Home » Modeling » TMF (Xtext) » [Xtext-0.7.1] some problems with the first steps
| [Xtext-0.7.1] some problems with the first steps [message #61081] |
Mon, 20 July 2009 07:49  |
Hello *,
I've got some problems with my new XText-project.
For migrate my old oAW-XText-project I'm testing TMF XText now.
1) I've downloaded today
http://download.itemis.com/distros/eclipse-SDK-3.5-xtext-0.7 .1-linux-gtk-x86_64.tar.gz
2) I've started this Eclipse and created a new XText project
3) I copied my old EBNF and make some changes for compatibility with
TMF-XText-0.7.1
4) run the workflow GenerateDsl.mwe
And now the problem, the parser was not generated.
" org.example.dsl.contentassist.antlr.internal.InternalDslPars er cannot
be resolved to a type".
In the project "dsl.ui" exists a package
"org.example.dsl.contentassist.antlr.internal". May the needed parser
should generated in there.
In documentation I found the hint to download separate ANTLR feature,
but it is installed yet.
What should I do now?
Ciao, Micha
| Re: [Xtext-0.7.1] some problems with the first steps [message #61788 is a reply to message #61765] |
Tue, 21 July 2009 05:58   |
Hi Michael,
please note that there should be two parsers, one in your main project
(the one with the dsl.xtext) and another one in your ui project. You'ld
have to add the options for both fragments. Please replace
<fragment class="org.eclipse.xtext.generator.AntlrDelegatingFragment" />
and use this one instead:
<fragment class="de.itemis.xtext.antlr.XtextAntlrGeneratorFragment">
<options backtrack="true" memoize="true"/>
</fragment>
Sebastian
Am 21.07.2009 10:09 Uhr, schrieb Michael Burhkardt:
> Hello Sebastian,
> you are right, there were an error.
> error(211):
> .../dsl/src-gen/org/example/parser/antlr/internal/InternalDs l.g:2635:1:
> [fatal] rule ruleReceive has non-LL(*) decision due to recursive rule
> invocations reachable from alts 1,2. Resolve by left-factoring or using
> syntactic predicates or using backtrack=true option.
> If found in the documentation the hint, to insert the following lines
> into the workflow file
> <fragment class="de.itemis.xtext.antlr.XtextAntlrUiGeneratorFragment" >
> </fragment>
> Now the org.example.dsl.contentassist.antlr.internal.InternalDslPars er
> was generated, but the main project cannot find it.
> Why?
> Should I add a depandancy manually?
> Ciao, Micha
> Sebastian Zarnekow schrieb:
>> Hi Michael,
>> are there any error messages in the logs when you invoke the
>> GenerateDsl.mwe?
>> Regards,
>> Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
| Re: [Xtext-0.7.1] some problems with the first steps [message #61811 is a reply to message #61788] |
Tue, 21 July 2009 06:10   |
Hi Sebastian,
I think, I got the error. If I use a capital letter for domain laguage name,
everything works fine with the given example from wizard.
So, now I try to copy my old ebnf into a new project. Thanks for you help.
Ciao, Micha
--- Original-Nachricht ---
Absender: Sebastian Zarnekow
Datum: 21.07.2009 11:58
> Hi Michael,
> </fragment>
> Sebastian
>> Hello Sebastian,
>> error(211):
>> </fragment>
>> Why?
>> Ciao, Micha
>>> Hi Michael,
>>> GenerateDsl.mwe?
>>> Regards,
>>> Sebastian
| Re: [Xtext-0.7.1] some problems with the first steps [message #61856 is a reply to message #61811] |
Tue, 21 July 2009 07:34   |
Hi Michael,
please consider to update Xtext to 0.7.1 as it incorporates a bunch of
fixes. For example, your lower case language name would have been
flagged as an error instead of a warning.
Sebastian
Am 21.07.2009 12:10 Uhr, schrieb Michael Burkhardt:
> Hi Sebastian,
> name, everything works fine with the given example from wizard.
> Ciao, Micha
>> Hi Michael,
>> You'ld have to add the options for both fragments. Please replace
>> </fragment>
>> Regards,
>> Sebastian
>>> Hello Sebastian,
>>> error(211):
>>> </fragment>
>>> Why?
>>> Ciao, Micha
>>>> Hi Michael,
>>>> GenerateDsl.mwe?
>>>> Regards,
>>>> Sebastian
| Re: [Xtext-0.7.1] some problems with the first steps [message #61880 is a reply to message #61788] |
Tue, 21 July 2009 10:22   |
Hello Sebastian,
in my main project I found a MWE file, but not in my UI project. I search for
the string "AntlrDelegatingFragment" in all file, but the single result was the
known GenerateDsl.mwe file from my main project.
Am I wrong?
Ciao, Micha
> Hi Michael,
> </fragment>
> Sebastian
>> Hello Sebastian,
>> error(211):
>> </fragment>
>> Why?
>> Ciao, Micha
>>> Hi Michael,
>>> GenerateDsl.mwe?
>>> Regards,
>>> Sebastian
| Re: [Xtext-0.7.1] some problems with the first steps [message #61935 is a reply to message #61880] |
Tue, 21 July 2009 11:52   |
Hi Michael,
I'm afraid my previous post was misleading.
I was refering to the workflow file in your dsl project. It contains the
fragments for the runtime and for the ui project. There are two
fragments that will create an Antlr based parser for you.
You need to define the backtracking in both fragments. You alread did
this for the ui, but I was assuming that you did not find the fragment
for the runtime parser.
The AntlrDelegatingFragment needs to be replaced by the
XtextAntlrGeneratorFragment which allows to define backtracking the same
way as for the ui parser.
Please search for AntlrDelegatingFragment in your GenerateDsl.mwe and use
</fragment>
instead.
Everything should have been fine if you already set backtracking to true
for the ui fragment _and_ the runtime fragment. In this case I'ld like
you to attach your mwe file because I have no idea why the parser should
be missing in your runtime project.
Sebastian
Am 21.07.2009 16:22 Uhr, schrieb Michael Burkhardt:
> Hello Sebastian,
> search for the string "AntlrDelegatingFragment" in all file, but the
> single result was the known GenerateDsl.mwe file from my main project.
> Am I wrong?
> Ciao, Micha
>> Hi Michael,
>> </fragment>
>> Regards,
>> Sebastian
>>> Hello Sebastian,
>>> error(211):
>>> </fragment>
>>> Why?
>>> Ciao, Micha
>>>> Hi Michael,
>>>> GenerateDsl.mwe?
>>>> Regards,
>>>> Sebastian
| Re: [Xtext-0.7.1] some problems with the first steps [message #62330 is a reply to message #61935] |
Wed, 22 July 2009 05:20  |
Don't be scared! Now I found the parts in the MWE file.
They are:
<!-- the following fragment tries to use the Antlr Generator fragment which can
be installed via update manager from http://download.itemis.com/updates/ -->
<!--fragment class="org.eclipse.xtext.generator.AntlrDelegatingFragment" / -->
</fragment>
and:
<!--fragment class="org.eclipse.xtext.generator.DelegatingGeneratorFragment "
delegate="de.itemis.xtext.antlr.XtextAntlrUiGeneratorFragment " message="You are
generating without ANTLR. It is highly recommended to download and use the
plugin 'de.itemis.xtext.antlr' \n\t using the update site
http://download.itemis.com/updates/.">
</fragment -->
</fragment>
I didn't found the second one.
Now, it works fine.
Thanks for your help. However, more problems will emerge for sure.
Ciao, Micha
Datum: 21.07.2009 17:52
> Hi Michael,
> </fragment>
> instead.
> Sebastian
Current Time: Fri Nov 21 04:23:29 EST 2025
Powered by FUDForum. Page generated in 0.04546 seconds
