| Binding a Data Set Parameter to Report Parameter Not Working [message #60898] |
Thu, 21 July 2005 23:28  |
Originally posted by: attley.gmail.com
Hi folks,
Has anyone had any luck binding a dataset parameter to a report parameter.
I have followed the documentation to a t but no luck. Basically I enter a
value in the dialog window (report param value) but this value never makes
it into my query for some reason?
Can anyone help, I noticed that one user said that this functionality was
buggy. I'm hoping this can work somehow, any ideas?
Simon
| Re: Binding a Data Set Parameter to Report Parameter Not Working [message #72157 is a reply to message #69367] |
Mon, 05 September 2005 19:12  |
Originally posted by: John.xxxx.com
Please respond.
-John
John wrote:
> Hey guys,
> i have the similar problem and here are the parameters i created
> ParamMonth which is data/time datatype and in the Report table it is also
> date/time but from the front end user it will come as "MAY". I dont
> understand which default value to give.i tried '%' , ' MMM', 'MMM/yy', as
> per my requirement.
> -John
> Simon Attley wrote:
>> Thanks Nina.
>> I actually managed to get it working. My dataset parameters are:
>> Data Type: Integer
>> Default Value: 0
>> Allows Null: No
>> Optional: No
>> My corresponding report parameters are:
>> Data Type: Float
>> Formatting: Custom, fixed number #0
>> This works from eclipse when I run it in BIRT Web Viewer. And the params
>> are entered through the left frame in the viewer. I haven't tried passing
>> the params in URL string from my webpage yet though.
>> simon
FUDForum. Page generated in 0.10041 seconds
