Home » Archived » Visual Editor (VE) » VE 1.0.1 SWT SUPPORT
VE 1.0.1 SWT SUPPORT [message #61281] Mon, 27 September 2004 05:59 Go to next message
After migration to eclipse 3 only to be able to use VE 1.0.1 i found some
problems:
i.e: (SWT components) add composite->add button--> add event to
button-->!!!
button.addActionListener(java.awt.event.ActionListener()) has been
added to swt button (???) (event added from Java Beans view)
i.e: in Properties view i can set a label for an swt button, this
generates a
button.setLabel() statement in the code instead of button.setText()
It seems to me VE handles the swt button as a swing jbutton.
Re: VE 1.0.1 SWT SUPPORT [message #61353 is a reply to message #61281] Mon, 27 September 2004 06:48 Go to previous message
Originally posted by: myersj.nospam.gmail.com
> problems:
> button-->!!!
> generates a
Hi Lrv,
You must use a Java runtime version 1.4.2 or above when working with
SWT. Versions previous to that contained a bug with the bean info
implementation that causes confusion between AWT and SWT classes.
- Jeff
Re: VE 1.0.1 SWT SUPPORT [message #599586 is a reply to message #61281] Mon, 27 September 2004 06:48 Go to previous message
> problems:
> button-->!!!
> generates a
Hi Lrv,
- Jeff
Previous Topic:code generation for Swing
Next Topic:[ANN] Eclipse Visual Editor 1.0 Released
Current Time: Sun Jul 13 20:18:27 EDT 2025
Powered by FUDForum. Page generated in 0.61068 seconds
