Home » Eclipse Projects » Eclipse Platform » disable menu bar
disable menu bar [message #61296] Tue, 03 June 2003 15:10 Go to next message
Originally posted by: bella_voldman.yahoo.com
I was wondering if there is a way to disable the menu bar in the eclipse
application itself. I have found a way to remove the tool bar (thanks to
Don Estberg’s post Apr 29 2003 18:40:46 in eclipse.tools) using
org.eclipse.ui.workbench/SHOW_TOOL_BAR=false. But I couldn’t find a
similar property for the menu bar.
Also, is there a way to “lock” the perspective, i.e. prevent the user from
opening/closing views?
Thank you in advance
Bella
Re: disable menu bar [message #61396 is a reply to message #61296] Tue, 03 June 2003 15:38 Go to previous messageGo to next message
Originally posted by: simon.ibm.oti.lab
There is no support to disable the menu bar. There is also no support for
locking the perspective.
Maybe you could provide more information about what you are trying to do.
Are you building a plugin that will run in Eclipse? Or are you simply using
part of Eclipse to write some standalone application
Simon :-)
"Bella" <bella_voldman@yahoo.com> wrote in message
news:bbirrn$7th$1@rogue.oti.com...
> Hello,
> Don Estberg's post Apr 29 2003 18:40:46 in eclipse.tools) using
> org.eclipse.ui.workbench/SHOW_TOOL_BAR=false. But I couldn't find a
> Also, is there a way to "lock" the perspective, i.e. prevent the user from
> Bella
Re: disable menu bar [message #61421 is a reply to message #61396] Tue, 03 June 2003 15:50 Go to previous messageGo to next message
I wanted to use Eclipse's editor, and so I am launching Eclipse from my
swing based application. But, for example, the navigator view will
conflict with the tree I have in my application. I have figured out a way
to have the initial perspective display only the editor. But I would like
to prevent the user from accidentally (or purposefully) opening other
views, like the navigator.
Any suggestions will be appreciated
Bella
> Simon :-)
> > Hello,
> > Bella
Re: disable menu bar [message #62526 is a reply to message #61421] Wed, 04 June 2003 11:45 Go to previous message
Beside "hacking" the eclipse code, there is nothing else I can think of. You
may want to keep an eye on the work for the rich client platform.
Simon :-)
news:bbiu64$9ug$1@rogue.oti.com...
> Bella
for
do.
using
> > Simon :-)
> > > Hello,
eclipse
to
from
> > > Bella
Previous Topic:adding menuitem to the "Open With" sub menu in Popup Menu of the resource navigator view
Next Topic:Branding Eclipse
Current Time: Sat Jul 19 02:19:52 EDT 2025
Powered by FUDForum. Page generated in 0.03577 seconds
