Home » Modeling » GMF (Graphical Modeling Framework) » How to get the right cellEditor for a referenced Feature in the properties sheet
How to get the right cellEditor for a referenced Feature in the properties sheet [message #61019] Wed, 11 October 2006 17:20 Go to next message
Originally posted by: rbbnjmn.yahoo.com
I have a XNode object with a one-way reference to a Date
(a number of eInts for year, month, etc..). Since only one
graph node has this Date property I don't want to model it
in the graph.
The Date property does not appear in the property sheet for
an XNode unless I add an ItemPropertyDescriptor for it in the
NodeItemProvider. (?) why ?
So, I add an ItemPropertyDescriptor for the Date property in the
XNodeItemProvider.getPropertyDescriptors(Object) method. I see in
the debugger that I have used the correct (Date) StructuralFeature.
After this I get the property Ok, but with an empty ComboBox cell editor.
What I really need to to launch my own cell editor here.
Of course I also have a DateDataItemProvider class. I would have
expected it would have been used as the property label and cell
editor provider... but it is not. I assume I should customize this class
to provide my Date cell editor (?) for the moment its not even accessed
I think....
Any help appreciated!
Roy
code:
NodePackage nodePackage = NodeFactory.eINSTANCE.getNodePackage();
EReference feature = nodePackage.getXNode_Date();
ItemPropertyDescriptor ipd = new ItemPropertyDescriptor(adapterFactory,
"Date", "Date", feature);
itemPropertyDescriptors.add(ipd);
Re: How to get the right cellEditor for a referenced Feature in the properties sheet [message #61214 is a reply to message #61019] Thu, 12 October 2006 04:24 Go to previous messageGo to next message
Well, because this very implementation delegates to adapter factory and item
providers. You can supply different implementation (in which case it's
Platform, not GMF question ;) )
org.eclipse.emf.edit.ui.provider.ProviderDescriptor#createPr opertyEditor
might be helpful to understand why and how cell editor looks like.
Artem
"rbbnjmn" <rbbnjmn@yahoo.com> wrote in message
news:egjn79$q1g$1@utils.eclipse.org...
> in the graph.
> I think....
> Roy
> code:
Re: How to get the right cellEditor for a referenced Feature in the properties sheet [message #61961 is a reply to message #61214] Thu, 12 October 2006 18:37 Go to previous message
Artem,
Thanks for the hint, I continue looking into this.... ;-)
I've post the question to the emf group.
For the moment all is still murky,
Roy
"Artem Tikhomirov" <artem.tikhomirov@borland.com> wrote in message
news:egktug$6od$1@utils.eclipse.org...
> item providers. You can supply different implementation (in which case
> it's Platform, not GMF question ;) )
> Artem
>> in the graph.
>> I think....
>> Roy
>> code:
Previous Topic:TextDirectEditManager throws exception in Eclipse 3.2.1
Next Topic:Please help I need an advise how to create ebedded Label for figure ?
Current Time: Mon Nov 10 15:22:40 EST 2025
Powered by FUDForum. Page generated in 0.04217 seconds
