| Quicker Eclipse 3.0 [message #61140] |
Fri, 06 May 2005 13:32  |
Originally posted by: vpalasi.nospamaurumsol.com
Hi everybody.
I'm preparing a course about J2EE using Eclipse and Lomboz in Windows XP.
The last time I taught this course I used Eclipse 2.1 and was satisfied.
I'm now using Eclipse 3.0 and it is so SLOW. It takes a lot of resources and
is irresponsive. Programming like this is frustrating: you don't do another
thing than waiting. Moreover, I cannot change the machines in the University
I teach (though they are updated enough and even so, Eclipse is very slow).
Does anybody know how to make Eclipse a little bit quicker? (Maybe some
configuration of Windows or Eclipse can help). I don't want the first
experience in Java of my students will be so frustrating.
Any help would be greatly appreciated.
TIA,
Vicent Palas
| Re: Quicker Eclipse 3.0 [message #65122 is a reply to message #64056] |
Tue, 17 May 2005 03:18  |
Originally posted by: hcs33.egon.gyaloglo.hu
You can turn off some features of Eclipse which may use lots of resources.
Some tips can be found in the Eclipse Wiki:
http://eclipsewiki.editme.com/GeneralFaq
Also, because this configuration has fairly low amount of memory, you should
do the following:
- make sure that only Eclipse is running (close all other programs which can
use memory)
- should use a 16-bit color mode instead of a true-color one
- should not use background image for desktop
- try using '-vmargs -Xmx96M' for running Eclipse.
- make sure that the Eclipse installation and the used workspaces are on the
machine hard disk (do not use network drives - it can slow down Eclipse)
I also recommend a memory upgrade if it is an available option. For
education purposes an additional 64MB ram should be fine (however at least a
+128MB is recommended).
HTH,
Csaba
Vicent Palas
FUDForum. Page generated in 0.07380 seconds
