Home » Newcomers » Newcomers » Moving Projects to a new Machine
Moving Projects to a new Machine [message #60760] Tue, 03 May 2005 01:25 Go to next message
Can anyoen tell me the key files to move 10s of personal Eclipse
projects to a new machine? I have moved the source trees,
but how do I teach Eclipse about all the projects I have?
-Paul
Re: Moving Projects to a new Machine [message #60766 is a reply to message #60760] Tue, 03 May 2005 06:17 Go to previous messageGo to next message
Move or to be safe copy the workspace, and point eclipse to the workspace.
"P.Hill" <goodhill@xmission.com> wrote in message
news:d572af$p09$1@news.eclipse.org...
> -Paul
Re: Moving Projects to a new Machine [message #60771 is a reply to message #60766] Tue, 03 May 2005 11:31 Go to previous messageGo to next message
Martin Holmes wrote:
>>Can anyone tell me the key files to move 10s of personal Eclipse
Ahh, yes, exactly, but the question is how; which file or setting?
As I said, I have all the files on the new machine exactly
where it was on the old machine.
Your use of the simple sounding 'pointing' suggests one master
setting somewhere and then it will see the entire collection.
So could you share where that setting is?
Should I install Eclipse from scratch then set something, or
should I install then copy some key file over the default install?
I hope that makes my question more precise and thus answerable.
thanks,
-Paul
Re: Moving Projects to a new Machine [message #60810 is a reply to message #60771] Thu, 05 May 2005 09:56 Go to previous messageGo to next message
On the original machine, you have somewhere a workspace directory that
Eclipse is using (the default location is
<eclipse-install-dir>/workspace, but it asked you the first time you
started Eclipse). Copy that directory to the new machine. If the
dreictory structure of the new one is exactly the same as the old one,
you can probably copy the entire Eclipse directory structure. Otherwise,
install Eclipse on the new machine and when starting it for the first
time tell it to use the workspace directory that you copied from the old
machine.
HTH,
Eric
Re: Moving Projects to a new Machine [message #61261 is a reply to message #60810] Fri, 06 May 2005 16:32 Go to previous message
> machine.
For the record, the choices for telling Eclipse where the workspace
is located are:
1. setting the start-in dir of the icon, c:\mydev\
where mydev contains \workspaces
1a. invoke it from the command line while working dir is the same dir.
2. use the -data switch to accomplish the same as start-in dir, but
include workspace in the path.
3. In 3.x setting the same value in the IDE via the new menu option.
-Paul
Previous Topic:StyledText Question
Next Topic:Which newsgroup?
Current Time: Mon Jul 14 15:49:27 EDT 2025
Powered by FUDForum. Page generated in 0.62999 seconds
