Home » Archived » Test and Performance Tools Platform (TPTP) » GUI recorder - wait until job completed
GUI recorder - wait until job completed [message #61263] Tue, 28 March 2006 11:32 Go to next message
Originally posted by: vladimir.au.ru
- I've tried to use GUI recorder for my test scenario, but I can't find
the way how to wait until particular job completed. For instance, during
long-run operation
" org.eclipse.ui.internal.progress.ProgressMonitorFocusJobDial og " appears
and I need to wait while when the job completed and dialog closed. I've
tried to use <command type="wait"/> but test failed with the following
exception:
A time-out occurred while waiting for the nested shell
org.eclipse.ui.internal.progress.ProgressMonitorFocusJobDial og to
complete. It is likely caused by the absence of the shell.
- I want to execute my test cases in the loop and measure time of
execution for every (or particular) step. Is it possible with TPTP?
Thanks in advance,
Vladimir.
Re: GUI recorder - wait until job completed [message #61378 is a reply to message #61263] Tue, 28 March 2006 11:57 Go to previous messageGo to next message
Vladimir,
There is a time-out threshold under the behavior page that you can adjust.
The default time-out period is 30 seconds.
You can also define wait commands based on a wait period.
e.g. <command type="wait" time-to-wait="5000"/> will cause a 5 second delay.
Alternatively, <command type="wait"/> will cause a wait until all user
Eclipse jobs are complete.
You can't do profiling with AGR but if you look at the execution history
file, a start and stop event is reported for each invocation. That's the
only time-stamp information that is reported.
"Vladimir" <vladimir@au.ru> wrote in message
news:995ad7af3aa6fb2718cee2397aeda17e$1@www.eclipse.org...
> long-run operation
> exception:
> Thanks in advance,
> Vladimir.
Re: GUI recorder - wait until job completed [message #61429 is a reply to message #61378] Tue, 28 March 2006 12:18 Go to previous messageGo to next message
Ali, thanks for the answer.
Ali Mehregani wrote:
> Vladimir,
I've tried again, and TPTP not waited until job completed. I use TPTP
version 4.1.0 with eclipse 3.1.2.
Here is parts from my test script (I try to import data from CVS to
existing project):
<macro version="0.1" >
<shell id="org.eclipse.ui.internal.WorkbenchWindow" return-code="-1">
<command type="focus"
contextId="view/org.eclipse.jdt.ui.PackageExplorer"
widgetId="org.eclipse.swt.widgets.Composite#1"/>
<command type="select"
contextId=" popup/view/org.eclipse.jdt.ui.PackageExplorer/org.eclipse.sw t.widgets.Tree#{{/}}-{{1.0}} "
widgetId="contribid/import13"/>
<shell id="org.eclipse.jface.wizard.WizardDialog" return-code="0">
<command type="item-select"
contextId="wizard-page/singleWizardSelectionPage"
widgetId="org.eclipse.swt.widgets.Table#1">
<item
path=" org.eclipse.swt.widgets.TableItem#{{org.eclipse.team.cvs.ui. newProjectCheckout}}-{{1.0}} "/>
</command>
widgetId="org.eclipse.swt.widgets.Table#1"/>
<command type="select" contextId="wizard"
widgetId="org.eclipse.swt.widgets.Button#{{15}}-{{1.0}}"/>
<!--set all checkout option and finally press Finish button -->
<!--.........now press Finish -->
widgetId="org.eclipse.swt.widgets.Button#{{16}}-{{1.0}}"/>
</shell>
<!-- additional wait -->
</shell>
</macro>
I insert additional wait in the end of script but it doesnt help. Is it a
known limitation?
Thanks, I've seen it. I just think that there is another way for it.
Vladimir
>> long-run operation
>> exception:
>> Thanks in advance,
>> Vladimir.
Re: GUI recorder - wait until job completed [message #61477 is a reply to message #61378] Tue, 28 March 2006 13:15 Go to previous messageGo to next message
Originally posted by: Dmitry.M.Kononov.gmail.com
Hi Ali,
I have run into the same problem. Looks like it doesn't matter if the
"Synchronous" checkbox under the Behavior tab is checked or not. It seems
the test cases execute in an asynchronous manner always.
Could you please explain what does "all user Eclipse jobs" mean in detail?
Please look at the following test suite.
1) Import a Java project. The project should be really big.
2) Clean project.
3) Build project.
4) Remove project from the Eclipse.
All these test cases invocations marked as synchronous under the Behavior
tab.
What we have in practice?
If the first test case takes long time, since a project is importing from
CVS or an archive, we get something like this:
1) running
2) waiting
3) waiting
4) waiting
If the first test case imports a project into the workspace as an existing
one we get jobs in a progress view as follows:
1) done
2) running
3) waiting
4) waiting
These jobs look overlapping. So, what is the sense of the "Synchronous"
checkbox under the Behavior tab?
There is another issue.
An AGR test suite launcher does not wait all the test cases finish. It
closes a tested workbench without regard to whether some test cases are
still running/waiting.
It looks like the launcher has only one goal: to launch all the test cases
and close a test workbench immediately.
Could you please explain me what do I do incorrectly?
Thanks.
Dmitry
Re: GUI recorder - wait until job completed [message #62271 is a reply to message #61477] Wed, 29 March 2006 12:13 Go to previous messageGo to next message
Hi Dmitry,
The "Synchronous" option doesn't have any semantics with AGR test suites.
The option was taken out in 4.2.
"User eclipse jobs" are jobs that are registered with Eclipse's job manager.
Can you use time-dependent wait commands in your test suite (e.g. <command
type="wait" time-to-wait="10000"/> causes a 10 second wait). If you are
specifying wait commands that are longer than 30 seconds, then ensure to
increase the time-out threshold for each command OR alternatively you can do
multiple wait commands. For example:
<command type="wait" time-to-wait="25000"/>
causes a 50 second wait.
You'll have to manually insert the wait command after the project is
imported. You can adjust the time-to-wait value to wait a sufficient amount
of time before continuing with another test case.
One thing to keep in mind is that the time-out threshold value specified
under the behavior page is only applicable to standard launches. It will
not work in quick mode.
"Dmitry" <Dmitry.M.Kononov@gmail.com> wrote in message
news:fe431702c965de1bb196dca725395344$1@www.eclipse.org...
> Hi Ali,
> 2) Clean project.
> 3) Build project.
> tab.
> 1) running
> 2) waiting
> 3) waiting
> 4) waiting
> 1) done
> 2) running
> 3) waiting
> 4) waiting
> Thanks.
> Dmitry
Re: GUI recorder - wait until job completed [message #62295 is a reply to message #61429] Wed, 29 March 2006 12:16 Go to previous messageGo to next message
Did you use <command type="wait"/> or <command type="wait"
time-to-wait="..."/>?
If you used <command type="wait"/>, then keep in mind that the time-out
threshold set under the behavior page will only apply in a standard launch
(not quick mode).
If you used a time-dependent wait command, then simply try to increase the
time-to-wait value.
news:a2fd08c833cb23b37ad2da29c6dd9faf$1@www.eclipse.org...
> > Vladimir,
adjust.
delay.
> existing project):
gets.Tree#{{/}}-{{1.0}}"
> <item
Checkout}}-{{1.0}}"/>
> </command>
> </shell>
> </shell>
> </macro>
> known limitation?
the
> Vladimir
during
> >> long-run operation
appears
> >> exception:
> >> Thanks in advance,
> >> Vladimir.
Re: GUI recorder - wait until job completed [message #62653 is a reply to message #62295] Thu, 30 March 2006 09:02 Go to previous messageGo to next message
At the moment I use the following workaround: loop of wait commands.
> (not quick mode).
> time-to-wait value.
But why wait command do not works properly? Am I correctly understand that
wait command should wait until all eclipse job completed, i.e. while cvs
chechout will completed.
Vladimir.
Re: GUI recorder - wait until job completed [message #65582 is a reply to message #62653] Tue, 11 April 2006 11:25 Go to previous messageGo to next message
Yes, wait commands should wait until the CVS job completes, but wait command
(just like any other commands) will time-out if the time-out threshold is
reached.
news:79b603a6822fb0ecb27762353e221344$1@www.eclipse.org...
launch
> > (not quick mode).
the
> > time-to-wait value.
> Vladimir.
Re: GUI recorder - wait until job completed [message #66117 is a reply to message #65582] Wed, 12 April 2006 07:42 Go to previous messageGo to next message
> reached.
Hi Ali,
Unfortunately wait is not working for me. I used eclipse 3.1.2 with TPTP
4.1.0. For my particular step (import from cvs) I set timeout threshold
for each command to 90000 seconds. It should be enough for cvs checkout,
but after several seconds of checkout script continue execution of the
next steps. What do you think about it?
Here is parts from my macro script:
Here I set options in CVS Checkout wizard and press finish button in the
wizard
</shell>
<!--I suggest this command should wait until checkout completed -->
</shell>
</macro>
Vladimir.
> launch
>> > (not quick mode).
> the
>> > time-to-wait value.
>> Thanks,
>> Vladimir.
Re: GUI recorder - wait until job completed [message #66389 is a reply to message #66117] Thu, 13 April 2006 15:12 Go to previous message
It can be because the CVS job is not being registered as a type of job that
the wait command looks for. You can open a defect if you like me to look
into the problem in more details.
news:25b4790a00355eb481f58bc1d1a5856d$1@www.eclipse.org...
command
is
> > reached.
> Hi Ali,
> wizard
> </shell>
> </shell>
> </macro>
> Vladimir.
time-out
> > launch
> >> > (not quick mode).
increase
> > the
> >> > time-to-wait value.
that
cvs
> >> Thanks,
> >> Vladimir.
Previous Topic:InactiveProcessException when starting TPTP JUnit Plugin
Next Topic:AGR inside a runtime workspace
Current Time: Fri Jul 18 00:21:19 EDT 2025
Powered by FUDForum. Page generated in 0.09198 seconds
