Home » Eclipse Projects » Nebula » [Grid/GridViewer] IndexOutOfBoundsException
[Grid/GridViewer] IndexOutOfBoundsException [message #61111] Tue, 09 December 2008 11:10 Go to next message
I came across a IndexOutOfBoundsException when using the Grid together with
the GridViewer. I'm using CellSelectionEnabled(true) and have added a filter
to the GridViewer. When the Filter returns 0 rows and you click on the
TopLeft Corner (ie selecting all cells) the following exeception is thrown:
java.lang.IndexOutOfBoundsException: Index: 0, Size: 0
at java.util.ArrayList.RangeCheck(ArrayList.java:547)
at java.util.ArrayList.get(ArrayList.java:322)
at org.eclipse.nebula.widgets.grid.Grid.selectAllCells(Grid.jav a:8798)
at org.eclipse.nebula.widgets.grid.Grid.onMouseDown(Grid.java:6 708)
at org.eclipse.nebula.widgets.grid.Grid.access$6(Grid.java:6526 )
at org.eclipse.nebula.widgets.grid.Grid$10.mouseDown(Grid.java: 6402)
BR
Tommy
Re: [Grid/GridViewer] IndexOutOfBoundsException [message #61135 is a reply to message #61111] Tue, 09 December 2008 13:25 Go to previous message
Hi Tommy,
Please create bugs for all things you find so that I can work on them
(hopefully next weekend I can dedicate some time to grid). If you even
produce patches that even more welcome!
My schedule is currently filled with Nebula-Project-Lead work to get
Nebula back in shape.
Tom
Tommy schrieb:
> Hi
> BR
> Tommy
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: [Grid/GridViewer] IndexOutOfBoundsException [message #592925 is a reply to message #61111] Tue, 09 December 2008 13:25 Go to previous message
Hi Tommy,
Tom
Tommy schrieb:
> Hi
> BR
> Tommy
Previous Topic:[Grid/GridViewer] IndexOutOfBoundsException
Next Topic:Grid - Grid Colunm
Current Time: Fri Nov 07 15:11:53 EST 2025
Powered by FUDForum. Page generated in 0.03590 seconds
