Home » Archived » M2M (model-to-model transformation) » [ATL] ATL Port to Eclipse Linux
[ATL] ATL Port to Eclipse Linux [message #61198] Thu, 06 September 2007 17:17 Go to next message
Originally posted by: leonardobsjr.yahoo.com.br
I'm having some troubles with Eclipse @ Linux and ATL. I'm using Eclipse
3.3 and ATL 2.0. When i try to run a file, i select all the parameters and
apply. If i don't run it that time, next time i try to run (or check the
parameters) they're all gone! I can't even re-put it again because it
doesn't let me choose my ATL File. I need to delete the "run project" and
make a new one.
Any Suggestions?
Leonardo Jr.
Re: [ATL] ATL Port to Eclipse Linux [message #61271 is a reply to message #61198] Sun, 09 September 2007 19:34 Go to previous messageGo to next message
Originally posted by: jconlon.apache.org
I'm having the same problem:-(
> and apply. If i don't run it that time, next time i try to run (or check
> the parameters) they're all gone! I can't even re-put it again because
> it doesn't let me choose my ATL File. I need to delete the "run project"
> and make a new one.
> Any Suggestions?
> Leonardo Jr.
Re: [ATL] ATL Port to Eclipse Linux [message #61294 is a reply to message #61198] Sun, 09 September 2007 19:55 Go to previous messageGo to next message
Leonardo,
A partial work around is to run the atl from the the run tool pull down
not the run menu. At least it doesn't blow the configuration away each
time.
John
> and make a new one.
> Any Suggestions?
> Leonardo Jr.
Re: [ATL] ATL Port to Eclipse Linux [message #61628 is a reply to message #61294] Mon, 10 September 2007 11:28 Go to previous message
Hello Leonardo & John,
Is your problem the same as the one described in the following bugzilla
entry?
https://bugs.eclipse.org/bugs/show_bug.cgi?id=199074
If it is, you may want to check if you have additional information to
provide.
For instance, it would be nice to have John's workaround there ;-).
Frédéric Jouault
John E. Conlon wrote:
> Leonardo,
> time.
> John
>> Eclipse 3.3 and ATL 2.0. When i try to run a file, i select all the
>> parameters and apply. If i don't run it that time, next time i try to
>> run (or check the parameters) they're all gone! I can't even re-put it
>> again because it doesn't let me choose my ATL File. I need to delete
>> the "run project" and make a new one.
>> Any Suggestions?
>> Thanks,
>> Leonardo Jr.
Previous Topic:[ATL] getAppliedStereotypes returns emptyList
Next Topic:[M2M] On the usage of prefixes in the M2M newsgroup
Current Time: Mon Jul 14 04:50:55 EDT 2025
Powered by FUDForum. Page generated in 0.08835 seconds
