Home » Archived » Visual Editor (VE) » Layout Problem
Layout Problem [message #60681] Wed, 22 September 2004 10:47 Go to next message
Originally posted by: mathurin.lm.agiledss.com
I have one problem with the "customize layout". I can't change the
default layout. I always receive thes message : No layout options to
customize on the current selection.
Here is may configuration :
Eclipse SDK 3.0.1
EMF SDK 2.0.1
GEF SDK 3.0.1
VE SDK 1.0.1
I want to use the gridLayout in a SWT composite, but with no
success...with VE.
Maybe I do something wrong...
Louis-Michel
Re: Layout Problem [message #60683 is a reply to message #60681] Wed, 22 September 2004 10:56 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
That window customizes the "current" layout. To switch to a different
layout, you go to the property sheet and change the layout from there.
Thanks, Rich Kulp
Re: Layout Problem [message #60685 is a reply to message #60683] Wed, 22 September 2004 10:57 Go to previous messageGo to next message
Louis-Michel
Re: Layout Problem [message #60686 is a reply to message #60681] Wed, 22 September 2004 11:07 Go to previous message
The Customize Layout dialog is not for changing the layout... just for changing
properties of the current layout or, for changing the constraints of components
that are children of the container with the layout.
If you want to change the layout, select the composite and change it's "layout"
property in the property sheet viewer.
Regards...
Peter Walker
Louis-Michel wrote:
> Eclipse SDK 3.0.1
> EMF SDK 2.0.1
> GEF SDK 3.0.1
> VE SDK 1.0.1
> success...with VE.
> Louis-Michel
Re: Layout Problem [message #598820 is a reply to message #60681] Wed, 22 September 2004 10:56 Go to previous message
Thanks, Rich Kulp
Re: Layout Problem [message #598832 is a reply to message #60683] Wed, 22 September 2004 10:57 Go to previous message
Louis-Michel
Re: Layout Problem [message #598839 is a reply to message #60681] Wed, 22 September 2004 11:07 Go to previous message
Regards...
Peter Walker
Louis-Michel wrote:
> Eclipse SDK 3.0.1
> EMF SDK 2.0.1
> GEF SDK 3.0.1
> VE SDK 1.0.1
> success...with VE.
> Louis-Michel
Previous Topic:Layout Problem
Next Topic:No SWT on palette
Current Time: Fri Jul 18 04:23:58 EDT 2025
Powered by FUDForum. Page generated in 0.09619 seconds
