Home » Modeling » BPEL Designer » BPEL namespace
BPEL namespace [message #5461] Wed, 16 August 2006 06:10 Go to next message
I have another question about BPEL parser. As I've noticed parser
produces almost empty Process object if bpws namespace is
"http://schemas.xmlsoap.org/ws/2003/03/business-process/", e.g. process
doesn't have variables and so on. If I change namespace to
"http://schemas.xmlsoap.org/ws/2004/03/business-process/" parsing goes well.
As I know correct namespace is
"http://schemas.xmlsoap.org/ws/2003/03/business-process/". Could you give me
a hint?
Rykovanov Dmitri
Re: BPEL namespace [message #5468 is a reply to message #5461] Wed, 16 August 2006 10:52 Go to previous messageGo to next message
I have also seen this issue...
If I understand correctly, the "2003" schema is for bpel 1.1, and the "2004"
is for BPEL 2.0.
The eclipse designer is only for 2.0, thus I think it stops when it sees the
1.1 namespace.
Others can correct me if I am wrong.....
-BIll Murray
"Rykovanov Dmitrii" <drykovan@abisoft.spb.ru> wrote in message
news:ebuqv1$dec$1@utils.eclipse.org...
> well.
> me
> a hint?
> Rykovanov Dmitri
Re: BPEL namespace [message #5510 is a reply to message #5468] Mon, 21 August 2006 13:54 Go to previous messageGo to next message
> is for BPEL 2.0.
> 1.1 namespace.
> -BIll Murray
>> well.
>> me
>> a hint?
>> Rykovanov Dmitri
A bit of history:
"http://schemas.xmlsoap.org/ws/2003/03/business-process/" was the
namespace from BPEL 1.0.
"http://schemas.xmlsoap.org/ws/2004/03/business-process/" was the
namespace from BPEL 1.1.
The model will only support BPEL 2.0 files (i.e. no backwards
compatibility) by design. The file you're trying to load is undoubtedly
a BPEL 1.0 file.
If OASIS changes the namespace before they finalize the 2.0 spec (e.g.
change "2004" to "2006" or whatever), then we'll use this new namespace
immediately.
james
Re: BPEL namespace [message #5514 is a reply to message #5510] Tue, 22 August 2006 03:38 Go to previous messageGo to next message
Originally posted by: mars.abcsolution.co.kr
James Moody wrote:
> A bit of history:
But they return 404 error code when I open the 2004 namespace url. Is it
normal that they don't have a real schema for 2004 namespace? I just wonder
what's going on as a newbie here.
BTW would you tell me where I can reference the BPEL 2.0 standard candidate
or draft or whatever?
Re: BPEL namespace [message #5515 is a reply to message #5514] Tue, 22 August 2006 10:05 Go to previous message
??? /Yi Dong-ryon/ wrote:
> James Moody wrote:
>> A bit of history:
The idea with namespaces is that it's just a namespace - it doesn't have
to correspond to a file on the world wide web. It's just a name.
The BPEL 2.0 work is going on on the OASIS web site - you can find a
link here:
http://www.oasis-open.org/committees/tc_home.php?wg_abbrev=w sbpel
If you click on "Documents", then you can find their most recent draft
versions.
Hope this helps!
james
Previous Topic:Co-lead announcement
Next Topic:example not working
Current Time: Tue Jul 15 12:34:56 EDT 2025
Powered by FUDForum. Page generated in 0.06174 seconds
