Home » Modeling » GMF (Graphical Modeling Framework) » Regenerate gmfmap?
Regenerate gmfmap? [message #60583] Mon, 09 October 2006 06:29 Go to next message
Het,
I've made changes to my gmfgraph, just want to use an elipse instead of a
rectangel, model validates fine.
How do I regenerate my gmfmap to include the changes?
Cheers
Re: Regenerate gmfmap? [message #60585 is a reply to message #60583] Mon, 09 October 2006 06:39 Go to previous messageGo to next message
Originally posted by: tobk.gmx.de
Gaff wrote:
> Het,
> Cheers
You do not have to regenerate the map. Just save the graph file when there
are no unsaved changes in the map, and the map will be updated
automatically. But you have to regenerate the gmfgen (by rightclicking the
map) and - of course - the diagram editor.
Re: Regenerate gmfmap? [message #60586 is a reply to message #60585] Mon, 09 October 2006 06:52 Go to previous messageGo to next message
Thought that was supposed to happen, but the updates didn't seem to be
registering.
Deleted both the gmfmap and gmfgen files and regenerated them both.
If I update the gmfmap within the gmfmap file will these changees also
update the original file?
Re: Regenerate gmfmap? [message #60607 is a reply to message #60585] Mon, 09 October 2006 13:15 Go to previous message
Originally posted by: reneschm.cs.tu-berlin.de
regenerating gmfgen doesn't always do all updates, its better to delete
gmfgen first.
Gmfmap needs no update, because there you have only a reference to a
Diagram Node. when generating gmfgen the figureclass that belongs to
this diagram node is generated and regenerating gmfgen doesn't update
this code.
regards
Rene
TU Berlin - Tiger Team
tobias schrieb:
> Gaff wrote:
>> Het,
>> Cheers
Previous Topic:take over coordinates from model into the diagram of the GMF editor?
Next Topic:gmf tutorial problem (step: graphical definition)
Current Time: Sat Jul 26 12:37:42 EDT 2025
Powered by FUDForum. Page generated in 0.03139 seconds
