| Re: java.lang.NoClassDefFoundError: org/eclipse/hyades/logging/events/cbe/SituationType [message #60982 is a reply to message #60958] |
Tue, 28 March 2006 08:28  |
Hi Mariano,
This class is packaged in the hlcbe101.jar found in the
org.eclipse.hyades.logging.core plugin. Are you using the Eclipse JUnit
runner to run your TPTP URL JUnit test? If so, you will need to include the
following JARs on the classpath of your run configuration:
org.eclipse.hyades.logging.core:
-hlcore.jar (Common Base Event's TPTP Logging Core dependency)
-hlcbe101.jar (Common Base Event implementation)
org.eclipse.emf.ecore:
-org.eclipse.emf.ecore_2.1.0.jar (Common Base Event's Eclipse Modeling
Framework (EMF) dependency
org.eclipse.emf.common:
-org.eclipse.emf.common_2.1.0.jar (Common Base Event's Eclipse Modeling
Framework (EMF) dependency)
Optionally, you may need the follow JAR file if you are calling the TPTP
Logging Agent:
org.eclipse.hyades.execution:
-hexr.jar (TPTP Logging Agent)
Paul
"Mariano Eloy Fern
FUDForum. Page generated in 0.05025 seconds
