Home » Archived » Visual Editor (VE) » Add SWT objects to the palette
Add SWT objects to the palette [message #60703] Thu, 23 September 2004 05:12 Go to next message
I was looking the documentation about extending the VE.
Can we extend the palette and add new SWT objects?
Thank you.
Pepe
Re: Add SWT objects to the palette [message #60706 is a reply to message #60703] Thu, 23 September 2004 06:20 Go to previous messageGo to next message
Hi Pepe,
> Thank you.
See Rich's reply to the earlier question "No SWT on palette".
What the Visual Editor does is only include items on the palette that
are avaliable in the build path. By default AWT and Swing are there
because they are part of J2SE, however SWT isn't. If you think about
the analogy of code assist, this only lists the classes that are in the
build path of your project and if you want a class that's in a JAR not
in your build path you have to manually add it to the build path.
Likewise for the VE to be able to work with SWT the project's build path
needs to have SWT added - the easiest way is just to use the "New visual
class" wizard will configures it all for you.
One idea we do have is to make this more obvious, so perhaps the palette
has a category called "Other..." and choosing this would show that SWT
was available but the project wasn't configured correctly, and it'd lead
you down how to do this. Another is that we put the categories for
available (but not yet usable) stuff on the palette (perhaps grayed out)
and selecting them would likewise auto-configure for you.
As Rich said, the palette is an area we need to work on including user
customization and knowing what's available but not yet in the build path
also needs to be addressed.
Joe Winchester
Re: Add SWT objects to the palette [message #60728 is a reply to message #60706] Fri, 24 September 2004 13:20 Go to previous message
Joe Winchester wrote:
> Hi Pepe,
>> Thank you.
Joe, I'm not sure this is what he's asking.
If you're asking about how to customize the palette with your own SWT
controls, then the short answer is that it can be done. See the thread
titled "How to extend the palette" for starters and ask more questions
when you have them.
Dave Orme
Dave Orme
Eclipse Visual Editor Project Lead
Advanced Systems Concepts' Chief Architect
http://www.swtworkbench.com http://essentialdata.sf.net
Re: Add SWT objects to the palette [message #598978 is a reply to message #60703] Thu, 23 September 2004 06:20 Go to previous message
Hi Pepe,
> Thank you.
Joe Winchester
Re: Add SWT objects to the palette [message #599180 is a reply to message #60706] Fri, 24 September 2004 13:20 Go to previous message
> Hi Pepe,
>> Thank you.
when you have them.
Dave Orme
Dave Orme
Previous Topic:SWT Class throws NULL exception
Next Topic:Thin prerequisites for Visual Editor
Current Time: Sat Jul 26 08:32:38 EDT 2025
Powered by FUDForum. Page generated in 0.04212 seconds
