Home » Archived » XML Schema Definition (XSD) » Creating complexType with simpleContent
Creating complexType with simpleContent [message #61274] |
Wed, 08 June 2005 13:43  |
I'm trying to construct a schema via the API, where a complexType extends a
simpleType (maybe indirectly via another complexType with simpleContent). I
can't get the output XSD file to produce <simpleContent> in that
complexType.
For example, a small excerpt from OAGIS 8.0 schema:
<xs:complexType name="Name">
<xs:simpleContent>
<xs:extension base="LingualString"/>
</xs:simpleContent>
</xs:complexType>
<xs:complexType name="LingualString">
<xs:simpleContent>
<xs:extension base="xs:string">
<xs:attribute name="lang" type="xs:language"/>
</xs:extension>
</xs:simpleContent>
</xs:complexType>
Reviewing the XSDPrototypicalSchema.java example, simpleContent is produced
only by adding an anonymous simpleType as content. I tried setting the
contentTypeCategory directly, but no affect on the generated schema.
complexType.setContentTypeCategory(XSDContentTypeCategory.SI MPLE_LITERAL);
I always get <xs:complexContent> in both of these types, which is incorrect.
Is this a bug? I am using EMF/XSD 2.1 20050428 build.
Dave Carlson
Re: Creating complexType with simpleContent [message #61298 is a reply to message #61274] |
Wed, 08 June 2005 13:49   |
Dave,
Yes, you must do it as shown in the XSDPrototypicalSchema example. The
anonymous simple type is just part of the syntax (i.e., it corresponds
to <xs:simpleContent> which has a grammar much like that for
<xs:simpleType>) and doesn't become part of the abstract component model
in the case of simple extension.
>complexType.
><xs:simpleContent>
></xs:simpleContent>
></xs:complexType>
><xs:simpleContent>
></xs:extension>
></xs:simpleContent>
></xs:complexType>
>Thanks,
> Dave Carlson
Re: Creating complexType with simpleContent [message #61321 is a reply to message #61298] |
Thu, 09 June 2005 13:20   |
Hi Ed,
I'm still stuck on this one... as far as I can see, I have exactly the same
code as used in the prototypical example, and I now get the simpleContent,
but the base type is always written as xsd:anyType in the output. In the
debugger, anonymousSimpleTypeDefinition shows its base type set correctly as
"string" with the XSD namespace. But output as:
<xsd:complexType name="LingualString">
<xsd:simpleContent>
<xsd:extension base="xsd:anyType"/>
</xsd:simpleContent>
</xsd:complexType>
Here is the code I used:
XSDSchema xsdSchema = XSDFactory.eINSTANCE.createXSDSchema();
xsdSchema.setSchemaForSchemaQNamePrefix("xsd");
Map qNamePrefixToNamespaceMap =
xsdSchema.getQNamePrefixToNamespaceMap();
qNamePrefixToNamespaceMap.put(xsdSchema.getSchemaForSchemaQN amePrefix(),
XSDConstants.SCHEMA_FOR_SCHEMA_URI_2001);
xsdSchema.setTargetNamespace("http://www.test.com/testsimple");
qNamePrefixToNamespaceMap.put("con", "http://www.test.com/testsimple");
XSDComplexTypeDefinition complexType =
XSDFactory.eINSTANCE.createXSDComplexTypeDefinition();
complexType.setName("LingualString");
complexType.setDerivationMethod(XSDDerivationMethod.EXTENSIO N_LITERAL);
XSDSimpleTypeDefinition xsdBaseType =
xsdSchema.getSchemaForSchema().resolveSimpleTypeDefinition("string ");
XSDSimpleTypeDefinition anonymousSimpleTypeDefinition =
XSDFactory.eINSTANCE.createXSDSimpleTypeDefinition();
anonymousSimpleTypeDefinition.setBaseTypeDefinition(xsdBaseT ype);
complexType.setContent(anonymousSimpleTypeDefinition);
xsdSchema.getContents().add(complexType);
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:d87b2q$lpi$1@news.eclipse.org...
> Dave,
> anonymous simple type is just part of the syntax (i.e., it corresponds to
> <xs:simpleContent> which has a grammar much like that for <xs:simpleType>)
> and doesn't become part of the abstract component model in the case of
> simple extension.
>>a simpleType (maybe indirectly via another complexType with
>>simpleContent). I can't get the output XSD file to produce
>><simpleContent> in that complexType.
>><xs:simpleContent>
>></xs:simpleContent>
>></xs:complexType>
>><xs:simpleContent>
>></xs:extension>
>></xs:simpleContent>
>></xs:complexType>
>>produced only by adding an anonymous simpleType as content. I tried
>>setting the contentTypeCategory directly, but no affect on the generated
>>schema.
>>incorrect. Is this a bug? I am using EMF/XSD 2.1 20050428 build.
>>Thanks,
>> Dave Carlson
Re: Creating complexType with simpleContent [message #61343 is a reply to message #61298] |
Thu, 09 June 2005 13:28   |
Hi Ed,
I'm still stuck on this one... as far as I can see I'm using the same code
as the prototypical example, and I now get simpleContent, but the base type
is always written as xsd:anyType in the output. In the debugger
anonymousSimpleTypeDefinition shows its baseTypeDefinition set correctly to
"string" with the XSD namespace. I get this output:
<xsd:simpleContent>
</xsd:complexType>
> Dave,
> simple extension.
>><xs:simpleContent>
>></xs:simpleContent>
>></xs:complexType>
>><xs:simpleContent>
>></xs:extension>
>></xs:simpleContent>
>></xs:complexType>
>>schema.
>>Thanks,
>> Dave Carlson
Re: Creating complexType with simpleContent [message #61364 is a reply to message #61343] |
Thu, 09 June 2005 14:00   |
--------------080408000806010200010005
Dave,
Changing this should do the trick:
//anonymousSimpleTypeDefinition.setBaseTypeDefinition(xsdBas eType);
complexType.setBaseTypeDefinition(xsdBaseType);
Dave Carlson wrote:
>Hi Ed,
> <xsd:simpleContent>
></xsd:complexType>
>xsdSchema.getSchemaForSchema().resolveSimpleTypeDefinition( "string");
>>Dave,
>>simple extension.
>>><xs:simpleContent>
>>></xs:simpleContent>
>>></xs:complexType>
>>><xs:simpleContent>
>>></xs:extension>
>>></xs:simpleContent>
>>></xs:complexType>
>>>schema.
>>>Thanks,
>>> Dave Carlson
<html>
<head>
</head>
Dave,<br>
<br>
Changing this should do the trick:<br>
<br>
//anonymousSimpleTypeDefinition.setBaseTypeDefinition(xsdBas eType); <br>
complexType.setBaseTypeDefinition(xsdBaseType);<br>
<br>
<br>
Dave Carlson wrote:
<blockquote cite="midd89u8a$ljb$1@news.eclipse.org" type="cite">
<pre wrap="">Hi Ed,
<xsd:simpleContent>
</xsd:complexType>
xsdSchema.setTargetNamespace(<a class="moz-txt-link-rfc2396E" href="http://www.test.com/testsimple">"http://www.test.com/testsimple"</a>);
qNamePrefixToNamespaceMap.put("con", <a class="moz-txt-link-rfc2396E" href="http://www.test.com/testsimple">"http://www.test.com/testsimple"</a>);
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:d87b2q$lpi$1@news.eclipse.org">news:d87b2q$lpi$1@news.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Dave,
simple extension.
Dave Carlson wrote:
</pre>
<pre wrap="">I'm trying to construct a schema via the API, where a complexType extends
<xs:simpleContent>
</xs:simpleContent>
</xs:complexType>
<xs:simpleContent>
</xs:extension>
</xs:simpleContent>
</xs:complexType>
schema.
Dave Carlson
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------080408000806010200010005--
Re: Creating complexType with simpleContent [message #61388 is a reply to message #61364] |
Thu, 09 June 2005 14:17  |
------=_NextPart_000_0028_01C56CED.478F26A0
charset="iso-8859-1"
Thanks Ed! It was not intuitive to create an anonymous type with no =
content and no base type, and use it it "trick" the compexType into =
interpreting its simple base type as simpleContent...
Dave
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:d8a03k$nr0$1@news.eclipse.org...
Dave,
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2900.2627" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Thanks Ed! It was not intuitive =
to create an=20
anonymous type with no content and no base type, and use it it "trick" =
the=20
compexType into interpreting its simple base type as=20
simpleContent...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>Dave</FONT></DIV>
<BLOCKQUOTE=20
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
wrote in message <A=20
href=3D"news:d8a03k$nr0$1@news.eclipse.org">news:d8a03k$nr0$1@news.eclips=
e.org</A>...</DIV>Dave,<BR><BR>Changing =20
this should do the =
trick:<BR><BR> =20
//anonymousSimpleTypeDefinition.setBaseTypeDefinition(xsdBas eType); <BR>&n=
bsp; &n bsp;=20
complexType.setBaseTypeDefinition(xsdBaseType);<BR><BR><BR ></BLOCKQUOTE><=
/BODY></HTML>
------=_NextPart_000_0028_01C56CED.478F26A0--
Re: Creating complexType with simpleContent [message #595544 is a reply to message #61274] |
Dave,
>complexType.
><xs:simpleContent>
></xs:simpleContent>
></xs:complexType>
><xs:simpleContent>
></xs:extension>
></xs:simpleContent>
></xs:complexType>
>Thanks,
> Dave Carlson
Re: Creating complexType with simpleContent [message #595552 is a reply to message #61298] |
Hi Ed,
<xsd:simpleContent>
</xsd:complexType>
> Dave,
> simple extension.
>><xs:simpleContent>
>></xs:simpleContent>
>></xs:complexType>
>><xs:simpleContent>
>></xs:extension>
>></xs:simpleContent>
>></xs:complexType>
>>schema.
>>Thanks,
>> Dave Carlson
Re: Creating complexType with simpleContent [message #595557 is a reply to message #61298] |
Hi Ed,
<xsd:simpleContent>
</xsd:complexType>
> Dave,
> simple extension.
>><xs:simpleContent>
>></xs:simpleContent>
>></xs:complexType>
>><xs:simpleContent>
>></xs:extension>
>></xs:simpleContent>
>></xs:complexType>
>>schema.
>>Thanks,
>> Dave Carlson
Re: Creating complexType with simpleContent [message #595568 is a reply to message #61343] |
Dave,
Dave Carlson wrote:
>Hi Ed,
> <xsd:simpleContent>
></xsd:complexType>
>>Dave,
>>simple extension.
>>><xs:simpleContent>
>>></xs:simpleContent>
>>></xs:complexType>
>>><xs:simpleContent>
>>></xs:extension>
>>></xs:simpleContent>
>>></xs:complexType>
>>>schema.
>>>Thanks,
>>> Dave Carlson
<html>
<head>
</head>
Dave,<br>
<br>
<br>
<br>
<br>
<pre wrap="">Hi Ed,
<xsd:simpleContent>
</xsd:complexType>
</pre>
<pre wrap="">Dave,
simple extension.
Dave Carlson wrote:
</pre>
<xs:simpleContent>
</xs:simpleContent>
</xs:complexType>
<xs:simpleContent>
</xs:extension>
</xs:simpleContent>
</xs:complexType>
schema.
Dave Carlson
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Re: Creating complexType with simpleContent [message #595576 is a reply to message #61364] |
Dave
Dave,
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
to create an=20
the=20
<BLOCKQUOTE=20
trick:<BR><BR> =20
bsp; &n bsp;=20
/BODY></HTML>
Current Time: Wed Jul 16 09:59:45 EDT 2025
Powered by FUDForum. Page generated in 0.11394 seconds
