| Layout Problem [message #60681] |
Wed, 22 September 2004 10:47  |
Originally posted by: mathurin.lm.agiledss.com
I have one problem with the "customize layout". I can't change the
default layout. I always receive thes message : No layout options to
customize on the current selection.
Here is may configuration :
Eclipse SDK 3.0.1
EMF SDK 2.0.1
GEF SDK 3.0.1
VE SDK 1.0.1
I want to use the gridLayout in a SWT composite, but with no
success...with VE.
Maybe I do something wrong...
Louis-Michel
| Re: Layout Problem [message #60686 is a reply to message #60681] |
Wed, 22 September 2004 11:07  |
The Customize Layout dialog is not for changing the layout... just for changing
properties of the current layout or, for changing the constraints of components
that are children of the container with the layout.
If you want to change the layout, select the composite and change it's "layout"
property in the property sheet viewer.
Regards...
Peter Walker
Louis-Michel wrote:
> Eclipse SDK 3.0.1
> EMF SDK 2.0.1
> GEF SDK 3.0.1
> VE SDK 1.0.1
> success...with VE.
> Louis-Michel
| Re: Layout Problem [message #598820 is a reply to message #60681] |
Wed, 22 September 2004 10:56  |
Originally posted by: richkulp.NO.SPAM.us.ibm.com
That window customizes the "current" layout. To switch to a different
layout, you go to the property sheet and change the layout from there.
Thanks, Rich Kulp
| Re: Layout Problem [message #598832 is a reply to message #60683] |
Wed, 22 September 2004 10:57  |
Louis-Michel
| Re: Layout Problem [message #598839 is a reply to message #60681] |
Regards...
Peter Walker
Louis-Michel wrote:
> Eclipse SDK 3.0.1
> EMF SDK 2.0.1
> GEF SDK 3.0.1
> VE SDK 1.0.1
> success...with VE.
> Louis-Michel
FUDForum. Page generated in 0.04636 seconds
