Home » Modeling » TMF (Xtext) » [Xtext] dynamic notion definitions
| [Xtext] dynamic notion definitions [message #61155] |
Mon, 20 July 2009 08:46  |
Originally posted by: alex.gmail.com
Hi everyone,
I have some notions in my model - lets call it 'component'. But the list
of components are defined in runtime only.
So I want at least to be able to populate content assist with that list.
To do that, as far as I understand, I need to implement
MyDslProposalProvider.complete...() methods - I just can't find any
snippet on how to do that.
But basically I would like to do more complicated stuff - which is to
import those notions into the model dynamically. Which means that those
'components' have some properties inside and I want to have those
notions in my model and use them with cross references.
Any ideas?
--A
| Re: [Xtext] dynamic notion definitions [message #61204 is a reply to message #61155] |
Mon, 20 July 2009 09:29   |
Hi Alex,
if I understood you correctly, you want to make some model elements
available for content assist and cross linking, that are not defined in
your model file or in a referenced model file. These 'components' only
exist in-memory.
I'ld try to implement a scope provider, that makes these elements
available as ScopedElements. ContentAssist and CrossLinking will work
out of the box with them.
As for your first question regarding the implementation of a completeXXX
method: Please have a look at the docs:
http://www.eclipse.org/Xtext/documentation/0_7_0/xtext.html# contentAssist
Hope that helps,
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 20.07.2009 14:46 Uhr, schrieb Alex:
> Hi everyone,
> Any ideas?
> Best regards,
> --A
| Re: [Xtext] dynamic notion definitions [message #61351 is a reply to message #61204] |
Mon, 20 July 2009 10:53   |
--------------070004010909080906030306
Content-Type: text/plain; charset=windows-1251; format=flowed
Sebastian Zarnekow wrote:
> Hi Alex,
> in your model file or in a referenced model file. These 'components'
> only exist in-memory.
> completeXXX method: Please have a look at the docs:
> Hope that helps,
> Sebastian
and to understand what do I mean think about a simple language using
which you can say "*build *<what> *using* <list_of_components>"
and then on a client side application you types something like "*build
*car *using* component1, component5, component8" but the list of
components with all properties (like price, color etc.) lives on a
server and not hard coded on a client side.
Content-Type: text/html; charset=windows-1251
<html>
<head>
<meta content="text/html;charset=windows-1251"
http-equiv="Content-Type">
</head>
<blockquote cite="mid:h41rf7$9gu$1@build.eclipse.org" type="cite">Hi
Alex,
<br>
<br>
exist in-memory.
<br>
<br>
<br>
<br>
<br>
<a class="moz-txt-link-freetext" href=" http://www.eclipse.org/Xtext/documentation/0_7_0/xtext.html# contentAssist"> http://www.eclipse.org/Xtext/documentation/0_7_0/xtext.html# contentAssist</a>
<br>
<br>
Hope that helps,
<br>
Sebastian
<br>
<br>
</blockquote>
which you can say
| Re: [Xtext] dynamic notion definitions [message #61693 is a reply to message #61519] |
Tue, 21 July 2009 03:08  |
Hi Alex,
I assume the following scenario, please correct me if I'm wrong:
You'll define a DSL with a concept of components. These components are
not declared by you, but by your clients. Each client may define other
components. You try to find a way to refer to these client specific
components from the DSL. Is this right?
That sounds to me like a very straight forward use case for multiple
languages. You define your DSL as is and another one for the definition
of components. The latter may or may not be a textual DSL, lets assume
it is textual for now.
Usually you would:
1) Start with your component DSL:
grammar org.foo.Components with org.eclipse.xtext.common.Terminals
generate componentsMM "http://org.foo.something/Components"
// rules follow here, at least one of them refers to components
Component:
name=ID // something more;
2) Generate the component DSL.
3) Create your second DSL:
grammar org.foo.DSL with org.eclipse.xtext.common.Terminals
generate dslMM "http://org.foo.something/DSL"
import
" platform:/resource/componentLangProject/src-gen/org/foo/Comp onents.ecore "
// rule go here
Import:
'components' 'from' importURI=STRING;
Something:
referToComponent=[Component] // more to come ...
4) Set the path to the component's genmodel in your MWE file (search
this newsgroup for details)
5) Generate your DSL.
Clients should create their components and refer to them from their DSL
file. The explicit import may be ommitted if you use some convention
over configuration principle.
If you do not want to use a textual notion for the definition of
components, you may create the components EPackage (Metamodel) manually
and refer to it the same way as in step (3). Clients would have to
implement a special interface / extension point / whatever mechanism to
provide their components. However, you'll need to come up with the
appropriate infrastructure for this solution.
Sebastian
Am 20.07.2009 18:21 Uhr, schrieb Alex:
>> Hi Alex,
>> model elements that are content of a scope are not necessarily
>> contained in the same resource. But they have to be referable
>> elements, thus you have to import the epackage in your grammar and
>> declare the cross links to their type.
>> Hope that helps,
>> Sebastian
> That's exactly what I was thinking about. But the only possibility to
> achieve that is to generate the file with component definitions in
> runtime and than to include it in to the project. But firstly I don't
> know how to do that (and any help will be very appreciated) and secondly
> I was wondering if there is simpler way to achieve what I'm trying to
> achieve.
> regards,
> --A
Current Time: Fri Nov 07 14:02:56 EST 2025
Powered by FUDForum. Page generated in 0.04650 seconds
