Home » Archived » XML Schema Definition (XSD) » Creating complexType with simpleContent
Creating complexType with simpleContent [message #61274] Wed, 08 June 2005 13:43 Go to next message
I'm trying to construct a schema via the API, where a complexType extends a
simpleType (maybe indirectly via another complexType with simpleContent). I
can't get the output XSD file to produce <simpleContent> in that
complexType.
For example, a small excerpt from OAGIS 8.0 schema:
<xs:complexType name="Name">
<xs:simpleContent>
<xs:extension base="LingualString"/>
</xs:simpleContent>
</xs:complexType>
<xs:complexType name="LingualString">
<xs:simpleContent>
<xs:extension base="xs:string">
<xs:attribute name="lang" type="xs:language"/>
</xs:extension>
</xs:simpleContent>
</xs:complexType>
Reviewing the XSDPrototypicalSchema.java example, simpleContent is produced
only by adding an anonymous simpleType as content. I tried setting the
contentTypeCategory directly, but no affect on the generated schema.
complexType.setContentTypeCategory(XSDContentTypeCategory.SI MPLE_LITERAL);
I always get <xs:complexContent> in both of these types, which is incorrect.
Is this a bug? I am using EMF/XSD 2.1 20050428 build.
Dave Carlson
Re: Creating complexType with simpleContent [message #61298 is a reply to message #61274] Wed, 08 June 2005 13:49 Go to previous messageGo to next message
Dave,
Yes, you must do it as shown in the XSDPrototypicalSchema example. The
anonymous simple type is just part of the syntax (i.e., it corresponds
to <xs:simpleContent> which has a grammar much like that for
<xs:simpleType>) and doesn't become part of the abstract component model
in the case of simple extension.
>complexType.
><xs:simpleContent>
></xs:simpleContent>
></xs:complexType>
><xs:simpleContent>
></xs:extension>
></xs:simpleContent>
></xs:complexType>
>Thanks,
> Dave Carlson
Re: Creating complexType with simpleContent [message #61321 is a reply to message #61298] Thu, 09 June 2005 13:20 Go to previous messageGo to next message
Hi Ed,
I'm still stuck on this one... as far as I can see, I have exactly the same
code as used in the prototypical example, and I now get the simpleContent,
but the base type is always written as xsd:anyType in the output. In the
debugger, anonymousSimpleTypeDefinition shows its base type set correctly as
"string" with the XSD namespace. But output as:
<xsd:complexType name="LingualString">
<xsd:simpleContent>
<xsd:extension base="xsd:anyType"/>
</xsd:simpleContent>
</xsd:complexType>
Here is the code I used:
XSDSchema xsdSchema = XSDFactory.eINSTANCE.createXSDSchema();
xsdSchema.setSchemaForSchemaQNamePrefix("xsd");
Map qNamePrefixToNamespaceMap =
xsdSchema.getQNamePrefixToNamespaceMap();
qNamePrefixToNamespaceMap.put(xsdSchema.getSchemaForSchemaQN amePrefix(),
XSDConstants.SCHEMA_FOR_SCHEMA_URI_2001);
xsdSchema.setTargetNamespace("http://www.test.com/testsimple");
qNamePrefixToNamespaceMap.put("con", "http://www.test.com/testsimple");
XSDComplexTypeDefinition complexType =
XSDFactory.eINSTANCE.createXSDComplexTypeDefinition();
complexType.setName("LingualString");
complexType.setDerivationMethod(XSDDerivationMethod.EXTENSIO N_LITERAL);
XSDSimpleTypeDefinition xsdBaseType =
xsdSchema.getSchemaForSchema().resolveSimpleTypeDefinition("string ");
XSDSimpleTypeDefinition anonymousSimpleTypeDefinition =
XSDFactory.eINSTANCE.createXSDSimpleTypeDefinition();
anonymousSimpleTypeDefinition.setBaseTypeDefinition(xsdBaseT ype);
complexType.setContent(anonymousSimpleTypeDefinition);
xsdSchema.getContents().add(complexType);
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:d87b2q$lpi$1@news.eclipse.org...
> Dave,
> anonymous simple type is just part of the syntax (i.e., it corresponds to
> <xs:simpleContent> which has a grammar much like that for <xs:simpleType>)
> and doesn't become part of the abstract component model in the case of
> simple extension.
>>a simpleType (maybe indirectly via another complexType with
>>simpleContent). I can't get the output XSD file to produce
>><simpleContent> in that complexType.
>><xs:simpleContent>
>></xs:simpleContent>
>></xs:complexType>
>><xs:simpleContent>
>></xs:extension>
>></xs:simpleContent>
>></xs:complexType>
>>produced only by adding an anonymous simpleType as content. I tried
>>setting the contentTypeCategory directly, but no affect on the generated
>>schema.
>>incorrect. Is this a bug? I am using EMF/XSD 2.1 20050428 build.
>>Thanks,
>> Dave Carlson
Re: Creating complexType with simpleContent [message #61343 is a reply to message #61298] Thu, 09 June 2005 13:28 Go to previous messageGo to next message
Hi Ed,
I'm still stuck on this one... as far as I can see I'm using the same code
as the prototypical example, and I now get simpleContent, but the base type
is always written as xsd:anyType in the output. In the debugger
anonymousSimpleTypeDefinition shows its baseTypeDefinition set correctly to
"string" with the XSD namespace. I get this output:
<xsd:simpleContent>
</xsd:complexType>
> Dave,
> simple extension.
>><xs:simpleContent>
>></xs:simpleContent>
>></xs:complexType>
>><xs:simpleContent>
>></xs:extension>
>></xs:simpleContent>
>></xs:complexType>
>>schema.
>>Thanks,
>> Dave Carlson
Re: Creating complexType with simpleContent [message #61364 is a reply to message #61343] Thu, 09 June 2005 14:00 Go to previous messageGo to next message
--------------080408000806010200010005
Dave,
Changing this should do the trick:
//anonymousSimpleTypeDefinition.setBaseTypeDefinition(xsdBas eType);
complexType.setBaseTypeDefinition(xsdBaseType);
Dave Carlson wrote:
>Hi Ed,
> <xsd:simpleContent>
></xsd:complexType>
>xsdSchema.getSchemaForSchema().resolveSimpleTypeDefinition( "string");
>>Dave,
>>simple extension.
>>><xs:simpleContent>
>>></xs:simpleContent>
>>></xs:complexType>
>>><xs:simpleContent>
>>></xs:extension>
>>></xs:simpleContent>
>>></xs:complexType>
>>>schema.
>>>Thanks,
>>> Dave Carlson
<html>
<head>
</head>
Dave,<br>
<br>
Changing&nbsp; this should do the trick:<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;
//anonymousSimpleTypeDefinition.setBaseTypeDefinition(xsdBas eType); <br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; complexType.setBaseTypeDefinition(xsdBaseType);<br>
<br>
<br>
Dave Carlson wrote:
<blockquote cite="midd89u8a$ljb$1@news.eclipse.org" type="cite">
<pre wrap="">Hi Ed,
&lt;xsd:complexType name="LingualString"&gt;
&lt;xsd:simpleContent&gt;
&lt;xsd:extension base="xsd:anyType"/&gt;
&lt;/xsd:simpleContent&gt;
&lt;/xsd:complexType&gt;
xsdSchema.setTargetNamespace(<a class="moz-txt-link-rfc2396E" href="http://www.test.com/testsimple">"http://www.test.com/testsimple"</a>);
qNamePrefixToNamespaceMap.put("con", <a class="moz-txt-link-rfc2396E" href="http://www.test.com/testsimple">"http://www.test.com/testsimple"</a>);
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:d87b2q$lpi$1@news.eclipse.org">news:d87b2q$lpi$1@news.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Dave,
&lt;xs:simpleContent&gt; which has a grammar much like that for &lt;xs:simpleType&gt;)
simple extension.
Dave Carlson wrote:
</pre>
<pre wrap="">I'm trying to construct a schema via the API, where a complexType extends
&lt;simpleContent&gt; in that complexType.
&lt;xs:complexType name="Name"&gt;
&lt;xs:extension base="LingualString"/&gt;
&lt;/xs:simpleContent&gt;
&lt;/xs:complexType&gt;
&lt;xs:complexType name="LingualString"&gt;
&lt;xs:extension base="xs:string"&gt;
&lt;xs:attribute name="lang" type="xs:language"/&gt;
&lt;/xs:extension&gt;
schema.
I always get &lt;xs:complexContent&gt; in both of these types, which is
Dave Carlson
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------080408000806010200010005--
Re: Creating complexType with simpleContent [message #61388 is a reply to message #61364] Thu, 09 June 2005 14:17 Go to previous message
------=_NextPart_000_0028_01C56CED.478F26A0
charset="iso-8859-1"
Thanks Ed! It was not intuitive to create an anonymous type with no =
content and no base type, and use it it "trick" the compexType into =
interpreting its simple base type as simpleContent...
Dave
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:d8a03k$nr0$1@news.eclipse.org...
Dave,
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2900.2627" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Thanks Ed!&nbsp; It was not intuitive =
to create an=20
anonymous type with no content and no base type, and use it it "trick" =
the=20
compexType into interpreting its simple base type as=20
simpleContent...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>Dave</FONT></DIV>
<BLOCKQUOTE=20
<DIV>"Ed Merks" &lt;<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>&gt;=20
wrote in message <A=20
href=3D"news:d8a03k$nr0$1@news.eclipse.org">news:d8a03k$nr0$1@news.eclips=
e.org</A>...</DIV>Dave,<BR><BR>Changing&nbsp;=20
this should do the =
trick:<BR><BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;=20
//anonymousSimpleTypeDefinition.setBaseTypeDefinition(xsdBas eType); <BR>&n=
bsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&n bsp;=20
complexType.setBaseTypeDefinition(xsdBaseType);<BR><BR><BR ></BLOCKQUOTE><=
/BODY></HTML>
------=_NextPart_000_0028_01C56CED.478F26A0--
Re: Creating complexType with simpleContent [message #595544 is a reply to message #61274] Wed, 08 June 2005 13:49 Go to previous message
Dave,
>complexType.
><xs:simpleContent>
></xs:simpleContent>
></xs:complexType>
><xs:simpleContent>
></xs:extension>
></xs:simpleContent>
></xs:complexType>
>Thanks,
> Dave Carlson
Re: Creating complexType with simpleContent [message #595552 is a reply to message #61298] Thu, 09 June 2005 13:20 Go to previous message
Hi Ed,
<xsd:simpleContent>
</xsd:complexType>
> Dave,
> simple extension.
>><xs:simpleContent>
>></xs:simpleContent>
>></xs:complexType>
>><xs:simpleContent>
>></xs:extension>
>></xs:simpleContent>
>></xs:complexType>
>>schema.
>>Thanks,
>> Dave Carlson
Re: Creating complexType with simpleContent [message #595557 is a reply to message #61298] Thu, 09 June 2005 13:28 Go to previous message
Hi Ed,
<xsd:simpleContent>
</xsd:complexType>
> Dave,
> simple extension.
>><xs:simpleContent>
>></xs:simpleContent>
>></xs:complexType>
>><xs:simpleContent>
>></xs:extension>
>></xs:simpleContent>
>></xs:complexType>
>>schema.
>>Thanks,
>> Dave Carlson
Re: Creating complexType with simpleContent [message #595568 is a reply to message #61343] Thu, 09 June 2005 14:00 Go to previous message
Dave,
Dave Carlson wrote:
>Hi Ed,
> <xsd:simpleContent>
></xsd:complexType>
>>Dave,
>>simple extension.
>>><xs:simpleContent>
>>></xs:simpleContent>
>>></xs:complexType>
>>><xs:simpleContent>
>>></xs:extension>
>>></xs:simpleContent>
>>></xs:complexType>
>>>schema.
>>>Thanks,
>>> Dave Carlson
<html>
<head>
</head>
Dave,<br>
<br>
<br>
<br>
<br>
<pre wrap="">Hi Ed,
</pre>
<pre wrap="">Dave,
simple extension.
Dave Carlson wrote:
</pre>
schema.
Dave Carlson
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Re: Creating complexType with simpleContent [message #595576 is a reply to message #61364] Thu, 09 June 2005 14:17 Go to previous message
Dave
Dave,
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
to create an=20
the=20
<BLOCKQUOTE=20
/BODY></HTML>
Previous Topic:Creating complexType with simpleContent
Next Topic:How to get elements from included schema?
Current Time: Tue Jul 15 02:31:25 EDT 2025
Powered by FUDForum. Page generated in 0.07167 seconds
