| 2 suggestions for XSD [message #61013] |
Mon, 09 May 2005 07:34  |
Originally posted by: adamNoSpam_._NoSPAMsoftfab.com
1) What schema.
Many schemas I have to work with are at the end of a long chain of
schemas i.e. I might be working on a schema which incudes a schema which
itself includes a schema etc.etc.
When you are then using the schema viewer & you get to an element which
is some distance into the model/tree you then have no idea which actual
schema contains the definition. What would be very usefull would be the
ability to see which actual schema contains a chosen type.
e.g. in the properties view you could include a further textbox which
says which schema this type resides in.
2) An example going all the way from XSD to a GEF editor.
I am looking at creating an XSD editor for an object model which is
expressed in XML. At present there is a tutorial for how to create an
EMF model from an xsd, and there are tutorials for how to create a GEF
editor from an EMF, but it would be usefull to have a tutorial where one
starts with an XSD & progresses right through to the GEF editor.
Preferably this would include best practice advice wrt how to separate
out the different levels such that if a schema changes then how to
ensure that only the minimal amount of work/refactoring will need to
occur at the GEF level.
Adam
| Re: 2 suggestions for XSD [message #61108 is a reply to message #61039] |
Tue, 10 May 2005 06:36  |
Ed Merks wrote:
> Adam,
> The WTP project provides a better XML Schema editor than the XSD
> project. XSD just provides a simple/sample editor (that I have no time
> to make better) whereas WTP is providing a "real tool". They'll be more
> able to make improvements based on your suggestions. (Ideally the
> editor would let you see all the sources and you could see any object
> selected its source view.)
OK I'll post that suggestion to the wtp group.
> The new GMF project is looking at the second issue of better edit
> support for GEF-based views for EMF model instances. Again, support for
> GEF is something our team would love to have done but just don't have no
> time to contain...
Fair enough
Adam
| Re: 2 suggestions for XSD [message #595439 is a reply to message #61013] |
Mon, 09 May 2005 07:49  |
Adam,
time to contain...
Adam Flinton wrote:
> 1) What schema.
> which itself includes a schema etc.etc.
> which is some distance into the model/tree you then have no idea which
> actual schema contains the definition. What would be very usefull
> would be the ability to see which actual schema contains a chosen type.
> one starts with an XSD & progresses right through to the GEF editor.
> Adam
| Re: 2 suggestions for XSD [message #595463 is a reply to message #61039] |
Ed Merks wrote:
> Adam,
> time to contain...
Fair enough
Adam
FUDForum. Page generated in 0.03322 seconds
