 seconds
