Home » Newcomers » Newcomers » Does Java 1.5 work in Eclipse Platform 3.0.2?
Does Java 1.5 work in Eclipse Platform 3.0.2? [message #60776] Tue, 03 May 2005 15:24 Go to next message
Originally posted by: ajmacd.ns.sympatico.ca
I wanted to clarify if it's possible to set the workspace compiler
compliance level to 1.5 in version 3.0.2 of the platform. I had recently
downloaded the new version (I do not remember what version I had before),
but noticed I could not use 1.5, even though I have set jdk1.5.0_03 as my
installed JRE. I am using this in Windows XP Home Edition on a Toshiba
Satellite laptop. Searching the threads here revealed some snippets that
confirmed my suspicions.
For now I'm going to try 3.0.1 to see if Java 1.5 works with that.
Thank you,
Aaron J. M.
Re: Does Java 1.5 work in Eclipse Platform 3.0.2? [message #60778 is a reply to message #60776] Tue, 03 May 2005 15:28 Go to previous message
No.
You need the Eclipse 3.1 stream for compilation against 1.5.
Try 3.1 M6
HTH
Darins
"Aaron J. M." <ajmacd@ns.sympatico.ca> wrote in message
news:b4cfed55776806f7089b50f7f630971f$1@www.eclipse.org...
> Thank you,
> Aaron J. M.
Previous Topic:viewing api docs
Next Topic:HELP: java.lang.IllegalStateException: Workspace is closed.
Current Time: Thu Nov 20 08:19:44 EST 2025
Powered by FUDForum. Page generated in 0.08313 seconds
